Busy wait in network initialization
Fri Sep 28 14:20:42 UTC 2012
On 09/28/2012 03:49 PM, Eric Norum wrote:
> There are some places in the BSD network code (at the time, can't say for sure now) that assumed that this value could never be 0 -- they use 0 as a value meaning something special --  'time not set' or 'forever', things like that.
Ok, thanks for the hints.  In this case the implementation has a problem
unsigned long
rtems_bsdnet_seconds_since_boot (void)
	rtems_interval now;
	now = rtems_clock_get_ticks_since_boot();
	return now / rtems_bsdnet_ticks_per_second;
since rtems_clock_get_ticks_since_boot() will overflow regularly (e.g. 1ms tick
=> every 50 days).
Maybe we should change this to
unsigned long
	rtems_interval ticks;
	ticks = rtems_clock_get_ticks_since_boot();
	ticks /= rtems_bsdnet_ticks_per_second;
	return ticks != 0 ? ticks : 1;
and remove the busy loop?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
