[PATCH 3/3] libblock: Use beacon instead of events
    Sebastian Huber
    Tue Oct 16 14:45:29 UTC 2012
The usage of events for transfer and synchronization requests is bad
because this may interfere with the event usage of application tasks.
Typical errors result in stack corruption.
 cpukit/libblock/src/bdbuf.c |   27 ++++++++++++++++++++++-----
 1 files changed, 22 insertions(+), 5 deletions(-)
diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
index 3f4915b..70c7ba0 100644
--- a/cpukit/libblock/src/bdbuf.c
+++ b/cpukit/libblock/src/bdbuf.c
@@ -181,12 +181,13 @@ typedef struct rtems_bdbuf_cache
 #define RTEMS_BLKDEV_FATAL_BDBUF_STATE_1       RTEMS_BLKDEV_FATAL_ERROR(29)
 #define RTEMS_BLKDEV_FATAL_BDBUF_STATE_2       RTEMS_BLKDEV_FATAL_ERROR(30)
 #define RTEMS_BLKDEV_FATAL_BDBUF_RA_WAKE_UP    RTEMS_BLKDEV_FATAL_ERROR(31)
+#define RTEMS_BLKDEV_FATAL_BDBUF_WATCH_BEACON  RTEMS_BLKDEV_FATAL_ERROR(32)
+#define RTEMS_BLKDEV_FATAL_BDBUF_CLEAR_BEACON  RTEMS_BLKDEV_FATAL_ERROR(33)
  * The events used in this code. These should be system events rather than
  * application events.
-#define RTEMS_BDBUF_TRANSFER_SYNC  RTEMS_EVENT_1
 #define RTEMS_BDBUF_SWAPOUT_SYNC   RTEMS_EVENT_2
 #define RTEMS_BDBUF_READ_AHEAD_WAKE_UP RTEMS_EVENT_1
@@ -1549,6 +1550,22 @@ rtems_bdbuf_wait_for_event (rtems_event_set event)
 static void
+rtems_bdbuf_wait_for_beacon (rtems_id *task_id)
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  sc = rtems_beacon_watch (RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  if (sc != RTEMS_SUCCESSFUL)
+    rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_WATCH_BEACON);
+  *task_id = 0;
+  sc = rtems_beacon_clear ();
+    rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_CLEAR_BEACON);
+static void
 rtems_bdbuf_wait_for_access (rtems_bdbuf_buffer *bd)
   while (true)
@@ -1867,7 +1884,7 @@ rtems_bdbuf_transfer_done (void* arg, rtems_status_code status)
   req->status = status;
-  rtems_event_send (req->io_task, RTEMS_BDBUF_TRANSFER_SYNC);
+  rtems_beacon_signal (req->io_task);
 static rtems_status_code
@@ -1888,7 +1905,7 @@ rtems_bdbuf_execute_transfer_request (rtems_disk_device    *dd,
   if (result == 0)
-    rtems_bdbuf_wait_for_event (RTEMS_BDBUF_TRANSFER_SYNC);
+    rtems_bdbuf_wait_for_beacon (&req->io_task);
     sc = req->status;
   else
@@ -2268,7 +2285,7 @@ rtems_bdbuf_syncdev (rtems_disk_device *dd)
   rtems_bdbuf_wake_swapper ();
   rtems_bdbuf_unlock_cache ();
+  rtems_bdbuf_wait_for_beacon (&bdbuf_cache.sync_requester);
   rtems_bdbuf_unlock_sync ();
   return RTEMS_SUCCESSFUL;
@@ -2617,7 +2634,7 @@ rtems_bdbuf_swapout_processing (unsigned long                 timer_delta,
     bdbuf_cache.sync_requester = 0;
     if (sync_requester)
-      rtems_event_send (sync_requester, RTEMS_BDBUF_TRANSFER_SYNC);
+      rtems_beacon_signal (sync_requester);
   return transfered_buffers;
1.7.7
