[PATCH 1/2] libblock: Block device transfer request API change
Wed Oct 31 12:57:52 UTC 2012
Add and use rtems_blkdev_request_done().  Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
 c/src/lib/libbsp/arm/gp32/smc/smc.c                |    4 +-
 .../libbsp/lm32/shared/milkymist_memcard/memcard.c |    6 +-
 c/src/libchip/i2c/spi-sd-card.c                    |   12 ++--
 c/src/libchip/ide/ata.c                            |    3 +-
 c/src/libchip/ide/ata_internal.h                   |    4 +-
 cpukit/libblock/include/rtems/blkdev.h             |   66 ++++++++++++-----
 cpukit/libblock/src/bdbuf.c                        |   25 ++----
 cpukit/libblock/src/flashdisk.c                    |    6 +-
 cpukit/libblock/src/nvdisk.c                       |    8 +-
 cpukit/libblock/src/ramdisk-driver.c               |    6 +-
 testsuites/libtests/block05/init.c                 |    2 +-
 testsuites/libtests/block06/init.c                 |    9 +-
 testsuites/libtests/block08/test_disk.c            |   27 ++++---
 testsuites/libtests/block09/init.c                 |   79 ++++++++++----------
 testsuites/libtests/block10/init.c                 |    2 +-
 testsuites/libtests/block12/init.c                 |    2 +-
 testsuites/libtests/block13/init.c                 |    2 +-
 testsuites/libtests/block14/init.c                 |    2 +-
 testsuites/libtests/block15/init.c                 |    2 +-
 19 files changed, 146 insertions(+), 121 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gp32/smc/smc.c b/c/src/lib/libbsp/arm/gp32/smc/smc.c
index b9419de..9cf460b 100644
--- a/c/src/lib/libbsp/arm/gp32/smc/smc.c
+++ b/c/src/lib/libbsp/arm/gp32/smc/smc.c
@@ -544,7 +544,7 @@ int sm_ECCEncode(const uint8_t * p_buf, uint8_t * p_ecc)
 static int smc_write(rtems_blkdev_request *req)
-	req->req_done(req->done_arg, RTEMS_SUCCESSFUL);
+	rtems_blkdev_request_done(req, RTEMS_SUCCESSFUL);
 	return 0;
@@ -573,7 +573,7 @@ smc_read(rtems_blkdev_request *req)
 	smc_read_page(sg->block,sg->buffer);
         remains -= count;
     return 0;
diff --git a/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c b/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
index 747903d..93c7a1d 100644
--- a/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
+++ b/c/src/lib/libbsp/lm32/shared/milkymist_memcard/memcard.c
@@ -197,14 +197,16 @@ static int memcard_disk_block_read(rtems_blkdev_request *r)
       return -RTEMS_IO_ERROR;
-  r->req_done(r->done_arg, RTEMS_SUCCESSFUL);
+  rtems_blkdev_request_done(r, RTEMS_SUCCESSFUL);
   return 0;
 static int memcard_disk_block_write(rtems_blkdev_request *r)
-  return -RTEMS_IO_ERROR;
+  rtems_blkdev_request_done(r, RTEMS_IO_ERROR);
+  return 0;
 static rtems_status_code memcard_init(void)
diff --git a/c/src/libchip/i2c/spi-sd-card.c b/c/src/libchip/i2c/spi-sd-card.c
index bdd6fe0..d85c177 100644
--- a/c/src/libchip/i2c/spi-sd-card.c
+++ b/c/src/libchip/i2c/spi-sd-card.c
@@ -1117,7 +1117,7 @@ static int sd_card_disk_block_read( sd_card_driver_entry *e, rtems_blkdev_reques
 	RTEMS_CHECK_SC_RV( sc, "Stop");
 	/* Done */
