[PATCH] FB driver for Cirrus GD5446 graphic hardware.
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 13 16:45:19 UTC 2012
Thanks for posting this so quickly. Here are some quick comments:
+ No Makefile.am changes?
+ C++ style comments need to be C
+ Some one-line C comments do not have a space before the */
+ Use single blank lines not multiple ones in a row
+ No license terms at top of file
I assume it works as as we get more into the graphics-addon patches
I will be able to duplicate your results.
--joel
On 9/13/2012 11:12 AM, Pavel Pisa wrote:
> From: Alexandru-Sever Horin <alex.sever.h at gmail.com>
> Subject: FB driver for Cirrus GD5446 graphic hardware.
> Implementation is tested to work on QEMU simulator only.
> QEMU offers this hardware by default for PC platform but
> it can be requested by "-vga cirrus" option for other PCI
> aware systems as well.
> Next sources used for driver implementation:
> - RTEMS fb_vga.c - Rosimildo da Silva ( rdasilva at connecttel.com )
> - Cirrus xf86 driver - used as VGA hardware setup documentation
> - CL-GD5446 Technical Reference Manual, 1996, Second Edition
> Signed-off-by: Alexandru-Sever Horin <alex.sever.h at gmail.com>
> Signed-off-by: Pavel Pisa <pisa at cmp.felk.cvut.cz>
> c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c | 771 +++++++++++++++++++++++
> 1 file changed, 771 insertions(+)
> create mode 100644 c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
> diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
> new file mode 100644
> index 0000000..7c6fc23
> --- /dev/null
> +++ b/c/src/lib/libbsp/i386/pc386/console/fb_cirrus.c
> @@ -0,0 +1,771 @@
> + * Copyright (c) 2012 - Alexandru-Sever Horin (alex.sever.h at gmail.com)
> + * MODULE DESCRIPTION:
> + * This module implements FB driver for Cirrus GD5446 board.
> + * It is tested to work on QEMU simulator only.
> + * used for documentation and model code from:
> + * fb_vga.c - Rosimildo da Silva ( rdasilva at connecttel.com )
> + * Cirrus xf86 driver
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <errno.h>
> +#include <sys/types.h>
> +#include <pthread.h>
> +#include <bsp.h>
> +#include <bsp/irq.h>
> +#include <rtems/libio.h>
> +#include <rtems/pci.h>
> +#include <rtems/fb.h>
> +/* mutex attribure */
> +pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
> +/* screen information for the VGA driver
> + * standard structures
> +static struct fb_var_screeninfo fb_var;
> +static struct fb_fix_screeninfo fb_fix;
> +#define CIRRUS_VENDOR_ID 0x1013
> +#define CIRRUS_GD5446_DEVICE_ID 0x00b8
> +typedef struct _DisplayModeRec {
> + struct _DisplayModeRec *prev;
> + struct _DisplayModeRec *next;
> + char *name; /* identifier for the mode */
> + // ModeStatus status;
> + int type;
> + /* These are the values that the user sees/provides */
> + int Clock; /* pixel clock freq (kHz) */
> + int HDisplay; /* horizontal timing */
> + int HSyncStart;
> + int HSyncEnd;
> + int HTotal;
> + int HSkew;
> + int VDisplay; /* vertical timing */
> + int VSyncStart;
> + int VSyncEnd;
> + int VTotal;
> + int VScan;
> + int Flags;
> + /* These are the values the hardware uses */
> + int ClockIndex;
> + int SynthClock; /* Actual clock freq to
> + * be programmed (kHz) */
> + int CrtcHDisplay;
