Benchmark Apps for RTEMS
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Sun Apr 21 02:29:52 UTC 2013
>________________________________________
>From: Chris Johns [chrisj at rtems.org]
>Sent: Friday, April 19, 2013 8:50 PM
>To: Gedare Bloom
>Cc: Rempel, Cynthia; rtems-devel at rtems.org
>Subject: Re: Benchmark Apps for RTEMS
>Gedare Bloom wrote:
>> On Thu, Apr 18, 2013 at 3:06 PM, Rempel, Cynthia
>>> My understanding is we have been trying for months to get examples-v2 to be Waf-based, and because of the header problems, we have been unsuccessful so far.  Waf is a step up in complexity over a standard Makefile; if we go that route, we need the examples-v2 with a Waf build system publicly available as a reference first...
>> I don't know about the effort to port examples-v2 personally, so I
>> don't know what complications may exist. If the installed headers are
>> holding it up, and also would hold up any Waf-based kit
>> infrastructure, then the dependency and risk needs to be addressed.
>> But I would want to hear more detail about the problem before calling
>> it a blocker.
>The only block on getting this done is the need for me to eat and sleep ;)
>Someone just has to do the work. All we need is someone to step forward.
>I will help support them. Anyone ?
Thanks! The patch is located at:
http://www.rtems.org/ftp/pub/rtems/people/chrisj/examples-v2-waf.diff
I haven't tried it, but if the patched examples-v2-waf makes executables, it might be feasible to port simple applications using this method...
>>> Only a select few RTEMS developers know how to use Waf and we don't want this to be an elitist open-source project.  There needs to be a publically available tutorial for how to maintain a Waf-based build-system (I think its inadvisable that only a few people should have keys to the build-system kingdom)...
>> I don't have personal experience with Waf other than using it a couple
>> of times. I don't see Waf as an elitist project, but actually I think
>> it may be much more accessible than Make and auto* approaches. Waf has
>> quite good documentation about the Waf system and about how to build
>> custom build systems if we need such flexibility.
>I agree. I have also provided an example tarball in my ftp area with
>python code to hook to an installed RTEMS. If there are issues with that
>code please let me know.
http://www.rtems.org/ftp/pub/rtems/people/chrisj/rtems-waf/ looks promising, I'll give it a try next weekend!
>>> I will go along with doing a Waf-based build system, I would like to hear your refutations, but I think it's inadvisable to do so until the above issues are addressed.
>It is different to make and others and knowing Python helps. You need to
>invest a small amount of time in doing some examples and reading the waf
>book. If there is an interest I can run a Google Hangout and we can
>discuss using waf with RTEMS and how it works. This can be streamed to
>the RTEMS You Tube channel.
I'll be probably work helping with on porting rtems-testing to python, for a few weekends, to learn more about both...
Thanks for showing us this!
>Chris