-	r->req_done( r->done_arg, RTEMS_SUCCESSFUL);
+	rtems_blkdev_request_done( r, RTEMS_SUCCESSFUL);
 	return 0;
@@ -1132,9 +1132,9 @@ sd_card_disk_block_read_cleanup:
 	sd_card_stop( e);
 	/* Done */
-	r->req_done( r->done_arg, RTEMS_IO_ERROR);
+	rtems_blkdev_request_done( r, RTEMS_IO_ERROR);
-	return rv;
+	return 0;
 static int sd_card_disk_block_write( sd_card_driver_entry *e, rtems_blkdev_request *r)
@@ -1206,7 +1206,7 @@ static int sd_card_disk_block_write( sd_card_driver_entry *e, rtems_blkdev_reque
 	/* Done */
 	return 0;
@@ -1225,9 +1225,9 @@ sd_card_disk_block_write_cleanup:
 	sd_card_stop( e);
 	/* Done */
-	return rv;
+	return 0;
 static int sd_card_disk_ioctl( rtems_disk_device *dd, uint32_t req, void *arg)
diff --git a/c/src/libchip/ide/ata.c b/c/src/libchip/ide/ata.c
index 18d8d14..1e25003 100644
--- a/c/src/libchip/ide/ata.c
+++ b/c/src/libchip/ide/ata.c
@@ -185,7 +185,8 @@ ata_io_data_request(dev_t device, rtems_blkdev_request *req)
     areq = malloc(sizeof(ata_req_t));
     if (areq == NULL)
-        return RTEMS_NO_MEMORY;
+        rtems_blkdev_request_done(req, RTEMS_NO_MEMORY);
+        return RTEMS_SUCCESSFUL;
     areq->breq = req;
diff --git a/c/src/libchip/ide/ata_internal.h b/c/src/libchip/ide/ata_internal.h
index 3eea2d1..32c9422 100644
--- a/c/src/libchip/ide/ata_internal.h
+++ b/c/src/libchip/ide/ata_internal.h
@@ -218,8 +218,8 @@ typedef struct ata_req_s {
 /* call callback provided by block device request if it is defined */
 #define ATA_EXEC_CALLBACK(areq, status) \
     do {\
-        if (((areq)->breq != NULL) && ((areq)->breq->req_done != NULL)) \
-            (areq)->breq->req_done((areq)->breq->done_arg, status); \
+        if ((areq)->breq != NULL) \
+            rtems_blkdev_request_done((areq)->breq, status); \
     } while (0)
 /* ATA RTEMS driver events types */
diff --git a/cpukit/libblock/include/rtems/blkdev.h b/cpukit/libblock/include/rtems/blkdev.h
index ccc8981..7f83a26 100644
--- a/cpukit/libblock/include/rtems/blkdev.h
+++ b/cpukit/libblock/include/rtems/blkdev.h
@@ -53,18 +53,15 @@ typedef enum rtems_blkdev_request_op {
   RTEMS_BLKDEV_REQ_SYNC        /**< Sync any data with the media. */
 } rtems_blkdev_request_op;
+struct rtems_blkdev_request;
  * @brief Block device request done callback function type.
- * The first parameter @a arg must be the argument provided by the block device
- * request structure @ref rtems_blkdev_request.
- * The second parameter @a status should contain the status of the operation:
- *  - @c RTEMS_SUCCESSFUL Operation was successful.
- *  - @c RTEMS_IO_ERROR Some sort of input or output error.
- *  - @c RTEMS_UNSATISFIED Media no more present.
-typedef void (*rtems_blkdev_request_cb)(void *arg, rtems_status_code status);
+typedef void (*rtems_blkdev_request_cb)(
+  struct rtems_blkdev_request *req,
+  rtems_status_code status
  * Block device scatter or gather buffer structure.
@@ -92,15 +89,16 @@ typedef struct rtems_blkdev_sg_buffer {
 } rtems_blkdev_sg_buffer;
- * The block device request structure is used to read or write a number of
- * blocks from or to the device.