> + int CrtcHBlankStart;
> + int CrtcHSyncStart;
> + int CrtcHSyncEnd;
> + int CrtcHBlankEnd;
> + int CrtcHTotal;
> + int CrtcHSkew;
> + int CrtcVDisplay;
> + int CrtcVBlankStart;
> + int CrtcVSyncStart;
> + int CrtcVSyncEnd;
> + int CrtcVBlankEnd;
> + int CrtcVTotal;
> + int CrtcHAdjusted;
> + int CrtcVAdjusted;
> + int PrivSize;
> + int32_t *Private;
> + int PrivFlags;
> + float HSync, VRefresh;
> +} DisplayModeRec, *DisplayModePtr;
> +static DisplayModeRec available_modes[] = {
> + .Clock = 31500 ,
> + .HDisplay = 640 ,
> + .HSyncStart = 664 ,
> + .HSyncEnd = 704 ,
> + .HTotal = 832 ,
> + .HSkew = 0 ,
> + .VDisplay = 480 , /* vertical timing */
> + .VSyncStart = 489 ,
> + .VSyncEnd = 491 ,
> + .VTotal = 520 ,
> + .VScan = 0,
> + .Flags = 0
> + .Clock = 40000 ,
> + .HDisplay = 800 ,
> + .HSyncStart = 840 ,
> + .HSyncEnd = 968 ,
> + .HTotal = 1056 ,
> + .HSkew = 0 ,
> + .VDisplay = 600 , /* vertical timing */
> + .VSyncStart = 601 ,
> + .VSyncEnd = 605 ,
> + .VTotal = 628 ,
> + .VScan = 0,
> + .Flags = 0
> +static DisplayModePtr active_mode;
> +/* The display mode used for the board hardcoded in the following define
> + * Index in above structure
> +#define CIRRUS_DISPLAY_MODE 0
> +/* The display bytes per pixel used for the board hardcoded in the following define
> +#define CIRRUS_DEFAULT_BPP 24
> +/* cirrus board information */
> +struct cirrus_board_str{
> + int pci_bus;
> + int pci_device;
> + int pci_function;
> + void *reg_base;
> +static struct cirrus_board_str cirrus_board_info;
> + * get information from the board
> +int
> +cirrus_pci_read( struct cirrus_board_str *cirrus_board, uint32_t *mem_base, uint32_t *cirrus_register_base)
> + int r;
> + r = pci_read_config_dword(
> + cirrus_board->pci_bus, cirrus_board->pci_device, cirrus_board->pci_function,
> + PCI_BASE_ADDRESS_0, mem_base);
> + if( r != PCIB_ERR_SUCCESS)
> + return RTEMS_UNSATISFIED;
> + PCI_BASE_ADDRESS_1, cirrus_register_base);
> + *mem_base &= PCI_BASE_ADDRESS_MEM_MASK;
> + *cirrus_register_base &= PCI_BASE_ADDRESS_MEM_MASK;
> + return RTEMS_SUCCESSFUL;
> +inline int
> +fb_cirrus_read_config_dword(
> + struct cirrus_board_str *fbst,
> + unsigned char where,
> + uint32_t *pval)
> + return pci_read_config_dword(
> + fbst->pci_bus, fbst->pci_device, fbst->pci_function,
> + where, pval);
> +inline int
> +fb_cirrus_write_config_dword(
> + uint32_t val)
> + return pci_write_config_dword(
> + where, val);
> +inline void
> +fb_cirrus_write_reg8 (
> + const struct cirrus_board_str *fbst,
> + unsigned int reg,
> + unsigned int val)
> + *(volatile uint8_t*)((char *)fbst->reg_base + reg) = val;
> +inline unsigned int
> +fb_cirrus_read_reg8 (
> + unsigned int reg)
> + return *(volatile uint8_t*)((char *)fbst->reg_base + reg);
> +#define SEQ_INDEX 0x04
> +#define SEQ_DATA 0x05
> +inline void
> +fb_cirrus_write_seq_reg (
> + unsigned int reg,
> + unsigned int val)
> + fb_cirrus_write_reg8(fbst, SEQ_INDEX, reg);
> + fb_cirrus_write_reg8(fbst, SEQ_DATA, val);
> +fb_cirrus_read_seq_reg (
> + unsigned int reg)
> + return fb_cirrus_read_reg8(fbst, SEQ_DATA);
> +#define CRT_INDEX 0x14
> +#define CRT_DATA 0x15
> +inline void
> +fb_cirrus_write_crt_reg (
> + unsigned int reg,
> + unsigned int val)
> + fb_cirrus_write_reg8(fbst, CRT_INDEX, reg);
