[PATCH] README: Rewrite and reduce
Mon Apr 22 17:29:48 UTC 2013
Delete old bit-rotting README files and rewrite the README to point
readers toward authoritative sources of documentation.
 INSTALL          |   47 ------------
 README           |  100 +++----------------------
 README.cdn-X     |   73 ------------------
 README.configure |  222 ------------------------------------------------------
 4 files changed, 11 insertions(+), 431 deletions(-)
 delete mode 100644 INSTALL
 delete mode 100644 README.cdn-X
 delete mode 100644 README.configure
diff --git a/INSTALL b/INSTALL
deleted file mode 100644
index 5eee13e..0000000
--- a/INSTALL
+++ /dev/null
@@ -1,47 +0,0 @@
-Building RTEMS
-See the file README.configure.
-UNCOMPRESSING .tgz FILES
-Many of the files found in this directory and its subdirectories
-are gzip'ed, tar archive files.  These files have the ".tgz"
-extension.  They were compressed with gzip version 1.2.4.
-Use a command sequence similar to the following to uncompress each
-file:
-   gzcat FILE.tgz | tar xvof -
-where FILE.tgz is the file to be installed.  This procedure will
-extract the files in the archive into the current directory.
-All of the .tgz files associated with this release RTEMS will
-place their contents in a subdirectory rtems-<release> in the current
-directory.
-If you are unsure of what is in an RTEMS archive file, then use
-the following command sequence to get a listing of the contents:
-   gzcat FILE.tgz | tar tvf -
-NOTES:
-(1) The "-o" option to tar is included on the tar command line
-    so that the user extracting the tar archive will own the extracted
-    files.
-(2) gzcat is sometimes installed as zcat.  Be warned that on many
-    (most) UNIX machines, zcat is associated with compress (.Z files).
-(3) If you do not have gzip 1.2.4, it is available from numerous sites
-    including this one.  Other sites include ftp.gnu.org and ftp.cdrom.com.
-(4) The GNU archive files included in this distribution are packaged
-    exactly like they are on official GNU ftp sites.  When extracting
-    GNU archives, they will not extract under a rtems-<version>
-    directory.  They will extract themselves under a directory which
-    is the name and version of the tool in question.  For example,
-    gcc-2.5.8.tgz will extract its contents into the subdirectory
-    gcc-2.5.8.
diff --git a/README b/README
index 37aeed9..2c7c661 100644
--- a/README
+++ b/README
@@ -1,93 +1,15 @@
-Building RTEMS
+See the documentation manuals in doc/ with daily builds available online at
+http://rtems.org/onlinedocs/doc-current/share/rtems/html/ and released builds
+at http://www.rtems.org/onlinedocs/releases/
-Directory Overview
+See the RTEMS Wiki at http://wiki.rtems.org/wiki/index.php/Main_Page
+for community knowledge and tutorials.
-This is the top level of the RTEMS directory structure.  The following
-is a description of the files and directories in this directory:
+RTEMS Doxygen available at http://www.rtems.org/onlinedocs/doxygen/cpukit/html
-  INSTALL
-    Rudimentary installation instructions.  For more detailed
-    information please see the Release Notes.  The Postscript
-    version of this manual can be found in the file
-    c_or_ada/doc/relnotes.tgz.
+Get help on the mailing lists:
+* For general-purpose questions related to using RTEMS, use the
+  rtems-users ml: http://www.rtems.org/mailman/listinfo/rtems-users
+* For questions and discussion related to development of RTEMS, use the
+  rtems-devel ml: http://www.rtems.org/mailman/listinfo/rtems-devel
-  LICENSE
-    Required legalese.
-  README
-    This file.
-  c
-    This directory contains the source code for the C
-    implementation of RTEMS as well as the test suites, sample
-    applications, Board Support Packages, Device Drivers, and
-    support libraries.
-  doc
-    This directory contains the PDL for the RTEMS executive.