+ * @brief The block device transfer request is used to read or write a number
+ * of blocks from or to the device.
+ * Transfer requests are issued to the disk device driver with the
+ * @ref RTEMS_BLKIO_REQUEST IO control.  The transfer request completion status
+ * must be signalled with rtems_blkdev_request_done().  This function must be
+ * called exactly once per request.  The return value of the IO control will be
+ * ignored for transfer requests.
- * TODO: The use of these req blocks is not a great design. The req is a
- *       struct with a single 'bufs' declared in the req struct and the
- *       others are added in the outer level struct. This relies on the
- *       structs joining as a single array and that assumes the compiler
- *       packs the structs. Why not just place on a list ? The BD has a
- *       node that can be used.
+ * @see rtems_blkdev_create().
 typedef struct rtems_blkdev_request {
@@ -111,7 +109,7 @@ typedef struct rtems_blkdev_request {
    * Request done callback function.
-  rtems_blkdev_request_cb req_done;
+  rtems_blkdev_request_cb done;
    * Argument to be passed to callback function.
@@ -133,6 +131,15 @@ typedef struct rtems_blkdev_request {
   rtems_id io_task;
+   * TODO: The use of these req blocks is not a great design. The req is a
+   *       struct with a single 'bufs' declared in the req struct and the
+   *       others are added in the outer level struct. This relies on the
+   *       structs joining as a single array and that assumes the compiler
+   *       packs the structs. Why not just place on a list ? The BD has a
+   *       node that can be used.
    * List of scatter or gather buffers.
@@ -140,6 +147,25 @@ typedef struct rtems_blkdev_request {
 } rtems_blkdev_request;
+ * @brief Signals transfer request completion status.
+ * This function must be called exactly once per request.
+ * @param[in,out] req The transfer request.
+ * @param[in] status The status of the operation should be
+ *  - @c RTEMS_SUCCESSFUL, if the operation was successful,
+ *  - @c RTEMS_IO_ERROR, if some sort of input or output error occured, or
+ *  - @c RTEMS_UNSATISFIED, if media is no more present.
+static inline void rtems_blkdev_request_done(
+  rtems_blkdev_request *req,
+  (*req->done)(req, status);
  * The start block in a request.
  * Only valid if the driver has returned the @ref RTEMS_BLKIO_CAPABILITIES of
@@ -341,6 +367,8 @@ extern const rtems_driver_address_table rtems_blkdev_generic_ops;
  * @retval RTEMS_INVALID_NUMBER Block size or block count is not positive.
  * @retval RTEMS_NO_MEMORY Not enough memory.
  * @retval RTEMS_UNSATISFIED Cannot create generic device node.
+ * @see rtems_blkdev_create_partition() and rtems_blkdev_request.
 rtems_status_code rtems_blkdev_create(
   const char *device,
@@ -370,6 +398,8 @@ rtems_status_code rtems_blkdev_create(
  * @retval RTEMS_INVALID_NUMBER Block begin or block count is invalid.