> + fb_cirrus_write_reg8(fbst, CRT_DATA, val);
> +fb_cirrus_read_crt_reg (
> + unsigned int reg)
> + return fb_cirrus_read_reg8(fbst, CRT_DATA);
> +#define GDC_INDEX 0x0E
> +#define GDC_DATA 0x0F
> +inline void
> +fb_cirrus_write_gdc_reg (
> + unsigned int reg,
> + unsigned int val)
> + fb_cirrus_write_reg8(fbst, GDC_INDEX, reg);
> + fb_cirrus_write_reg8(fbst, GDC_DATA, val);
> +fb_cirrus_read_gdc_reg (
> + unsigned int reg)
> + return fb_cirrus_read_reg8(fbst, GDC_DATA);
> +#define VGA_DAC_MASK 0x06
> +inline void
> +fb_cirrus_write_hdr_reg (
> + unsigned int val)
> + volatile unsigned int dummy __attribute__((unused));
> + dummy = fb_cirrus_read_reg8(fbst, VGA_DAC_MASK);
> + fb_cirrus_write_reg8(fbst, VGA_DAC_MASK, val);
> +/* Functionality to support multiple VGA frame buffers can be added easily,
> + * but is not supported at this moment because there is no need for two or
> + * more "classic" VGA adapters. Multiple frame buffer drivers may be
> + * implemented and If we had implement it they would be named as "/dev/fb0",
> + * "/dev/fb1", "/dev/fb2" and so on.
> + * fb_cirrus device driver INITIALIZE entry point.
> +rtems_device_driver frame_buffer_initialize(
> + rtems_device_major_number major,
> + rtems_device_minor_number minor,
> + void *arg
> + rtems_status_code status;
> + int res;
> + printk( "FB_CIRRUS -- driver initializing..\n" );
> + res = pci_find_device(
> + CIRRUS_VENDOR_ID,
> + CIRRUS_GD5446_DEVICE_ID,
> + minor,
> + &cirrus_board_info.pci_bus,
> + &cirrus_board_info.pci_device,
> + &cirrus_board_info.pci_function
> + if ( res != PCIB_ERR_SUCCESS ) {
> + printk( "FB_CIRRUS initialize -- device not found\n" );
> + else{
> + * Register the device
> + status = rtems_io_register_name ("/dev/fb0", major, 0);
> + if (status != RTEMS_SUCCESSFUL) {
> + printk("Error registering /dev/fb0 FB_CIRRUS framebuffer device!\n");
> + rtems_fatal_error_occurred( status );
> + * This function is used to initialize the Start Address - the first
> + * displayed location in the video memory.
> + * Usually mandatory
> +void
> +cirrus_adjust_frame( struct cirrus_board_str *board, int x, int y)
> + uint32_t Base;
> + uint8_t tmp;
> + Base = ((y * fb_var.xres + x) >> 3);
> + if (fb_var.bits_per_pixel != 1)
> + Base *= (fb_var.bits_per_pixel >> 2);
> + printk("FB_CIRRUS: cirrus_adjust_frame %d %d >>> %d %x\n", x, y, Base, Base);
> + if ((Base & ~0x000FFFFF) != 0) {
> + printk("FB_CIRRUS: Internal error: cirrus_adjust_frame: cannot handle overflow\n");
> + return;
> + fb_cirrus_write_crt_reg( board, 0x0C, (Base >> 8) & 0xff);
> + fb_cirrus_write_crt_reg( board, 0x0D, Base & 0xff);
> + tmp = fb_cirrus_read_crt_reg( board, 0x1B);
> + tmp &= 0xF2;
> + tmp |= (Base >> 16) & 0x01;
> + tmp |= (Base >> 15) & 0x0C;
> + fb_cirrus_write_crt_reg( board, 0x1B, tmp);
> + tmp = fb_cirrus_read_crt_reg( board, 0x1D);
> + tmp &= 0x7F;
> + tmp |= (Base >> 12) & 0x80;
> + fb_cirrus_write_crt_reg( board, 0x1D, tmp);
> +int cirrus_set_mode(DisplayModePtr mode)
> + int depthcode = fb_var.bits_per_pixel;;
> + int width;
> + int HDiv2 = 0, VDiv2 = 0;
> + const struct cirrus_board_str *cirrus_board_ptr = &cirrus_board_info;
> + int temp;
> + int hdr = -1;
> + printk("FB_CIRRUS: mode %d bpp, %d Hz %d %d %d %d %d %d %d %d\n",