-Ada versus C
-There are two implementations of RTEMS in this source tree --
-in Ada and in C.  These two implementations are functionally
-and structurally equivalent.  The C implementation follows
-the packaging conventions and hierarchical nature of the Ada
-implementation.  In addition, a style has been followed which
-allows one to easily find the corresponding Ada and C
-implementations.
-File names in C and code placement was carefully designed to insure
-a close mapping to the Ada implementation.  The following file name
-extensions are used:
-   .adb - Ada body
-   .ads - Ada specification
-   .adp - Ada body requiring preprocessing
-   .inc - include file for .adp files
-   .c   - C body (non-inlined routines)
-   .inl - C body (inlined routines)
-   .h   - C specification
-In the executive source, XYZ.c and XYZ.inl correspond directly to a
-single XYZ.adb or XYZ.adp file.  A .h file corresponds directly to
-the .ads file.  There are only a handful of .inc files in the
-Ada source and these are used to insure that the desired simple
-inline textual expansion is performed.  This avoids scoping and
-calling convention side-effects in carefully constructed tests
-which usually test context switch behavior.
-In addition, in Ada code and data name references are always fully
-qualified as PACKAGE.NAME.  In C, this convention is followed
-by having the package name as part of the name itself and using a
-capital letter to indicate the presence of a "." level.  So we have
-PACKAGE.NAME in Ada and _Package_Name in C.  The leading "_" in C
-is used to avoid naming conflicts between RTEMS and user variables.
-By using these conventions, one can easily compare the C and Ada
-implementations.
-The most noticeable difference between the C and Ada83 code is
-the inability to easily obtain a "typed pointer" in Ada83.
-Using the "&" operator in C yields a pointer with a specific type.
-The 'Address attribute is the closest feature in Ada83.  This
-returns a System.Address and this must be coerced via Unchecked_Conversion
-into an access type of the desired type.  It is easy to view
-System.Address as similar to a "void *" in C, but this is not the case.
-A "void *" can be assigned to any other pointer type without an
-explicit conversion.
-The solution adopted to this problem was to provide two routines for
-each access type in the Ada implementation -- one to convert from
-System.Address to the access type and another to go the opposite
-direction.  This results in code which accomplishes the same thing
-as the corresponding C but it is easier to get lost in the clutter
-of the apparent subprogram invocations than the "less bulky"
-C equivalent.
-A related difference is the types which are only in Ada which are used
-for pointers to arrays.  These types do not exist and are not needed
-in the C implementation.
diff --git a/README.cdn-X b/README.cdn-X
index d259d5d..0000000
--- a/README.cdn-X
+++ /dev/null
@@ -1,73 +0,0 @@
-Building RTEMS Canadian Cross
-RTEMS now contains experimental and yet incomplete support for building
-it Canadian Cross.
-1. Introduction
-If you don't know what Canadian Cross Building means, you probably don't want
-to apply it and should consider stop reading here.
-Interested readers might want to read Ian Lance Taylor's article at
-http://www.airs.com/ian/configure for underlaying details and working
-principles.
-2. RTEMS
-Example: Building RTEMS for sparc-rtems under i386-pc-linux-gnu to be hosted
-on a i386-cygwin platform.
-2.1 Required tools
-* A i386-pc-linux-gnu cross sparc-rtems toolchain.
-* A i386-pc-linux-gnu cross i386-cygwin toolchain.
-* A i386-pc-linux-gnu native toolchain.
-We further on assume these to be installed to these locations:
-/opt/rtems .. linux cross sparc-rtems toolchain
-/opt/cygwin .. linux cross i386-cygwin cross-toolchain
-/usr .. linux native toolchain and further tools.
-2.2 Building sparc-rtems
-The first step is to build RTEMS for sparc-rtems under linux.
-mkdir build
-cd build
-<path>/rtems/configure [options] \
---target=sparc-rtems \
---prefix=/opt/cygwin
-make
-make install
-This will build a standard sparc-rtems RTEMS and install it to the given
-PREFIX.
-2.3 Building i386-cygwin host support
-The next step is to build RTEMS host support for i386-cygwin.
-This basically means to cross-build the host tools contained in RTEMS.
