[PATCH 2/6] score: Change _Heap_Extend() API
Sebastian Huber
Mon Oct 15 13:13:53 UTC 2012
The _Heap_Extend() has now the same signature as _Heap_Initialize().
The 4th parameter is ignored (page size in _Heap_Initialize()).
Add Heap_Area and Heap_Initialization_or_extend_handler.
Add and test _Heap_No_extend().
This helps to do a table based heap initialization and extension.
Create a table of Heap_Area elements and iterate through it. Set the
handler to _Heap_Initialize() in the first iteration and then to
_Heap_Extend().
cpukit/rtems/src/regionextend.c | 7 ++--
cpukit/score/Makefile.am | 2 +-
cpukit/score/include/rtems/score/heap.h | 59 +++++++++++++++++++++++++++---
cpukit/score/src/heapextend.c | 15 +++-----
cpukit/score/src/heapnoextend.c | 37 +++++++++++++++++++
cpukit/score/src/pheapextend.c | 7 ++--
testsuites/libtests/malloctest/init.c | 7 ++++
7 files changed, 110 insertions(+), 24 deletions(-)
create mode 100644 cpukit/score/src/heapnoextend.c
diff --git a/cpukit/rtems/src/regionextend.c b/cpukit/rtems/src/regionextend.c
index cf4489e..205534b 100644
--- a/cpukit/rtems/src/regionextend.c
+++ b/cpukit/rtems/src/regionextend.c
@@ -46,7 +46,6 @@ rtems_status_code rtems_region_extend(
uintptr_t amount_extended;
- bool extend_ok;
Objects_Locations location;
rtems_status_code return_status;
Region_Control *the_region;
@@ -61,14 +60,14 @@ rtems_status_code rtems_region_extend(
case OBJECTS_LOCAL:
- extend_ok = _Heap_Extend(
+ amount_extended = _Heap_Extend(
&the_region->Memory,
starting_address,
length,
- &amount_extended
+ 0
- if ( extend_ok ) {
+ if ( amount_extended > 0 ) {
the_region->length += amount_extended;
the_region->maximum_segment_size += amount_extended;
return_status = RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 6f9f94f..d259acb 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -178,7 +178,7 @@ endif
libscore_a_SOURCES += src/heap.c src/heapallocate.c src/heapextend.c \
src/heapfree.c src/heapsizeofuserarea.c src/heapwalk.c src/heapgetinfo.c \
src/heapgetfreeinfo.c src/heapresizeblock.c src/heapiterate.c \
- src/heapgreedy.c
+ src/heapgreedy.c src/heapnoextend.c
## OBJECT_C_FILES
libscore_a_SOURCES += src/objectallocate.c src/objectclose.c \
diff --git a/cpukit/score/include/rtems/score/heap.h b/cpukit/score/include/rtems/score/heap.h
index 8e6220c..964386a 100644
--- a/cpukit/score/include/rtems/score/heap.h
+++ b/cpukit/score/include/rtems/score/heap.h
@@ -388,6 +388,33 @@ typedef enum {
} Heap_Resize_status;
+ * @brief Heap area structure for table based heap initialization and
+ * extension.
+ * @see Heap_Initialization_or_extend_handler.
+typedef struct {
+ void *begin;
+ uintptr_t size;
+} Heap_Area;
+ * @brief Heap initialization and extend handler type.
+ * This helps to do a table based heap initialization and extension. Create a
+ * table of Heap_Area elements and iterate through it. Set the handler to
+ * _Heap_Initialize() in the first iteration and then to _Heap_Extend().
+ * @see Heap_Area, _Heap_Initialize(), _Heap_Extend(), or _Heap_No_extend().
+typedef uintptr_t (*Heap_Initialization_or_extend_handler)(
+ Heap_Control *heap,
+ void *area_begin,
+ uintptr_t area_size,
+ uintptr_t page_size_or_unused
* @brief Gets the first and last block for the heap area with begin
* @a heap_area_begin and size @a heap_area_size.
@@ -419,6 +446,8 @@ bool _Heap_Get_first_and_last_block(
* @c CPU_ALIGNMENT, it is aligned up to the nearest @c CPU_ALIGNMENT boundary.
* Returns the maximum memory available, or zero in case of failure.
uintptr_t _Heap_Initialize(
Heap_Control *heap,
@@ -431,22 +460,40 @@ uintptr_t _Heap_Initialize(
* @brief Extends the memory available for the heap @a heap using the memory
* area starting at @a area_begin of size @a area_size bytes.
- * The extended space available for allocation will be returned in
- * @a amount_extended. This pointer may be @c NULL.