> + fb_var.bits_per_pixel,
> + mode->Clock,
> + mode->HDisplay,
> + mode->HSyncStart,
> + mode->HSyncEnd,
> + mode->HTotal,
> + mode->VDisplay,
> + mode->VSyncStart,
> + mode->VSyncEnd,
> + mode->VTotal);
> + if ( mode->Clock > 85500 ) {
> + /* The actual DAC register value is set later. */
> + /* The CRTC is clocked at VCLK / 2, so we must half the */
> + /* horizontal timings. */
> + if (!mode->CrtcHAdjusted) {
> + mode->HDisplay >>= 1;
> + mode->HSyncStart >>= 1;
> + mode->HTotal >>= 1;
> + mode->HSyncEnd >>= 1;
> + mode->SynthClock >>= 1;
> + mode->CrtcHAdjusted = TRUE;
> + depthcode += 64;
> + HDiv2 = 1;
> + if (mode->VTotal >= 1024 ) {
> + /* For non-interlaced vertical timing >= 1024, the vertical timings */
> + /* are divided by 2 and VGA CRTC 0x17 bit 2 is set. */
> + if (!mode->CrtcVAdjusted) {
> + mode->VDisplay >>= 1;
> + mode->VSyncStart >>= 1;
> + mode->VSyncEnd >>= 1;
> + mode->VTotal >>= 1;
> + mode->CrtcVAdjusted = TRUE;
> + VDiv2 = 1;
> + * Sequential registers
> + fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x00, 0x00);
> + fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x01, 0x01);
> + fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x02, 0x0F);
> + fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x03, 0x00);
> + fb_cirrus_write_seq_reg(cirrus_board_ptr, 0x04, 0x0E);
> + * CRTC Controller Registers
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x00, (mode->HTotal >> 3) - 5 );
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x01, (mode->HDisplay >> 3) - 1);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x02, (mode->HSyncStart >> 3) - 1);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x03, ((mode->HSyncEnd >> 3) & 0x1F) | 0x80);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x04, (mode->HSyncStart >> 3));
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x05,
> + (((mode->HSyncEnd >> 3) & 0x20 ) << 2 )
> + | (((mode->HSyncEnd >> 3)) & 0x1F));
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x06, (mode->VTotal - 2) & 0xFF);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x07,
> + (((mode->VTotal -2) & 0x100) >> 8 )
> + | (((mode->VDisplay -1) & 0x100) >> 7 )
> + | ((mode->VSyncStart & 0x100) >> 6 )
> + | (((mode->VSyncStart) & 0x100) >> 5 )
> + | 0x10
> + | (((mode->VTotal -2) & 0x200) >> 4 )
> + | (((mode->VDisplay -1) & 0x200) >> 3 )
> + | ((mode->VSyncStart & 0x200) >> 2 ));
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x08, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x09, ((mode->VSyncStart & 0x200) >>4) | 0x40);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0A, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0B, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0C, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0D, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0E, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x0F, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x10, mode->VSyncStart & 0xFF);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x11, (mode->VSyncEnd & 0x0F) | 0x20);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x12, (mode->VDisplay -1) & 0xFF);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x13, 0x00); /* no interlace */