 rtems_status_code rtems_blkdev_create_partition(
   const char *partition,
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index 81f641e..8fb3848 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -1871,10 +1871,8 @@ rtems_bdbuf_get (rtems_disk_device   *dd,
  * @param status I/O completion status
 static void
-rtems_bdbuf_transfer_done (void* arg, rtems_status_code status)
+rtems_bdbuf_transfer_done (rtems_blkdev_request* req, rtems_status_code status)
-  rtems_blkdev_request* req = (rtems_blkdev_request*) arg;
   req->status = status;
   rtems_event_transient_send (req->io_task);
@@ -1886,7 +1884,6 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device    *dd,
                                       bool                  cache_locked)
   rtems_status_code sc = RTEMS_SUCCESSFUL;
-  int result = 0;
   uint32_t transfer_index = 0;
   bool wake_transfer_waiters = false;
   bool wake_buffer_waiters = false;
@@ -1894,15 +1891,12 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device    *dd,
   if (cache_locked)
     rtems_bdbuf_unlock_cache ();
-  result = dd->ioctl (dd->phys_dev, RTEMS_BLKIO_REQUEST, req);
+  /* The return value will be ignored for transfer requests */
+  dd->ioctl (dd->phys_dev, RTEMS_BLKIO_REQUEST, req);
-  if (result == 0)
-    rtems_bdbuf_wait_for_transient_event ();
-    sc = req->status;
-  else
-    sc = RTEMS_IO_ERROR;
+  /* Wait for transfer request completion */
+  rtems_bdbuf_wait_for_transient_event ();
+  sc = req->status;
   rtems_bdbuf_lock_cache ();
@@ -1977,10 +1971,8 @@ rtems_bdbuf_execute_read_request (rtems_disk_device  *dd,
                      sizeof (rtems_blkdev_sg_buffer) * transfer_count);
   req->req = RTEMS_BLKDEV_REQ_READ;
-  req->req_done = rtems_bdbuf_transfer_done;
-  req->done_arg = req;
+  req->done = rtems_bdbuf_transfer_done;
   req->io_task = rtems_task_self ();
-  req->status = RTEMS_RESOURCE_IN_USE;
   req->bufnum = 0;
   rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_TRANSFER);
@@ -2655,8 +2647,7 @@ rtems_bdbuf_swapout_writereq_alloc (void)
     rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_SO_NOMEM);
   write_req->req = RTEMS_BLKDEV_REQ_WRITE;
-  write_req->req_done = rtems_bdbuf_transfer_done;
-  write_req->done_arg = write_req;
+  write_req->done = rtems_bdbuf_transfer_done;
   write_req->io_task = rtems_task_self ();
   return write_req;
diff --git a/cpukit/libblock/src/flashdisk.c b/cpukit/libblock/src/flashdisk.c
index ec1ace2..a9e56c9 100644
--- a/cpukit/libblock/src/flashdisk.c
+++ b/cpukit/libblock/src/flashdisk.c
@@ -2086,8 +2086,7 @@ rtems_fdisk_read (rtems_flashdisk* fd, rtems_blkdev_request* req)
-  req->status = ret ? RTEMS_IO_ERROR : RTEMS_SUCCESSFUL;
-  req->req_done (req->done_arg, req->status);
+  rtems_blkdev_request_done (req, ret ? RTEMS_IO_ERROR : RTEMS_SUCCESSFUL);
   return 0;
@@ -2122,8 +2121,7 @@ rtems_fdisk_write (rtems_flashdisk* fd, rtems_blkdev_request* req)
   return 0;
diff --git a/cpukit/libblock/src/nvdisk.c b/cpukit/libblock/src/nvdisk.c
index c90f319..127291d 100644
--- a/cpukit/libblock/src/nvdisk.c
+++ b/cpukit/libblock/src/nvdisk.c
@@ -597,10 +597,9 @@ rtems_nvdisk_read (rtems_nvdisk* nvd, rtems_blkdev_request* req)
-  return ret;
+  return 0;
@@ -637,8 +636,7 @@ rtems_nvdisk_write (rtems_nvdisk* nvd, rtems_blkdev_request* req)
   return 0;
diff --git a/cpukit/libblock/src/ramdisk-driver.c b/cpukit/libblock/src/ramdisk-driver.c
index fb4a80f..881b7df 100644
--- a/cpukit/libblock/src/ramdisk-driver.c
+++ b/cpukit/libblock/src/ramdisk-driver.c
@@ -67,8 +67,7 @@ ramdisk_read(struct ramdisk *rd, rtems_blkdev_request *req)
 #endif
         memcpy(sg->buffer, from + (sg->block * rd->block_size), sg->length);
