RFC: ARM GCC changes
Tue Sep 25 12:12:27 UTC 2012
On 09/25/2012 01:47 PM, Ralf Corsepius wrote:
> On 09/25/2012 12:36 PM, Chris Johns wrote:
>> Sebastian Huber wrote:
>>> On 09/25/2012 12:04 PM, Ralf Corsepius wrote:
>>>> On 09/25/2012 10:54 AM, Sebastian Huber wrote:
>>>>> This is an updated patch for the GCC 4.8. It renames the target
>>>>> "arm-rtemseabi" to "arm-rtems" to bring the ARM tool chain back to the
>>>>> standard RTEMS target pattern "$ARCH-rtems".
>>>> As I tried to tell you several times before, I consider this step
>>>> a) to be silly, because it raises abiguities to the "arm-rtems*"
>>>> target tuple
>>>> and breaks the clear distingtion between "arm-rtems" and
>>>> "arm-rtemseabi*" we
>>>> currently have.
>>> We have only one ARM tool chain configuration in the current RTEMS
>>> development version and this is arm-rtemseabi. The ARM tool chain is the
>>> only exception to the $ARCH-rtems pattern. This is confusing and leads
>>> to special cases in general support scripts.
> This doesn't mean much more but your scripts to be lacking generality.
We should keep things simple and don't introduce artificial burdens.
>>> There is absolutely no
>>> reason to have two ARM tool chain configuration for new versions of
>>> RTEMS.
> I vehemently disagree:
> * arm-rtems4.11/gcc-4.8 would be eabi.
Yes, this is the purpose of the patch.
> * arm-rtems/gcc-4.7 would fail to build
> * arm-rtems4.11/gcc-4.7 would expect *-eabi
> * arm-rtems4.11/gcc-4.6 would be abi.
This patch targets GCC 4.8.  The patches for GCC 4.6 and 4.7 are part of a
previous email.
> * arm-rtems* would apply conventions arm*eabi users do not expect.
RTEMS ARM users expect a functional tool chain with a standard name.  If a
RTEMS ARM user has a problem with this change, he can express his concerns here.
>> +1
>> Please make the change and remove the ARM ABI mess we have. Sebastian,
>> thanks for the patch.
> There is no mess, IMO, this all is bikesheding for no technical reasons but for
> personal reasons.
> All this patch would do is to replace a clear separation with a mess and cause
> further mess. Of course you (Chris) will not experience much of the mess
> Sebastian is causing, because you are not packing the toolchains.
Yes, there is a mess, but only because you ignore the advice from the GCC ARM
maintainer and me.
There is no need for a separation, because only the EABI variant is useful for
future RTEMS versions.  Why is this so difficult for you to accept?  The
transition to the EABI variant was a process of several years and RTEMS was one
of the last users that stuck with the totally obsolete and unmaintained variant.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
