[PATCH 3/3] libblock: Use transient event
Wed Oct 24 16:11:33 UTC 2012
 cpukit/libblock/src/bdbuf.c |   21 ++++++++++++++++-----
 1 files changed, 16 insertions(+), 5 deletions(-)
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index 3f4915b..ffe9f7d 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -181,12 +181,12 @@ typedef struct rtems_bdbuf_cache
 #define RTEMS_BLKDEV_FATAL_BDBUF_STATE_1       RTEMS_BLKDEV_FATAL_ERROR(29)
 #define RTEMS_BLKDEV_FATAL_BDBUF_STATE_2       RTEMS_BLKDEV_FATAL_ERROR(30)
 #define RTEMS_BLKDEV_FATAL_BDBUF_RA_WAKE_UP    RTEMS_BLKDEV_FATAL_ERROR(31)
+#define RTEMS_BLKDEV_FATAL_BDBUF_WAIT_TRANS_EVNT RTEMS_BLKDEV_FATAL_ERROR(32)
  * The events used in this code. These should be system events rather than
  * application events.
-#define RTEMS_BDBUF_TRANSFER_SYNC  RTEMS_EVENT_1
 #define RTEMS_BDBUF_SWAPOUT_SYNC   RTEMS_EVENT_2
 #define RTEMS_BDBUF_READ_AHEAD_WAKE_UP RTEMS_EVENT_1
@@ -1549,6 +1549,17 @@ rtems_bdbuf_wait_for_event (rtems_event_set event)
 static void
+rtems_bdbuf_wait_for_transient_event (void)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  sc = rtems_transient_event_receive ( RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  if (sc != RTEMS_SUCCESSFUL)
+    rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_WAIT_TRANS_EVNT);
+static void
 rtems_bdbuf_wait_for_access (rtems_bdbuf_buffer *bd)
   while (true)
@@ -1867,7 +1878,7 @@ rtems_bdbuf_transfer_done (void* arg, rtems_status_code status)
   req->status = status;
-  rtems_event_send (req->io_task, RTEMS_BDBUF_TRANSFER_SYNC);
+  rtems_transient_event_send (req->io_task);
 static rtems_status_code
@@ -1888,7 +1899,7 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device    *dd,
   if (result == 0)
-    rtems_bdbuf_wait_for_event (RTEMS_BDBUF_TRANSFER_SYNC);
+    rtems_bdbuf_wait_for_transient_event ();
     sc = req->status;
   else
@@ -2268,7 +2279,7 @@ rtems_bdbuf_syncdev (rtems_disk_device *dd)
   rtems_bdbuf_wake_swapper ();
   rtems_bdbuf_unlock_cache ();
   rtems_bdbuf_unlock_sync ();
   return RTEMS_SUCCESSFUL;
@@ -2617,7 +2628,7 @@ rtems_bdbuf_swapout_processing (unsigned long                 timer_delta,
     bdbuf_cache.sync_requester = 0;
     if (sync_requester)
-      rtems_event_send (sync_requester, RTEMS_BDBUF_TRANSFER_SYNC);
+      rtems_transient_event_send (sync_requester);
   return transfered_buffers;
1.7.7