-mkdir host
-cd host
---build=`<path>/rtems/config.guess` \
---host=i386-cygwin \
-make
-make install
-This will build RTEMS host-tools for i386-cygwin and install them to the given
-PREFIX.
-3. Known issues
-* At present time, building RTEMS Canadian Cross is known to be immature, and
-to require additional work. Do not expect this to work.
-* The <toplevel>/make/ directory hierarchy is not treated correctly.
diff --git a/README.configure b/README.configure
index 6ca355e..0000000
--- a/README.configure
+++ /dev/null
@@ -1,222 +0,0 @@
-1. Autoconf support
-This version of RTEMS is configured with GNU autoconf. RTEMS can be
-configured and built either standalone or together with the compiler
-tools in the Cygnus one-tree structure. Using autoconf also means
-that RTEMS now can be built in a separate build directory.
-To re-generate auto*tool generated files (configure, Makefile.in etc),
-autoconf-2.68 and automake-1.11.1 are required.
-2. Installation
-To configure RTEMS for a specific target, run configure in the build
-directory. In addition to the standard configure options, the following
-RTEMS-specific option are supported:
-      --disable-rtems-inlines
-      --disable-posix
-      --disable-networking
-      --enable-cxx
-      --enable-multiprocessing
-      --enable-rtemsbsp="bsp1 bsp2 ..."
-      --enable-tests
-      --enable-rdbg            (only valid for i386 and some PowerPC BSPs)
-      --enable-docs
-In addition, the following standard autoconf options are frequently
-used when configuring RTEMS installations:
-      --prefix=INSTALL_DIRECTORY
-By default, inline routines are used instead of macros where possible.
-Macros can be selected using the --disable-inlines option.  [NOTE:
-Some APIs may not support macro versions of their inline routines.]
-By default, the RTEMS POSIX 1003.1b interface is built for targets that support
-it. It can be disabled with the --disable-posix option.
-By default, the RTEMS networking support is built for targets which
-support it.  It can be specifically disabled for those targets
-with the --disable-networking option.
-By default, the RTEMS remote debugger server support is not built.
-It can be specifically enabled for the targets that support it.
-with the --enable-rdbg option. NB : the RTEMS networking support
-must be enabled to support the remote debugger server.
-By default, the RTEMS support of C++ is disabled.  It can be enabled
-with the --enable-cxx option. If the rtems++ C++ library is installed
-it will also be build.
-By default, the RTEMS test suites are NOT configured -- only the
-sample tests are built.  --enable-tests will configure
-the RTEMS test suite. The default speeds up the build
-and configure process when the tests are not desired.
-By default, RTEMS is built using arguments and build rules which require a
-gcc supporting the -specs option, ie. a gcc >= 2.8.
-[The --disable-gcc28 option, which has been present in former releases, has
-been removed.]
-By default, multiprocessing is is not built.  It can be enabled
-for those BSPs supporting it by the --enable-multiprocessing option.
-By default, all bsps for a target are built. The bare BSP is not built
-unless directly specified. There are  two ways of changing this:
-+ use the --enable-rtemsbsp option which will set the specified
-  bsps as the default bsps, or
-+ set the RTEMS_BSP variable during make (see below).
-The --enable-rtemsbsp= option configures RTEMS for a specific board
-within a target architecture.  Remember that the target specifies the
-CPU family while the BSP specifies the precise board you will be using.
-The following targets are supported:
-      arm-rtems4.10
-      avr-rtems4.10
-      bfin-rtems4.10
-      h8300-rtems4.10
-      i386-rtems4.10
-      lm32-rtems4.10
-      m32c-rtems4.10
-      m32r-rtems4.10
-      m68k-rtems4.10
-      mips-rtems4.10
-      no_cpu-rtems4.10
-      powerpc-rtems4.10
-      sh-rtems4.10
-      sparc-rtems4.10
-The cross-compiler is set to $(target)-gcc by default.
-To build, run make in the build directory. To specify which bsps to build,
-add the RTEMS_BSP="bsp1 bsp2 .." to the make command.  Specifying multiple
-BSPs to build only works from the top level build directory.
