[PATCH 2/8] libcsupport: Delete REENT_MALLOCED define
Thu Apr 25 09:19:55 UTC 2013
 cpukit/libcsupport/src/newlibc_reent.c |   32 +++++---------------------------
 1 files changed, 5 insertions(+), 27 deletions(-)
diff --git a/cpukit/libcsupport/src/newlibc_reent.c b/cpukit/libcsupport/src/newlibc_reent.c
index e5a558c..3a4a065 100644
--- a/cpukit/libcsupport/src/newlibc_reent.c
+++ b/cpukit/libcsupport/src/newlibc_reent.c
@@ -48,13 +48,7 @@
 int _fwalk(struct _reent *ptr, int (*function) (FILE *) );
 extern struct _reent * const _global_impure_ptr __ATTRIBUTE_IMPURE_PTR__;
- * reent struct allocation moved here from libc_start_hook() to avoid
- * mutual exclusion problems when memory is allocated from the start hook.
- * Memory is also now allocated from the workspace rather than the heap.
- *  -- ptorre 9/30/03
 bool newlib_create_hook(
   rtems_tcb *current_task __attribute__((unused)),
   rtems_tcb *creating_task
@@ -69,19 +63,10 @@ bool newlib_create_hook(
     _Thread_Set_libc_reent (&_REENT);
-  /*  NOTE: The RTEMS malloc is reentrant without a reent ptr since
-   *        it is based on the Classic API Region Manager.
+  /* It is OK to allocate from the workspace because these
+   * hooks run with thread dispatching disabled.
-  #define REENT_MALLOCED 0
-  #if REENT_MALLOCED
-    ptr = (struct _reent *) calloc(1, sizeof(struct _reent));
-  #else
-    /* It is OK to allocate from the workspace because these
-     * hooks run with thread dispatching disabled.
-    ptr = (struct _reent *) _Workspace_Allocate(sizeof(struct _reent));
-  #endif
+  ptr = (struct _reent *) _Workspace_Allocate(sizeof(struct _reent));
   if (ptr) {
     _REENT_INIT_PTR((ptr)); /* GCC extension: structure constants */
@@ -135,10 +120,6 @@ void newlib_delete_hook(
   struct _reent *ptr;
-   * The reentrancy structure was allocated by newlib using malloc()
   if (current_task == deleted_task) {
     ptr = _REENT;
   } else {
@@ -154,11 +135,8 @@ void newlib_delete_hook(
      *  Just in case there are some buffers lying around.
     _fwalk(ptr, newlib_free_buffers);
-#if REENT_MALLOCED
-    free(ptr);
-#else
     _Workspace_Free(ptr);
-#endif
   deleted_task->libc_reent = NULL;
1.7.7
