[PATCH 2/3] score: Add system events
Wed Oct 24 16:11:32 UTC 2012
 cpukit/rtems/Makefile.am                   |    2 +
 cpukit/rtems/include/rtems/rtems/event.h   |   81 ++++++++++++++++++++++++++++
 cpukit/rtems/src/event.c                   |    1 +
 cpukit/rtems/src/systemeventreceive.c      |   67 +++++++++++++++++++++++
 cpukit/rtems/src/systemeventsend.c         |   65 ++++++++++++++++++++++
 cpukit/score/include/rtems/score/states.h  |    3 +
 cpukit/score/inline/rtems/score/states.inl |   15 +++++
 7 files changed, 234 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/rtems/src/systemeventreceive.c
 create mode 100644 cpukit/rtems/src/systemeventsend.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index bbf8611..ff3174e 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -209,6 +209,8 @@ librtems_a_SOURCES += src/eventsend.c
 librtems_a_SOURCES += src/eventsurrender.c
 librtems_a_SOURCES += src/eventtimeout.c
 librtems_a_SOURCES += src/eventdata.c
+librtems_a_SOURCES += src/systemeventsend.c
+librtems_a_SOURCES += src/systemeventreceive.c
 ## SIGNAL_C_FILES
 librtems_a_SOURCES += src/signal.c
diff --git a/cpukit/rtems/include/rtems/rtems/event.h b/cpukit/rtems/include/rtems/rtems/event.h
index dc7f445..0ff1d5a 100644
--- a/cpukit/rtems/include/rtems/rtems/event.h
+++ b/cpukit/rtems/include/rtems/rtems/event.h
@@ -207,6 +207,85 @@ rtems_status_code rtems_event_receive (
+ *  @defgroup ClassicSystemEvent System Events
+ *  @ingroup ClassicRTEMS
+ * @brief Reserved system event for transient usage.
+ * The executing task must ensure that this event is not pending after the last
+ * call to rtems_system_event_receive() in the last usage context.
+#define RTEMS_SYSTEM_EVENT_TRANSIENT RTEMS_EVENT_0
+ * @brief See rtems_event_send().
+rtems_status_code rtems_system_event_send(
+  rtems_id id,
+  rtems_event_set event_in
+ * @brief See rtems_event_receive().
+rtems_status_code rtems_system_event_receive(
+  rtems_event_set event_in,
+  rtems_option option_set,
+  rtems_interval ticks,
+  rtems_event_set *event_out
+ * @brief See rtems_system_event_send() and RTEMS_SYSTEM_EVENT_TRANSIENT.
+RTEMS_INLINE_ROUTINE rtems_status_code rtems_transient_event_send(
+  rtems_id id
+  return rtems_system_event_send( id, RTEMS_SYSTEM_EVENT_TRANSIENT );
+ * @brief See rtems_system_event_receive() and RTEMS_SYSTEM_EVENT_TRANSIENT.
+RTEMS_INLINE_ROUTINE rtems_status_code rtems_transient_event_receive(
+  rtems_event_set event_out;
+  return rtems_system_event_receive(
+    RTEMS_SYSTEM_EVENT_TRANSIENT,
+    RTEMS_EVENT_ALL | option_set,
+    ticks,
+    &event_out
+RTEMS_INLINE_ROUTINE void rtems_transient_event_clear( void )
+  rtems_system_event_receive(
+    RTEMS_EVENT_ALL | RTEMS_NO_WAIT,
+    0,
+    &event_out
  *  @defgroup ScoreEvent Event Handler
  *  @ingroup Score
@@ -248,6 +327,8 @@ void _Event_Timeout (
 RTEMS_EVENT_EXTERN Thread_blocking_operation_States _Event_Sync_state;
+RTEMS_EVENT_EXTERN Thread_blocking_operation_States _System_event_Sync_state;
 #if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/rtems/src/event.c b/cpukit/rtems/src/event.c
index ed148e8..d5c29f6 100644
--- a/cpukit/rtems/src/event.c
+++ b/cpukit/rtems/src/event.c
@@ -34,6 +34,7 @@
 void _Event_Manager_initialization( void )
   _Event_Sync_state = THREAD_BLOCKING_OPERATION_SYNCHRONIZED;
+  _System_event_Sync_state = THREAD_BLOCKING_OPERATION_SYNCHRONIZED;
    *  Register the MP Process Packet routine.
diff --git a/cpukit/rtems/src/systemeventreceive.c b/cpukit/rtems/src/systemeventreceive.c
new file mode 100644
index 0000000..22ab473
--- /dev/null
+++ b/cpukit/rtems/src/systemeventreceive.c
@@ -0,0 +1,67 @@
+ * @file
+ * @ingroup ClassicSystemEvent
+ * @brief rtems_system_event_receive() implementation.
+ * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/rtems/event.h>
+#include <rtems/rtems/tasks.h>
+  rtems_status_code sc;
+  if ( event_out != NULL ) {
+    Thread_Control *executing = _Thread_Executing;
+    RTEMS_API_Control *api = executing->API_Extensions[ THREAD_API_RTEMS ];
+    if ( !_Event_sets_Is_empty( event_in ) ) {
+      _Thread_Disable_dispatch();
+      _Event_Seize(
+        event_in,
+        option_set,
+        ticks,
+        event_out,
+        executing,
+        &api->pending_events,
+        &_System_event_Sync_state,
+        STATES_WAITING_FOR_SYSTEM_EVENT
+      _Thread_Enable_dispatch();
+      sc = _Thread_Executing->Wait.return_code;
+    } else {
+      *event_out = api->pending_events;
+      sc = RTEMS_SUCCESSFUL;
+  } else {
+    sc = RTEMS_INVALID_ADDRESS;
+  return sc;
diff --git a/cpukit/rtems/src/systemeventsend.c b/cpukit/rtems/src/systemeventsend.c
index 0000000..aafa03e
--- /dev/null
+++ b/cpukit/rtems/src/systemeventsend.c
@@ -0,0 +1,65 @@
+ * @file
+ * @brief rtems_system_event_send() implementation.
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+  rtems_id id,
+  Thread_Control *thread;
+  Objects_Locations location;
+  RTEMS_API_Control *api;
+  thread = _Thread_Get( id, &location );
+  switch ( location ) {
+    case OBJECTS_LOCAL:
+      api = thread->API_Extensions[ THREAD_API_RTEMS ];
+      _Event_Surrender(
+        thread,
+        event_in,
+      break;
+#ifdef RTEMS_MULTIPROCESSING
+    case OBJECTS_REMOTE:
+      sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
+      break;
+#endif
+    default:
+      sc = RTEMS_INVALID_ID;
+      break;
+  return sc;
diff --git a/cpukit/score/include/rtems/score/states.h b/cpukit/score/include/rtems/score/states.h
index eb4658e..f71bf93 100644
--- a/cpukit/score/include/rtems/score/states.h
+++ b/cpukit/score/include/rtems/score/states.h
@@ -81,6 +81,8 @@ typedef uint32_t   States_Control;
 #define STATES_WAITING_FOR_BARRIER             0x10000
 /** This macro corresponds to a task waiting for a RWLock. */
 #define STATES_WAITING_FOR_RWLOCK              0x20000
+/** This macro corresponds to a task waiting for a system event. */
+#define STATES_WAITING_FOR_SYSTEM_EVENT        0x40000
 /** This macro corresponds to a task which is in an interruptible
  *  blocking state.
@@ -110,6 +112,7 @@ typedef uint32_t   States_Control;
                                  STATES_WAITING_FOR_TIME        | \
                                  STATES_WAITING_FOR_PERIOD      | \
                                  STATES_WAITING_FOR_EVENT       | \
+                                 STATES_WAITING_FOR_SYSTEM_EVENT | \
                                  STATES_WAITING_ON_THREAD_QUEUE | \
                                  STATES_INTERRUPTIBLE_BY_SIGNAL )
diff --git a/cpukit/score/inline/rtems/score/states.inl b/cpukit/score/inline/rtems/score/states.inl
index 7bad0c9..f5d816a 100644
--- a/cpukit/score/inline/rtems/score/states.inl
+++ b/cpukit/score/inline/rtems/score/states.inl
@@ -213,6 +213,21 @@ RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_event (
+ *  This function returns true if the WAITING_FOR_SYSTEM_EVENT state is set in
+ *  the_states, and false otherwise.
+ *  @param[in] the_states is the task state set to test
+ *  @return This method returns true if the desired state condition is set.
+RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_system_event (
+  States_Control the_states
+   return (the_states & STATES_WAITING_FOR_SYSTEM_EVENT);
  *  This function returns true if the WAITING_FOR_MUTEX state
  *  is set in the_states, and false otherwise.
1.7.7