-Installation is done under $(prefix)/rtems.
-As an example, to build and install the mvme136 and mvme162 bsps for m68k do:
-      (path_to_rtems_src)/configure --target=m68k-rtems4.11
-      make RTEMS_BSP="mvme136 mvme162"
-      make install RTEMS_BSP="mvme136 mvme162"
-The sample tests are built by 'make all' when configured with
---enable-tests=samples.  Use --enable-tests=all to build the full
-test suite.
-Documentation is built separately from the source code.
-3. To use the installed RTEMS library
-To use the installed RTEMS bsps to build applications, the application
-makefile has to include a bsp-specific makefile that will define the
-RTEMS variables necessary to find include files and libraries. The
-bsp-specific makefile is installed at
-      $(RTEMS_MAKEFILE_PATH)/Makefile.inc
-For the erc32 bsp installed at /usr/local/cross, the environment
-variable RTEMS_MAKEFILE_PATH would be set as follows to the
-following:
-/usr/local/cross/sparc-rtems/rtems/erc32/Makefile.inc
-4. Supported target bsps
-The following bsps are supported:
-arm             : csb336 csb337 edb7312 gba gp32 nds rtl22x rtl22xx_t
-                  smdk2410
-avr:            : avrtest
-bfin            : eZKit533 bf537Stamp
-h8300           : h8sim
-i386		: i386ex pc386 pc386dx pc486 pc586 pc686 pck6 ts_386ex
-		NOTE: The "pc386" BSP can be compiled to support a
-		      variety of PC configurations including PC-104
-		      based solutions.
-lm32:		: lm32_evr
-m32c		: m32csim
-m32r		: m32rsim
-m68k		: av5282 csb360 gen68302 gen68360 gen68360_040
-		genmcf548x idp mcf5206elite mcf52235 mcf5235 mcf5239
-		m5484FireEngine mrm332 mvme136 mvme147s mvme162 mvme162lx
-		mvme167 ods68302 pgh360 sim68000 simcpu32 uC5282 COBRA5475
-no_cpu          : no_bsp  (porting example)
-mips            : csb350 genmongoosev hurricane jmr3904 rbtx4925 rbtx4938
-		p4600 p4650
-powerpc		: brs5l ep1a gen5200 gen83xx haleakala hsc_cm01 icecube
-		mbx821_001 mbx821_002 mbx821_002b mbx860_001b mbx860_002
-		mbx860_005b mcp750 mvme2100 mvme2307 mtx603e
-		mvme5500 mpc55xxevb mpc8260ads mpc8313erdb mpc8349eamds
-		pghplus pm520_cr825 pm520_ze30 psim score603e ss555
-		tqm8xx_stk8xx virtex
-                  NOTE: The "motorola_powerpc" BSP is a single BSP which
-                  can be conditionally compiled to support most Motorola
-                  VMEbus, CompactPCI, and MTX boards.)
-                  NOTE: The mbx8xx, gen5200, gen83xx, and tqm8xx BSPs are
-		  designed to handle a variety of boards based on the same
-		  family of system on chips CPUs
-sh              : gensh1 gensh2 gensh4 simsh1 simsh2 simsh4
-sparc 		: erc32 sis leon2 leon3
-5. Makefile structure
-The makefiles have been re-organized. Most gnu-based bsps now use three
-main makefiles:
-    + custom/default.cfg,
-    + custom/bsp.cfg and
-    + compilers/gcc-target-default.cfg.
-Default.cfg sets the default values of certain common build options.
-Bsp.cfg set bsp-specific build options and can also override the
-default settings.
-Gcc-target-default.cfg contains the common gcc definitions.
-6. Adding a bsp
-Please refer to the BSP and Device Driver Guide.
-7. Tested configurations
-All gnu-based bsps have been built on Linux.
-8. Prerequisites
-Gawk version 2 or higher.
-GNU make version 3.72 or higher.
-Bash.
-gcc version > 2.8
-NOTE: These prerequisites are probably out of date but autoconf should detect
-      any problems.
1.7.1