-    req->status = RTEMS_SUCCESSFUL;
+    rtems_blkdev_request_done (req, RTEMS_SUCCESSFUL);
     return 0;
@@ -92,8 +91,7 @@ ramdisk_write(struct ramdisk *rd, rtems_blkdev_request *req)
 #endif
         memcpy(to + (sg->block * rd->block_size), sg->buffer, sg->length);
     return 0;
diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
index dd5d646..0a56ec6 100644
--- a/testsuites/libtests/block05/init.c
+++ b/testsuites/libtests/block05/init.c
@@ -379,7 +379,7 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
     switch (r->req) {
       case RTEMS_BLKDEV_REQ_READ:
       case RTEMS_BLKDEV_REQ_WRITE:
         return 0;
       default:
         errno = EINVAL;
diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
index e007a5e..ff309b1 100644
--- a/testsuites/libtests/block06/init.c
+++ b/testsuites/libtests/block06/init.c
@@ -488,7 +488,7 @@ bdbuf_disk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
             if (!bdbuf_disk_ioctl_process (bdd, r))
-              errno = EIO;
             else
               rtems_blkdev_sg_buffer* sg = r->bufs;
@@ -511,15 +511,16 @@ bdbuf_disk_ioctl (rtems_disk_device *dd, uint32_t req, void* argp)
                 remains -= length;
-              r->req_done (r->done_arg, RTEMS_SUCCESSFUL);
+              rtems_blkdev_request_done (r, RTEMS_SUCCESSFUL);
             bdbuf_disk_ioctl_leave (bdd, r->bufnum);
             break;
-              errno = EIO;
+            else
             break;
diff --git a/testsuites/libtests/block08/test_disk.c b/testsuites/libtests/block08/test_disk.c
index 3040ab3..f743c00 100644
--- a/testsuites/libtests/block08/test_disk.c
+++ b/testsuites/libtests/block08/test_disk.c
@@ -32,18 +32,20 @@ static Objects_Id testq_id = OBJECTS_ID_NONE;
 static int
 test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
-    rtems_status_code rc;
-    bdbuf_test_msg    msg;
-    size_t            msg_size;
+    rtems_status_code     rc;
+    bdbuf_test_msg        msg;
+    size_t                msg_size;
+    rtems_blkdev_request *r;
     switch (req)
         case RTEMS_BLKIO_REQUEST:
-            rtems_blkdev_request   *r = argp;
             rtems_blkdev_sg_buffer *sg;
             unsigned int            i;
+            r = argp;
             printk("DISK_DRV: %s ",
                    r->req == RTEMS_BLKDEV_REQ_READ ? "R" :
                    r->req == RTEMS_BLKDEV_REQ_WRITE ? "W" : "?");
@@ -71,7 +73,8 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
     if (rc != RTEMS_SUCCESSFUL)
         printf("Error while sending a message to Test task: %u\n", rc);
-        return -1;
+        return 0;
     /* Wait for a reply from the test task */
@@ -81,27 +84,27 @@ test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *argp)
         printf("Error while reading a message from Test task: %u\n", rc);
-        return rc;
+        return 0;
     if (msg.type != BDBUF_TEST_MSG_TYPE_DRIVER_REPLY)
         printf("Unexpected message comes to test disk driver: %d\n",
                msg.type);
-        return -1;
+        return 0;
     if (msg.val.driver_reply.ret_val != 0)
-        errno = msg.val.driver_reply.ret_errno;
     else
-        rtems_blkdev_request *r = (rtems_blkdev_request *)argp;
-        r->req_done(r->done_arg, msg.val.driver_reply.res_status);
+        rtems_blkdev_request_done(r, msg.val.driver_reply.res_status);
-    return msg.val.driver_reply.ret_val;
+    return 0;
 rtems_device_driver
diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
index d29d6ac..e17819f 100644
--- a/testsuites/libtests/block09/init.c
+++ b/testsuites/libtests/block09/init.c
@@ -64,47 +64,50 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
