change log for rtems (2011-05-26)
Wed Sep 26 13:51:47 UTC 2012
On 09/26/2012 08:48 AM, Sebastian Huber wrote:
> On 09/26/2012 03:40 PM, Joel Sherrill wrote:
>> On 09/26/2012 07:00 AM, Sebastian Huber wrote:
>>> What has this change to do with SMP inter-process communications?  Why do we
>>> update _Thread_Time_of_last_context_switch in case
>>> __RTEMS_USE_TICKS_FOR_STATISTICS__ is defined?
>> At least I can explain this part of the change.  There were technically
>> two changes in that commit. They got merged into one and the comment
>> doesn't reflect that.
>> If you don't set the _Thread_Time_of_last_context_switch, then the
>> statistics for rate monotonic periods are not completely right. You
>> need to account for how long the current task has been running.
> Ok, but then the rate-monotonic statistics do not honor the
> __RTEMS_USE_TICKS_FOR_STATISTICS__.  I currently don't have time to look at
> this more detailed, but I think something is mixed up here.
Where do they not honor that? I see it used in a number of
rate monotonic files:
./include/rtems/rtems/ratemon.h
./src/ratemongetstatistics.c
./src/ratemongetstatus.c
./src/ratemonreportstatistics.c
./src/ratemonperiod.c
Joel Sherrill, Ph.D.             Director of Research&   Development
