[rtems-libbsd commit] Added -g option to Makefile.
Fri Oct 26 08:30:44 UTC 2012
Ralf Corsepius wrote:
> b) the problem with this change is it hard-coding compiler flags - This
> is a classical newbie mistake.
I see nothing wrong with hard-coding here because it will be thrown away
then the code is moved into the main repo. The focus of the project is
the TCP stack and not a build system.
> c) My opinion about Joel's Makefile fragment system is known.
> The most polite formulation of my opinion on it is: Don't use it.
Then may I suggest you ignore it. It is not harming anyone and it is
letting them get the project done.
