[PATCH] README: Rewrite and reduce
Tue Apr 23 13:19:12 UTC 2013
Hi Sebastian,
I made an effort to comply with the requirements listed in the GNU standard.
On Tue, Apr 23, 2013 at 3:36 AM, Sebastian Huber
> On 04/22/2013 07:29 PM, Gedare Bloom wrote:
>> Delete old bit-rotting README files and rewrite the README to point
>> readers toward authoritative sources of documentation.
>>   INSTALL          |   47 ------------
>>   README           |  100 +++----------------------
>>   README.cdn-X     |   73 ------------------
>>   README.configure |  222
>>   4 files changed, 11 insertions(+), 431 deletions(-)
>>   delete mode 100644 INSTALL
>>   delete mode 100644 README.cdn-X
>>   delete mode 100644 README.configure
> Thanks for cleaning this up.  I someone has the time, he can add things to
> the README required by the GNU standard:
> http://www.gnu.org/prep/standards/html_node/Releases.html
> rtems-devel mailing list
> rtems-devel at rtems.org