       rtems_blkdev_sg_buffer *sg = &r->bufs [i];
       char *buf = sg->buffer;
-      if (sg->length != 1) {
-        return -1;
-      switch (r->req) {
-        case RTEMS_BLKDEV_REQ_READ:
-          switch (sg->block) {
-            case BLOCK_READ_IO_ERROR:
-              break;
-            case BLOCK_READ_UNSATISFIED:
-              sc = RTEMS_UNSATISFIED;
-              break;
-            case BLOCK_READ_SUCCESSFUL:
-            case BLOCK_WRITE_IO_ERROR:
-              *buf = disk_data [sg->block];
-              break;
-            default:
-              return -1;
-          break;
-        case RTEMS_BLKDEV_REQ_WRITE:
-              disk_data [sg->block] = *buf;
-              break;
-              break;
-            default:
-              return -1;
-          break;
-        default:
-          return -1;
+      if (sg->length == 1) {
+        switch (r->req) {
+          case RTEMS_BLKDEV_REQ_READ:
+            switch (sg->block) {
+              case BLOCK_READ_IO_ERROR:
+                sc = RTEMS_IO_ERROR;
+                break;
+              case BLOCK_READ_UNSATISFIED:
+                sc = RTEMS_UNSATISFIED;
+                break;
+              case BLOCK_READ_SUCCESSFUL:
+              case BLOCK_WRITE_IO_ERROR:
+                *buf = disk_data [sg->block];
+                break;
+              default:
+                break;
+            break;
+          case RTEMS_BLKDEV_REQ_WRITE:
+                disk_data [sg->block] = *buf;
+                break;
+                break;
+              default:
+                break;
+            break;
+          default:
+            break;
+      } else {
-    r->req_done(r->done_arg, sc);
+    rtems_blkdev_request_done(r, sc);
     return 0;
   } else {
diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
index 37b757a..fe8c21b 100644
--- a/testsuites/libtests/block10/init.c
+++ b/testsuites/libtests/block10/init.c
@@ -105,7 +105,7 @@ static int disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
       set_task_prio(RTEMS_SELF, PRIORITY_SWAPOUT);
     return 0;
   } else {
diff --git a/testsuites/libtests/block12/init.c b/testsuites/libtests/block12/init.c
index 8182cd6..9931c0b 100644
--- a/testsuites/libtests/block12/init.c
+++ b/testsuites/libtests/block12/init.c
@@ -55,7 +55,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
       ++block_access_counts [block];
-    breq->req_done(breq->done_arg, RTEMS_SUCCESSFUL);
+    rtems_blkdev_request_done(breq, RTEMS_SUCCESSFUL);
   } else {
     errno = EINVAL;
     rv = -1;
diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
index 267e4ec..d5d2593 100644
--- a/testsuites/libtests/block13/init.c
+++ b/testsuites/libtests/block13/init.c
@@ -126,7 +126,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
-    (*breq->req_done)(breq->done_arg, RTEMS_SUCCESSFUL);
   } else {
     errno = EINVAL;
     rv = -1;
diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
index b95b86d..1c4f1c7 100644
--- a/testsuites/libtests/block14/init.c
+++ b/testsuites/libtests/block14/init.c
@@ -105,7 +105,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
-    (*breq->req_done)(breq->done_arg, sc);
+    rtems_blkdev_request_done(breq, sc);
   } else {
     errno = EINVAL;
     rv = -1;
diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
index e6de9c3..a6e4937 100644
--- a/testsuites/libtests/block15/init.c
+++ b/testsuites/libtests/block15/init.c
@@ -84,7 +84,7 @@ static int test_disk_ioctl(rtems_disk_device *dd, uint32_t req, void *arg)
   } else if (req == RTEMS_BLKIO_CAPABILITIES) {
     *(uint32_t *) arg = RTEMS_BLKDEV_CAP_MULTISECTOR_CONT;
   } else {
1.7.7
