building modified RTEMS source tree
Andrei Dimitrief-Jianu andrei.dimitrief.jianu at gmail.com
Sat Oct 20 17:47:15 UTC 2012
Hello,
I am trying to add files to the source tree and re-compile. For now, I
am adding one header file (in cpukit/rtems/include/rtems/rtems) and
one source file (cpukit/rtems/src).
I modified cpukit/rtems/Makefile.am to include the header file and the
source file.
I ran bootstrap -p, bootstrap in my source directory, and configure,
make all in my build directory.
Below are the options I am using with configure:
../rtems-20121015-2250/configure -target=sparc-rtems4.10
--enable-maintainer-mode --enable-tests --disable-posix
--disable-itron --disable-networking --enable-rtemsbsp="sis"
--prefix=/home/andrei/Src/rtems-20121015-2250-install
The build explodes with the messages below. Any thoughts on how to fix this?
Not sure if this helps, but just adding the header file with some type
definitions does not break the build.
Thanks,
Andrei.
Making all in rtems
gmake[5]: Entering directory
`/home/andrei/Src/rtems-20121015-2250-build/sparc-rtems4.10/c/sis/cpukit/rtems'
 cd .. && /bin/sh ./config.status rtems/Makefile depfiles
config.status: creating rtems/Makefile
config.status: executing depfiles commands
gmake[5]: Leaving directory
sparc-rtems4.10-gcc --pipe -DHAVE_CONFIG_H   -I..
-I../../cpukit/../../../sis/lib/include -D__RTEMS_INSIDE__
-mcpu=cypress -O2 -g -Wall -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -MT src/librtems_a-eventflag.o
-MD -MP -MF src/.deps/librtems_a-eventflag.Tpo -c -o
src/librtems_a-eventflag.o `test -f 'src/eventflag.c' || echo
'../../../../../../rtems-20121015-2250/c/src/../../cpukit/rtems/'`src/eventflag.c
In file included from
../../cpukit/../../../sis/lib/include/rtems/score/address.h:34,
                 from
../../cpukit/../../../sis/lib/include/rtems/score/chain.h:37,
                 from
../../cpukit/../../../sis/lib/include/rtems/score/object.h:25,
                 from ../../cpukit/../../../sis/lib/include/rtems/config.h:34,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/eventflag.h:52,
                 from
../../../../../../rtems-20121015-2250/c/src/../../cpukit/rtems/src/eventflag.c:25:
../../cpukit/../../../sis/lib/include/rtems/score/address.inl:43:
error: expected '=', ',', ';', 'asm' or '__attribute__' before 'void'
../../cpukit/../../../sis/lib/include/rtems/score/address.inl:63:
../../cpukit/../../../sis/lib/include/rtems/score/address.inl:84:
'int32_t'
../../cpukit/../../../sis/lib/include/rtems/score/address.inl:103:
error: expected '=', ',', ';', 'asm' or '__attribute__' before 'bool'
../../cpukit/../../../sis/lib/include/rtems/score/address.inl:129:
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/chain.h:128: error:
expected declaration specifiers or '...' before 'size_t'
../../cpukit/../../../sis/lib/include/rtems/score/chain.h:129: error:
../../cpukit/../../../sis/lib/include/rtems/score/chain.h:189,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:42: error:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:58: error:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:76: error:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:92: error:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:107:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:122:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:137:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:153:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:169:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:184:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:199:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:216:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:234:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:251:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:268:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:286:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:302:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:316:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:333:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:360:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:388:
'Chain_Node'
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:410:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:434:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:458:
../../cpukit/../../../sis/lib/include/rtems/score/chain.inl:476:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:26,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:40: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'ISR_Level'
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:45: error:
'ISR_Vector_number'
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:63: warning:
parameter names (without types) in function declaration
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:82: error:
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:88: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'volatile'
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:95: error:
'ISR_Handler_entry'
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:215: error:
'_ISR_Is_in_progress'
../../cpukit/../../../sis/lib/include/rtems/score/isr.h:221,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/isr.inl:36: error:
../../cpukit/../../../sis/lib/include/rtems/score/isr.inl:48: error:
In file included from ../../cpukit/../../../sis/lib/include/rtems/config.h:34,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/object.h:60: error:
expected specifier-qualifier-list before 'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:73: error:
expected declaration specifiers or '...' before '*' token
../../cpukit/../../../sis/lib/include/rtems/score/object.h:76: error:
expected declaration specifiers or '...' before 'uint16_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:77:
warning: type defaults to 'int' in declaration of 'bool'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:77: error:
'bool' declared as function returning a function
warning: function declaration isn't a prototype
../../cpukit/../../../sis/lib/include/rtems/score/object.h:124: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'Objects_Id'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:130: error:
'Objects_Maximum'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:337: error:
expected specifier-qualifier-list before 'Objects_Id'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:350: error:
expected specifier-qualifier-list before 'uint16_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:410: error:
'Objects_Information'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:500: error:
expected declaration specifiers or '...' before 'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:501: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:502: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:504: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:521: error:
expected ')' before 'api'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:546: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:624: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:625: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:626: error:
expected declaration specifiers or '...' before 'Objects_Id'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:666: error:
expected ')' before 'id'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:696: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:727: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:729: error:
expected declaration specifiers or '...' before 'ISR_Level'
../../cpukit/../../../sis/lib/include/rtems/score/object.h:756: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:786: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:803: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:805: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:821: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:834: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:850: error:
../../cpukit/../../../sis/lib/include/rtems/score/object.h:870: error:
'_Objects_Set_name' declared as function returning a function
../../cpukit/../../../sis/lib/include/rtems/score/object.h:899,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:39:
'Objects_Id'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:61:
'Objects_APIs'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:73:
'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:88:
'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:110:
'Objects_Maximum'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:127:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:146:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:164:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:185:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:203:
'Objects_Control'
