[PATCH 2/3] score: Add system events
Wed Oct 24 16:35:38 UTC 2012
The new functions don't really seem to follow the usual conventions
for rtems "packages". Might it be better to use something like
rtems_event_send/receive_system/transient
On Wed, Oct 24, 2012 at 12:11 PM, Sebastian Huber
>  cpukit/rtems/Makefile.am                   |    2 +
>  cpukit/rtems/include/rtems/rtems/event.h   |   81 ++++++++++++++++++++++++++++
>  cpukit/rtems/src/event.c                   |    1 +
>  cpukit/rtems/src/systemeventreceive.c      |   67 +++++++++++++++++++++++
>  cpukit/rtems/src/systemeventsend.c         |   65 ++++++++++++++++++++++
>  cpukit/score/include/rtems/score/states.h  |    3 +
>  cpukit/score/inline/rtems/score/states.inl |   15 +++++
>  7 files changed, 234 insertions(+), 0 deletions(-)
>  create mode 100644 cpukit/rtems/src/systemeventreceive.c
>  create mode 100644 cpukit/rtems/src/systemeventsend.c
> diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
> index bbf8611..ff3174e 100644
> --- a/cpukit/rtems/Makefile.am
> +++ b/cpukit/rtems/Makefile.am
> @@ -209,6 +209,8 @@ librtems_a_SOURCES += src/eventsend.c
>  librtems_a_SOURCES += src/eventsurrender.c
>  librtems_a_SOURCES += src/eventtimeout.c
>  librtems_a_SOURCES += src/eventdata.c
> +librtems_a_SOURCES += src/systemeventsend.c
> +librtems_a_SOURCES += src/systemeventreceive.c
>  ## SIGNAL_C_FILES
>  librtems_a_SOURCES += src/signal.c
> diff --git a/cpukit/rtems/include/rtems/rtems/event.h b/cpukit/rtems/include/rtems/rtems/event.h
> index dc7f445..0ff1d5a 100644
> --- a/cpukit/rtems/include/rtems/rtems/event.h
> +++ b/cpukit/rtems/include/rtems/rtems/event.h
> @@ -207,6 +207,85 @@ rtems_status_code rtems_event_receive (
> + *  @defgroup ClassicSystemEvent System Events
> + *  @ingroup ClassicRTEMS
> + * @brief Reserved system event for transient usage.
> + * The executing task must ensure that this event is not pending after the last
> + * call to rtems_system_event_receive() in the last usage context.
> +#define RTEMS_SYSTEM_EVENT_TRANSIENT RTEMS_EVENT_0
> + * @brief See rtems_event_send().
> +rtems_status_code rtems_system_event_send(
> +  rtems_id id,
> +  rtems_event_set event_in
> + * @brief See rtems_event_receive().
> +rtems_status_code rtems_system_event_receive(
> +  rtems_event_set event_in,
> +  rtems_option option_set,
> +  rtems_interval ticks,
> +  rtems_event_set *event_out
> + * @brief See rtems_system_event_send() and RTEMS_SYSTEM_EVENT_TRANSIENT.
> +RTEMS_INLINE_ROUTINE rtems_status_code rtems_transient_event_send(
> +  rtems_id id
> +  return rtems_system_event_send( id, RTEMS_SYSTEM_EVENT_TRANSIENT );
> + * @brief See rtems_system_event_receive() and RTEMS_SYSTEM_EVENT_TRANSIENT.
> +RTEMS_INLINE_ROUTINE rtems_status_code rtems_transient_event_receive(
> +  rtems_event_set event_out;
> +  return rtems_system_event_receive(
> +    RTEMS_SYSTEM_EVENT_TRANSIENT,
> +    RTEMS_EVENT_ALL | option_set,
> +    ticks,
> +    &event_out
> +RTEMS_INLINE_ROUTINE void rtems_transient_event_clear( void )
> +  rtems_system_event_receive(
> +    RTEMS_EVENT_ALL | RTEMS_NO_WAIT,
> +    0,
> +    &event_out
>   *  @defgroup ScoreEvent Event Handler
>   *  @ingroup Score
> @@ -248,6 +327,8 @@ void _Event_Timeout (
>  RTEMS_EVENT_EXTERN Thread_blocking_operation_States _Event_Sync_state;
> +RTEMS_EVENT_EXTERN Thread_blocking_operation_States _System_event_Sync_state;
>  #if defined(RTEMS_MULTIPROCESSING)
> diff --git a/cpukit/rtems/src/event.c b/cpukit/rtems/src/event.c
> index ed148e8..d5c29f6 100644
> --- a/cpukit/rtems/src/event.c
> +++ b/cpukit/rtems/src/event.c
> @@ -34,6 +34,7 @@
>  void _Event_Manager_initialization( void )
>    _Event_Sync_state = THREAD_BLOCKING_OPERATION_SYNCHRONIZED;
> +  _System_event_Sync_state = THREAD_BLOCKING_OPERATION_SYNCHRONIZED;
>     *  Register the MP Process Packet routine.