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x14, 0x00);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x15, mode->VSyncStart & 0xFF);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x16, (mode->VSyncStart +1) & 0xFF);
> + temp = 0xAF;
> + if(VDiv2)
> + temp |= 0x04;
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x17, temp);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x18, 0xFF);
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x1A ,
> + (((mode->HTotal >> 3) & 0xC0 ) >> 2)
> + | (((mode->VTotal - 2) & 0x300 ) >> 2));
> + width = fb_fix.line_length >> 3;
> + if (fb_var.bits_per_pixel == 1)
> + width <<= 2;
> + if(width >= 0xFF)
> + printk("FB_CIRRUS: Warning line size over the limit ... reduce bpp or width resolution");
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x13, width);
> + /* Offset extension (see CR13) */
> + temp = fb_cirrus_read_crt_reg( cirrus_board_ptr, 0x1B);
> + temp &= 0xAF;
> + temp |= (width >> (3+4)) & 0x10;
> + temp |= (width >> (3+3)) & 0x40;
> + temp |= 0x22;
> + fb_cirrus_write_crt_reg( cirrus_board_ptr, 0x1B, temp);
> + * Enable linear mode and high-res packed pixel mode
> + temp = fb_cirrus_read_seq_reg( cirrus_board_ptr, 0x07);
> + temp &= 0xe0;
> + switch (depthcode) {
> + case 1:
> + case 4:
> + temp |= 0x10;
> + break;
> + case 8:
> + temp |= 0x11;
> + break;
> + case 64+8:
> + temp |= 0x17;
> + break;
> + case 15:
> + temp |= 0x17;
> + hdr = 0xC0; // 5:5:5 Sierra
> + break;
> + case 16:
> + temp |= 0x17;
> + hdr = 0xC1; // 5:6:5 XGA mode
> + break;
> + case 24:
> + temp |= 0x15;
> + hdr = 0xC5; // 8:8:8 16M colors
> + break;
> + case 32:
> + temp |= 0x19;
> + break;
> + default:
> + printk("FB_CIRRUS: Cannot Initialize display to requested mode\n");
> + printk("FB_CIRRUS: returning RTEMS_UNSATISFIED on depthcode %d\n", depthcode);
> + fb_cirrus_write_seq_reg( cirrus_board_ptr, 0x07, temp);
> + // this just set packed pixel mode with according bpp
> + * HDR Register
> + if(hdr > 0)
> + fb_cirrus_write_hdr_reg( cirrus_board_ptr, hdr);
> + * Graphic Data Controller Registers
> + temp = fb_cirrus_read_gdc_reg( cirrus_board_ptr, 0x12);
> + if (HDiv2)
> + temp |= 0x20;
> + else
> + temp &= ~0x20;
> + fb_cirrus_write_gdc_reg( cirrus_board_ptr, 0x12, temp);
> + /* Enable high-color modes */
> + fb_cirrus_write_gdc_reg(cirrus_board_ptr, 0x05, 0x40);
> + /* VGA graphics mode */
> + fb_cirrus_write_gdc_reg(cirrus_board_ptr, 0x06, 0x01);
> + return TRUE;
> +void cirrus_prepare_mode( void )
> + active_mode = &available_modes[CIRRUS_DISPLAY_MODE];
> + fb_var.bits_per_pixel = CIRRUS_DEFAULT_BPP;
> + fb_var.xres = active_mode->HDisplay;
> + fb_var.yres = active_mode->VDisplay;
> + fb_fix.line_length = (fb_var.xres * fb_var.bits_per_pixel + 7) / 8;
> + fb_fix.type = FB_TYPE_PACKED_PIXELS;
> + fb_fix.visual = FB_VISUAL_TRUECOLOR;
> + * fb_cirrus device driver OPEN entry point
> +rtems_device_driver frame_buffer_open(
> + void *arg
> + int r;
> + uint32_t smem_start, regs_start;
> + if (pthread_mutex_trylock(&mutex)!= 0){
> + printk( "FB_CIRRUS could not lock mutex\n" );
> + r = cirrus_pci_read(&cirrus_board_info, &smem_start, ®s_start);
> + if ( r == RTEMS_UNSATISFIED )
> + fb_fix.smem_start = (volatile char *)smem_start;
> + fb_fix.smem_len = 0x1000000;