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:234:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:267:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:287:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:310:
../../cpukit/../../../sis/lib/include/rtems/score/object.inl:334:
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:27,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/config.h:21,
                 from ../../cpukit/../../../sis/lib/include/rtems/config.h:58,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:392: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:405: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:418: error:
'_Heap_Free' declared as function returning a function
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:432: error:
'_Heap_Walk' declared as function returning a function
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:468: error:
'_Heap_Size_of_alloc_area' declared as function returning a function
../../cpukit/../../../sis/lib/include/rtems/score/heap.h:493,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:35: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'Heap_Block'
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:40: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:45: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:50: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:55: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:64: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:79: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:92: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:100: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'uintptr_t'
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:114: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:125: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:133: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:140: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:147: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:156: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:161: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:171: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:176: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:186: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:193: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:207: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:212: error:
../../cpukit/../../../sis/lib/include/rtems/score/heap.inl:217: error:
../../cpukit/../../../sis/lib/include/rtems/score/priority.h:42,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:29,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:523: error:
'Context_Control_fp'
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:538: error:
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:539: error:
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:548: error:
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:897: error:
expected declaration specifiers or '...' before 'proc_ptr'
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:898: error:
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:909: error:
../../cpukit/../../../sis/lib/include/rtems/score/cpu.h:910: error:
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/priority.h:95:
'volatile'
../../cpukit/../../../sis/lib/include/rtems/score/priority.h:103:
'Priority_Bit_map_control'
../../cpukit/../../../sis/lib/include/rtems/score/priority.h:141,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:37:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:51:
error: expected '=', ',', ';', 'asm' or '__attribute__' before '_Bool'
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:67:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:78:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:92:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:103:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:117:
'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:131:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:145:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:159:
'Priority_Control'
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:177:
../../cpukit/../../../sis/lib/include/rtems/score/priority.inl:208:
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:30,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/tod.h:124: error:
../../cpukit/../../../sis/lib/include/rtems/score/tod.h:129: error:
'Timestamp_Control'
../../cpukit/../../../sis/lib/include/rtems/score/tod.h:134: error:
'Timestamp_Control'
../../cpukit/../../../sis/lib/include/rtems/score/tod.h:244,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/tod.inl:39: error:
../../cpukit/../../../sis/lib/include/rtems/score/tod.inl:48: error:
../../cpukit/../../../sis/lib/include/rtems/score/tod.inl:57: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:31,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:72:
error: expected ')' before 'void'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:138:
error: expected specifier-qualifier-list before
'Watchdog_Service_routine_entry'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:152:
'volatile'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:159:
'volatile'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:166:
'volatile'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:173:
'Watchdog_Nanoseconds_since_last_tick_routine'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:180:
'Chain_Control'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:186:
'Chain_Control'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.h:306,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:37:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:55:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:69:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:83:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:97:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:109:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:123:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:142:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:160:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:175:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:192:
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:208:
'Watchdog_Control'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:222:
'Watchdog_Control'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:236:
'Watchdog_Control'
../../cpukit/../../../sis/lib/include/rtems/score/watchdog.inl:250:
'Watchdog_Control'
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.h:101,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:32,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:36: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:50: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:63: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:76: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:88: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:101:
../../cpukit/../../../sis/lib/include/rtems/rtems/modes.inl:116:
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/types.h:83: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'rtems_id'
../../cpukit/../../../sis/lib/include/rtems/score/states.h:117,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:39,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/config.h:22,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:40:
'States_Control'
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:57:
'States_Control'
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:73:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:88:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:103:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:118:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:133:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:148:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:163:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:178:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:193:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:208:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:223:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:238:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:253:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:268:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:283:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:298:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:315:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:332:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:348:
../../cpukit/../../../sis/lib/include/rtems/score/states.inl:364:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:58,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:40,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/context.h:51: error:
../../cpukit/../../../sis/lib/include/rtems/score/stack.h:59,
                 from
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:65,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/stack.inl:36: error:
../../cpukit/../../../sis/lib/include/rtems/score/stack.inl:52: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/stack.inl:65: error:
../../cpukit/../../../sis/lib/include/rtems/score/stack.inl:81: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'size_t'
../../cpukit/../../../sis/lib/include/rtems/score/stack.inl:100:
'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/tqdata.h:106,
                 from
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:68,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/tqdata.inl:36:
'uint32_t'
../../cpukit/../../../sis/lib/include/rtems/score/tqdata.inl:49:
../../cpukit/../../../sis/lib/include/rtems/score/tqdata.inl:61:
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:254: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:423: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:429: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:435: error:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:444: error:
'Context_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:451: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:457: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:464: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:469: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:475: error:
'Chain_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:481: error:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:489: error:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:496: error:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:505: error:
expected '=', ',', ';', 'asm' or '__attribute__' before 'struct'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:515: error:
'Timestamp_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:731: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:821: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:843: error:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:26,
                 from
../../cpukit/../../../sis/lib/include/rtems/score/thread.h:847,
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.h:81:
'System_state_Codes'
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.h:87,
                 from
                 from
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:33:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:40:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:54:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:59:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:66:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:73:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:80:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:87:
../../cpukit/../../../sis/lib/include/rtems/score/sysstate.inl:94:
                 from
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:40:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:65:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:77:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:89:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:100:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:112:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:127:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:140:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:154:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:178:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:238:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:249:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:259:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:268:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:277:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:288:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:299:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:308:
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:319:
'struct'
../../cpukit/../../../sis/lib/include/rtems/score/thread.inl:328:
../../cpukit/../../../sis/lib/include/rtems/rtems/eventset.h:125,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:42,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/eventset.inl:35:
../../cpukit/../../../sis/lib/include/rtems/rtems/eventset.inl:48:
../../cpukit/../../../sis/lib/include/rtems/rtems/eventset.inl:66:
'rtems_event_set'
../../cpukit/../../../sis/lib/include/rtems/rtems/eventset.inl:80:
'rtems_event_set'
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.h:146,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:43,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.inl:37: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.inl:56: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.inl:76: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.inl:89: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/asr.inl:104: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.h:188,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:44,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:37: error:
'rtems_attribute'
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:51: error:
'rtems_attribute'
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:65: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:93: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:106: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:119: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:133: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:146: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:159: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:172: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/attr.inl:185: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/status.h:211,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:45,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/status.inl:36:
../../cpukit/../../../sis/lib/include/rtems/rtems/status.inl:49:
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:264: error:
expected declaration specifiers or '...' before 'rtems_id'
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:281: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:291: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:302: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:315: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:342: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:353: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:363: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:375: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:388: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:422: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:431: error:
expected ')' before 'tid'
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:442: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:453: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:462: error:
'rtems_task_self'
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.h:492,
                 from
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.inl:36: error:
'Thread_Control'
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.inl:47: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.inl:62: error:
'Priority_Control'
../../cpukit/../../../sis/lib/include/rtems/rtems/tasks.inl:75: error:
In file included from ../../cpukit/../../../sis/lib/include/rtems/config.h:60,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/extension.h:209: error:
../../cpukit/../../../sis/lib/include/rtems/extension.h:230: error:
../../cpukit/../../../sis/lib/include/rtems/extension.h:245: error:
../../cpukit/../../../sis/lib/include/rtems/extension.h:251,
                 from
                 from
../../cpukit/../../../sis/lib/include/rtems/extension.inl:36: error:
../../cpukit/../../../sis/lib/include/rtems/rtems/eventflag.h:133:
error: expected specifier-qualifier-list before 'rtems_id'
../../cpukit/../../../sis/lib/include/rtems/rtems/eventflag.h:405,
                 from
../../cpukit/../../../sis/lib/include/rtems/rtems/eventflag.inl:69:
error: expected ')' before 'id'
../../cpukit/../../../sis/lib/include/rtems/rtems/eventflag.inl:89:
gmake[5]: *** [src/librtems_a-eventflag.o] Error 1
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory
`/home/andrei/Src/rtems-20121015-2250-build/sparc-rtems4.10/c/sis/cpukit'
gmake[3]: *** [all] Error 2
gmake[3]: Leaving directory
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/andrei/Src/rtems-20121015-2250-build/sparc-rtems4.10/c/sis'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/home/andrei/Src/rtems-20121015-2250-build/sparc-rtems4.10/c'
make: *** [all-recursive] Error 1