* There are no alignment requirements. The memory area must be big enough to
* contain some maintainance blocks. It must not overlap parts of the current
* heap areas. Disconnected subordinate heap areas will lead to used blocks
* which cover the gaps. Extending with an inappropriate memory area will
* corrupt the heap.
- * Returns @c true in case of success, and @c false otherwise.
+ * The unused fourth parameter is provided to have the same signature as
+ * _Heap_Initialize().
+ * Returns the extended space available for allocation, or zero in case of failure.
-bool _Heap_Extend(
+uintptr_t _Heap_Extend(
Heap_Control *heap,
void *area_begin,
- uintptr_t *amount_extended
+ uintptr_t unused
+ * @brief This function returns always zero.
+ * This function only returns zero and does nothing else.
+ * Returns always zero.
+uintptr_t _Heap_No_extend(
+ Heap_Control *unused_0,
+ void *unused_1,
+ uintptr_t unused_2,
+ uintptr_t unused_3
diff --git a/cpukit/score/src/heapextend.c b/cpukit/score/src/heapextend.c
index 9d2d587..f93d71f 100644
--- a/cpukit/score/src/heapextend.c
+++ b/cpukit/score/src/heapextend.c
@@ -108,11 +108,11 @@ static void _Heap_Link_above(
last_block->size_and_flag |= HEAP_PREV_BLOCK_USED;
-bool _Heap_Extend(
Heap_Control *heap,
void *extend_area_begin_ptr,
uintptr_t extend_area_size,
- uintptr_t *extended_size_ptr
+ uintptr_t unused __attribute__((unused))
Heap_Statistics *const stats = &heap->stats;
@@ -134,7 +134,7 @@ bool _Heap_Extend(
bool extend_area_ok = false;
if ( extend_area_end < extend_area_begin ) {
- return false;
+ return 0;
extend_area_ok = _Heap_Get_first_and_last_block(
@@ -147,7 +147,7 @@ bool _Heap_Extend(
if (!extend_area_ok ) {
/* For simplicity we reject extend areas that are too small */
- return false;
+ return 0;
do {
@@ -160,7 +160,7 @@ bool _Heap_Extend(
if (
sub_area_end > extend_area_begin && extend_area_end > sub_area_begin
- return false;
+ return 0;
if ( extend_area_end == sub_area_begin ) {
@@ -234,8 +234,5 @@ bool _Heap_Extend(
/* Statistics */
stats->size += extended_size;
- if ( extended_size_ptr != NULL )
- *extended_size_ptr = extended_size;
- return true;
+ return extended_size;
diff --git a/cpukit/score/src/heapnoextend.c b/cpukit/score/src/heapnoextend.c
new file mode 100644
index 0000000..1652f59
--- /dev/null
+++ b/cpukit/score/src/heapnoextend.c
@@ -0,0 +1,37 @@
+ * @file
+ * @ingroup ScoreHeap
+ * @brief Heap Handler implementation.
+ * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Obere Lagerstr. 30
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/score/heap.h>
+ Heap_Control *unused_0 __attribute__((unused)),
+ void *unused_1 __attribute__((unused)),
+ uintptr_t unused_2 __attribute__((unused)),
+ uintptr_t unused_3 __attribute__((unused))
+ return 0;
diff --git a/cpukit/score/src/pheapextend.c b/cpukit/score/src/pheapextend.c
index be23c70..5f1a4df 100644
--- a/cpukit/score/src/pheapextend.c
+++ b/cpukit/score/src/pheapextend.c
@@ -28,12 +28,11 @@ bool _Protected_heap_Extend(
uintptr_t size
- bool extend_ok;
_RTEMS_Lock_allocator();
- extend_ok = _Heap_Extend(the_heap, starting_address, size, &amount_extended);
+ amount_extended = _Heap_Extend( the_heap, starting_address, size, 0 );
_RTEMS_Unlock_allocator();
- return extend_ok;
+ return amount_extended != 0;
diff --git a/testsuites/libtests/malloctest/init.c b/testsuites/libtests/malloctest/init.c
index a93edc4..c2080e8 100644
--- a/testsuites/libtests/malloctest/init.c
+++ b/testsuites/libtests/malloctest/init.c
@@ -984,6 +984,12 @@ static void test_heap_extend(void)
test_heap_assert( ret, true );
+static void test_heap_no_extend(void)
+ uintptr_t extended_space = _Heap_No_extend( NULL, 0, 0, 0 );
+ rtems_test_assert( extended_space == 0 );
static void test_heap_info(void)
size_t s1, s2;
@@ -1142,6 +1148,7 @@ rtems_task Init(
test_realloc();
test_heap_cases_1();
test_heap_extend();
+ test_heap_no_extend();
test_heap_info();
test_protected_heap_info();
test_rtems_heap_allocate_aligned_with_boundary();
1.7.7