> diff --git a/cpukit/rtems/src/systemeventreceive.c b/cpukit/rtems/src/systemeventreceive.c
> new file mode 100644
> index 0000000..22ab473
> --- /dev/null
> +++ b/cpukit/rtems/src/systemeventreceive.c
> @@ -0,0 +1,67 @@
> + * @file
> + * @ingroup ClassicSystemEvent
> + * @brief rtems_system_event_receive() implementation.
> + * Copyright (c) 2012 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Obere Lagerstr. 30
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#if HAVE_CONFIG_H
> +  #include "config.h"
> +#endif
> +#include <rtems/rtems/event.h>
> +#include <rtems/rtems/tasks.h>
> +  rtems_status_code sc;
> +  if ( event_out != NULL ) {
> +    Thread_Control *executing = _Thread_Executing;
> +    RTEMS_API_Control *api = executing->API_Extensions[ THREAD_API_RTEMS ];
> +    if ( !_Event_sets_Is_empty( event_in ) ) {
> +      _Thread_Disable_dispatch();
> +      _Event_Seize(
> +        event_in,
> +        option_set,
> +        ticks,
> +        event_out,
> +        executing,
> +        &api->pending_events,
> +        &_System_event_Sync_state,
> +        STATES_WAITING_FOR_SYSTEM_EVENT
> +      _Thread_Enable_dispatch();
> +      sc = _Thread_Executing->Wait.return_code;
> +    } else {
> +      *event_out = api->pending_events;
> +      sc = RTEMS_SUCCESSFUL;
> +  } else {
> +    sc = RTEMS_INVALID_ADDRESS;
> +  return sc;
> diff --git a/cpukit/rtems/src/systemeventsend.c b/cpukit/rtems/src/systemeventsend.c
> index 0000000..aafa03e
> --- /dev/null
> +++ b/cpukit/rtems/src/systemeventsend.c
> @@ -0,0 +1,65 @@
> + * @file
> + * @brief rtems_system_event_send() implementation.
> + *  82178 Puchheim
> + *  Germany
> +#if HAVE_CONFIG_H
> +#endif
> +  rtems_id id,
> +  Thread_Control *thread;
> +  Objects_Locations location;
> +  RTEMS_API_Control *api;
> +  thread = _Thread_Get( id, &location );
> +  switch ( location ) {
> +    case OBJECTS_LOCAL:
> +      api = thread->API_Extensions[ THREAD_API_RTEMS ];
> +      _Event_Surrender(
> +        thread,
> +        event_in,
> +      break;
> +#ifdef RTEMS_MULTIPROCESSING
> +    case OBJECTS_REMOTE:
> +      sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
> +      break;
> +#endif
> +    default:
> +      sc = RTEMS_INVALID_ID;
> +      break;
> +  return sc;
> diff --git a/cpukit/score/include/rtems/score/states.h b/cpukit/score/include/rtems/score/states.h
> index eb4658e..f71bf93 100644
> --- a/cpukit/score/include/rtems/score/states.h
> +++ b/cpukit/score/include/rtems/score/states.h
> @@ -81,6 +81,8 @@ typedef uint32_t   States_Control;
>  #define STATES_WAITING_FOR_BARRIER             0x10000
>  /** This macro corresponds to a task waiting for a RWLock. */
>  #define STATES_WAITING_FOR_RWLOCK              0x20000
> +/** This macro corresponds to a task waiting for a system event. */
> +#define STATES_WAITING_FOR_SYSTEM_EVENT        0x40000
>  /** This macro corresponds to a task which is in an interruptible
>   *  blocking state.
> @@ -110,6 +112,7 @@ typedef uint32_t   States_Control;
>                                   STATES_WAITING_FOR_TIME        | \
>                                   STATES_WAITING_FOR_PERIOD      | \
>                                   STATES_WAITING_FOR_EVENT       | \
> +                                 STATES_WAITING_FOR_SYSTEM_EVENT | \
>                                   STATES_WAITING_ON_THREAD_QUEUE | \
>                                   STATES_INTERRUPTIBLE_BY_SIGNAL )
> diff --git a/cpukit/score/inline/rtems/score/states.inl b/cpukit/score/inline/rtems/score/states.inl
> index 7bad0c9..f5d816a 100644
> --- a/cpukit/score/inline/rtems/score/states.inl
> +++ b/cpukit/score/inline/rtems/score/states.inl
> @@ -213,6 +213,21 @@ RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_event (
> + *  This function returns true if the WAITING_FOR_SYSTEM_EVENT state is set in
> + *  the_states, and false otherwise.
> + *  @param[in] the_states is the task state set to test
> + *  @return This method returns true if the desired state condition is set.
> +RTEMS_INLINE_ROUTINE bool _States_Is_waiting_for_system_event (
> +  States_Control the_states
> +   return (the_states & STATES_WAITING_FOR_SYSTEM_EVENT);
>   *  This function returns true if the WAITING_FOR_MUTEX state
>   *  is set in the_states, and false otherwise.
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
