Implementation of some of the well developed real time scheduling for rtems
Mon Apr 22 13:29:16 UTC 2013
If you can propose some specific scheduling algorithms for fault
tolerant or power-aware scheduling, then we can decide if it makes
sense. In general, I think it is a good idea. It will also give us
some idea about how well the scheduling framework is setup to support
such scheduling mechanisms. However, another student is proposing to
do some work also related to the scheduler framework itself, so we
need to be careful to avoid having too much conflict/overlap between
you two. I don't anticipate that there would be much problem.
-Gedare
On Sun, Apr 21, 2013 at 5:34 PM, Ye Xu <xy008areshsu at gmail.com> wrote:
> Hello all,
> Having looked into some of the info and documents available online, I am
> interested in implementing some of the well known scheduling algorithms in
> rtems kernel, specifically, I would like to implement Fault Tolerance
> Scheduling and/or Power Aware Scheduling, since these two areas are becoming
> increasingly important these days. Fault tolerance techniques are very
> critical for Hard Real time systems in order to improve the safety issues,
> whereas power aware techniques are important for almost all embedded system
> with limited powers.
> Is this a right direction to get started? I looked at the scheduling
> algorithms document for rtems 4.10.99:
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/c_user/Scheduling-Concepts-Scheduling-Algorithms.html#Scheduling-Concepts-Scheduling-Algorithms,
> and found out there are already a couple of fundamental algorithms
> implemented, but I haven't found any regarding fault tolerance and power
> aware, so I think this might be a good idea to propose.
> Thank you very much.
> Ye Xu
> Best Regards,
> Ares Hsu
> rtems-devel mailing list
> rtems-devel at rtems.org
