[PATCH] LM3S3749 BSP
Mon Apr 22 07:16:59 UTC 2013
Hello,
how similar are the LM3S3749 and lm3s69xx?  Is it possible to use one BSP
directory with some conditional compilation for both?
You can avoid hard coded values with BSP options, e.g.
RTEMS_BSPOPTS_SET([LPC24XX_OSCILLATOR_MAIN],[lpc23*],[3686400U])
RTEMS_BSPOPTS_SET([LPC24XX_OSCILLATOR_MAIN],[*],[12000000U])
RTEMS_BSPOPTS_HELP([LPC24XX_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
RTEMS_BSPOPTS_SET([LPC24XX_OSCILLATOR_RTC],[*],[32768U])
RTEMS_BSPOPTS_HELP([LPC24XX_OSCILLATOR_RTC],[RTC oscillator frequency in Hz])
RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc17xx_ea*],[96000000U])
RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc23*],[58982400U])
RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc24xx_plx800_*],[51612800U])
RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[*],[72000000U])
RTEMS_BSPOPTS_HELP([LPC24XX_CCLK],[CPU clock in Hz])
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
