Newlib reentrancy
Mon Apr 22 13:55:47 UTC 2013
On 04/22/2013 03:46 PM, Gedare Bloom wrote:
>>>> The implementation of __getreent() for RTEMS is easy:
>>>> >>>struct _reent *__getreent(void)
>>>> >>>struct _reent *reent = _Thread_Executing->libc_reent;
>>>> >>>if ( reent == NULL ) {
>>>> >>>reent = _global_impure_ptr;
>>>> >>>return reent;
>>> >>Does this code need locking ?
>> >No, but I haven't tested anything yet.
> Seems right to me. Do we need the check for NULL though, or can we
> define the invariant that _Thread_Executing->libc_reent is valid
> pointer to the reent structure?
I want to avoid the every program needs a reference to the global reentrancy
structure.  We have the configuration option
CONFIGURE_DISABLE_NEWLIB_REENTRANCY.  In case this option is defined, then we
should initialize thread->libc_reent to NULL.  If we initialize it to
_global_impure_ptr, then we pull in the global reentrancy structure even if we
don't need it in the application.  If someone needs it, then he gets the
reference via __getreent().
Now I think that an even better approach is to define __getreent() in
confdefs.h depending on CONFIGURE_DISABLE_NEWLIB_REENTRANCY, e.g.
#ifdef CONFIGURE_DISABLE_NEWLIB_REENTRANCY
   return _global_impure_ptr;
#else
   return _Thread_Executing->libc_reent;
#endif
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