> + cirrus_board_info.reg_base = (void *)regs_start;
> + cirrus_prepare_mode();
> + cirrus_set_mode( active_mode );
> + cirrus_adjust_frame( &cirrus_board_info, 0, 0);
> + if (1) {
> + uint32_t pixmask;
> + int x, y;
> + if(fb_var.bits_per_pixel == 32)
> + pixmask = 0xffffff;
> + else
> + pixmask = (1 << fb_var.bits_per_pixel) - 1;
> + printk("FB_CIRRUS: mode set, test patter output\n");
> + /*while(1)*/
> + for(y = 0; y < fb_var.yres; y++) {
> + for(x = 0; x < fb_var.xres; x++) {
> + uint32_t color;
> + char *addr = (char *)fb_fix.smem_start;
> + addr += y * fb_fix.line_length;
> + addr += x * fb_var.bits_per_pixel / 8;
> + color = x & 1 ? 0 : y & 1 ? pixmask & 0x000ff00f : pixmask;
> + if(y == fb_var.yres - 1) {
> + if((x > 0) && (x < fb_var.xres-1))
> + color = pixmask & 0x00555555;
> + switch (fb_var.bits_per_pixel) {
> + case 8: *(volatile uint8_t*) addr = color;
> + break;
> + case 16: *(volatile uint16_t*) addr = color;
> + break;
> + case 24: *(volatile uint32_t*) addr =
> + (*(volatile uint32_t*) addr & 0xff000000) | color;
> + break;
> + case 32: *(volatile uint32_t*) addr = color;
> + break;
> + * fb_cirrus device driver CLOSE entry point
> +rtems_device_driver frame_buffer_close(
> + void *arg
> + if (pthread_mutex_unlock(&mutex) == 0){
> + /* restore previous state. for VGA this means return to text mode.
> + * leave out if graphics hardware has been initialized in
> + * frame_buffer_initialize() */
> + /* VGA text mode */
> + fb_cirrus_write_gdc_reg(&cirrus_board_info, 0x06, 0x00);
> + printk( "FB_CIRRUS: close called.\n" );
> + * fb_cirrus device driver READ entry point.
> +rtems_device_driver frame_buffer_read(
> + void *arg
> + rtems_libio_rw_args_t *rw_args = (rtems_libio_rw_args_t *)arg;
> + rw_args->bytes_moved = ((rw_args->offset + rw_args->count) > fb_fix.smem_len ) ? (fb_fix.smem_len - rw_args->offset) : rw_args->count;
> + memcpy(rw_args->buffer, (const void *) (fb_fix.smem_start + rw_args->offset), rw_args->bytes_moved);
> + * frame_buffer device driver WRITE entry point.
> +rtems_device_driver frame_buffer_write(
> + void *arg
> + memcpy( (void *) (fb_fix.smem_start + rw_args->offset), rw_args->buffer, rw_args->bytes_moved);
> +static int get_fix_screen_info( struct fb_fix_screeninfo *info )
> + *info = fb_fix;
> + return 0;
> +static int get_var_screen_info( struct fb_var_screeninfo *info )
> + *info = fb_var;
> + return 0;
> + * IOCTL entry point -- This method is called to carry
> + * all services of this interface.
> +rtems_device_driver frame_buffer_control(
> + void *arg
> + rtems_libio_ioctl_args_t *args = arg;
> + printk( "FB_CIRRUS ioctl called, cmd=%x\n", args->command );
> + switch( args->command ) {
> + case FBIOGET_FSCREENINFO:
> + args->ioctl_return = get_fix_screen_info( ( struct fb_fix_screeninfo * ) args->buffer );
> + break;
> + case FBIOGET_VSCREENINFO:
> + args->ioctl_return = get_var_screen_info( ( struct fb_var_screeninfo * ) args->buffer );
> + break;
> + case FBIOPUT_VSCREENINFO:
> + /* not implemented yet*/
> + args->ioctl_return = -1;
> + case FBIOGETCMAP:
> + /* no palette - truecolor mode*/
> + case FBIOPUTCMAP:
> + default:
> + args->ioctl_return = 0;
> + break;
> 1.7.10.4
Joel Sherrill, Ph.D. Director of Research& Development
