[PATCH 7/8] libcsupport: Rename open_dev_console()
Thu Apr 25 09:20:00 UTC 2013
Rename open_dev_console() to rtems_libio_post_driver().  Rename
rtems_libio_supp_helper to rtems_libio_post_driver_helper.
 c/src/lib/libbsp/shared/bsppost.c              |    2 +-
 cpukit/libcsupport/include/rtems/libcsupport.h |    1 -
 cpukit/libcsupport/include/rtems/libio.h       |    4 ++--
 cpukit/libcsupport/src/open_dev_console.c      |    2 +-
 cpukit/sapi/include/confdefs.h                 |    4 ++--
 5 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/c/src/lib/libbsp/shared/bsppost.c b/c/src/lib/libbsp/shared/bsppost.c
index 351e4d7..24d13af 100644
--- a/c/src/lib/libbsp/shared/bsppost.c
+++ b/c/src/lib/libbsp/shared/bsppost.c
@@ -18,5 +18,5 @@
 void bsp_postdriver_hook(void)
-  (*rtems_libio_supp_helper)();
+  (*rtems_libio_post_driver_helper)();
diff --git a/cpukit/libcsupport/include/rtems/libcsupport.h b/cpukit/libcsupport/include/rtems/libcsupport.h
index 582e16b..8699ba9 100644
--- a/cpukit/libcsupport/include/rtems/libcsupport.h
+++ b/cpukit/libcsupport/include/rtems/libcsupport.h
@@ -67,7 +67,6 @@ extern void fix_syscall_errno(void);
  * Find amount of free heap remaining
 extern size_t malloc_free_space(void);
-extern void open_dev_console(void);
  * @brief Get malloc status information.
diff --git a/cpukit/libcsupport/include/rtems/libio.h b/cpukit/libcsupport/include/rtems/libio.h
index 02db6bb..ec2ced3 100644
--- a/cpukit/libcsupport/include/rtems/libio.h
+++ b/cpukit/libcsupport/include/rtems/libio.h
@@ -1390,13 +1390,13 @@ typedef void (*rtems_libio_helper)(void);
 extern const rtems_libio_helper rtems_libio_init_helper;
-extern const rtems_libio_helper rtems_libio_supp_helper;
+extern const rtems_libio_helper rtems_libio_post_driver_helper;
 extern const rtems_libio_helper rtems_fs_init_helper;
 void rtems_libio_helper_null(void);
-void open_dev_console(void);
+void rtems_libio_post_driver(void);
  * @brief Creates a directory and all its parent directories according to
diff --git a/cpukit/libcsupport/src/open_dev_console.c b/cpukit/libcsupport/src/open_dev_console.c
index d204dee..b678202 100644
--- a/cpukit/libcsupport/src/open_dev_console.c
+++ b/cpukit/libcsupport/src/open_dev_console.c
@@ -20,7 +20,7 @@
  *  This is a replaceable stub which opens the console, if present.
   int      stdin_fd;
   int      stdout_fd;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 04d8ae2..0d8c99b 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -99,11 +99,11 @@ const rtems_libio_helper rtems_libio_init_helper =
     rtems_libio_init;
   #endif
-const rtems_libio_helper rtems_libio_supp_helper =
+const rtems_libio_helper rtems_libio_post_driver_helper =
   #ifdef CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
     rtems_libio_helper_null;
   #else
-    open_dev_console;
+    rtems_libio_post_driver;
   #endif
 const rtems_libio_helper rtems_fs_init_helper =
1.7.7
