[PATCH] New fstest hitting blocks map grow and shrink
Krzysztof Mięsowicz krzysztof.miesowicz at gmail.com
Tue Oct 16 09:22:20 UTC 2012
Hi
I'm sending new fstest which hits growing and shrinking blocks map. It
covers about 100 instructions from rtems_rfs_block_map_grow and about 60 in
rtems_rfs_block_map_shrink.
There are still uncovered ranges in both functions and other rfs_block_map
functions. Most of them can execute only when rtems_rfs_inode_load fail or
when rtems_rfs_buffer_handle_request fails. I don't know how to make it
failed, but if you have any tips I will appreciate it a lot.
Please, take a look at this test and point incorrectness and mistakes you
notice.
Krzysztof Miesowicz
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121016/6ac82dc9/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20121016/6ac82dc9/attachment.obj>
