[rtems commit] bsp/mpc55xx: Add e200z7 specific idle task
Fri Sep 28 15:07:39 UTC 2012
On 09/28/2012 04:57 PM, Joel Sherrill wrote:
> On 9/28/2012 9:47 AM, Sebastian Huber wrote:
>> Module:    rtems
>> Branch:    master
>> Commit:    b762488ef5cd1fe18b620dd960dcbab9587aefe9
>> Changeset:
>> http://git.rtems.org/rtems/commit/?id=b762488ef5cd1fe18b620dd960dcbab9587aefe9
>> Author:    Sebastian Huber <sebastian.huber at embedded-brains.de>
>> Date:      Fri Sep 28 16:02:28 2012 +0200
>>   c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h |   13 +++++++++++++
>>   1 files changed, 13 insertions(+), 0 deletions(-)
>> diff --git a/c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h
>> b/c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h
>> index b486820..e1b1405 100644
>> --- a/c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h
>> +++ b/c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h
>> @@ -74,6 +74,19 @@ rtems_status_code bsp_register_i2c(void);
>>   void bsp_restart(void *addr);
>> +#if MPC55XX_CHIP_TYPE / 10 == 567
> Could you put parentheses around the "MPC55XX_CHIP_TYPE / 10"
> portion?
The operator precedence of "/" and "==" should be well known.
> And could you add a comment block explaining this?  Or even better what
> does 567 mean? Should that be a constant?
If you work with these chips it should be clear.  You can derive certain
features from the chip type.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
