undefined reference to libbsdport_netdriver_attach
SAeeD
salpha.2004 at gmail.com
Fri Sep 28 15:50:56 UTC 2012
> Did you add -lbsdports to the list of libraries you must link with ?
I added this option to LDFLAGS section and this is the new link error I
encounter:
i386-rtems4.10-gcc --pipe
-B/home/saeed/RTEMS/src/rtems-4.10.2/b-pc386/bsp-install/i386-rtems4.10/pc386/lib/
-specs bsp_specs -qrtems -g -Wall -O2 -g -g -mtune=i386
-Wl,-Ttext,0x00100000 -lbsdports -mtune=i386 -o
o-optimize/network-suite.exe o-optimize/init.o
/opt/rtems-4.10/lib/gcc/i386-rtems4.10/4.4.7/../../../../i386-rtems4.10/bin/ld:
cannot find -lbsdports
collect2: ld returned 1 exit status
make: *** [o-optimize/network-suite.exe] Error 1
I doubt that I've added the option correctly to my Makefile. I've attached
my Makefile.
Regards,
SAeeD
On Fri, Sep 28, 2012 at 2:13 AM, Chris Johns <chrisj at rtems.org> wrote:
> SAeeD wrote:
>> Is there any link options that I must add to my application's Makefile?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120928/579e13c1/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120928/579e13c1/attachment.obj>
