priority inheritance algorithms
yangwei weiyang
wei.a.yang at gmail.com
Thu Apr 25 14:26:32 UTC 2013
2013/4/25 Pavel Pisa <ppisa4lists at pikron.com>
> Hello Deng Hengyi,
> On Thursday 25 April 2013 07:27:20 wei.a.yang wrote:
> > Hi, Pavel. Thank you for your advice. And in my former mail my proposal
> is
> > very similar with the mechanism in the Linux. But the different is that I
> > use two min-heap instead of two plist because of good algorithm
> complexity
> > of min-heap.
> It worth to evaluate what is better algorithm - RB-tree or min-heap.
> RB tree allows to use "static" nodes which are part of the task
> structure. The classic array base heap tree with 2n and 2n+1 children
> requires per queue array allocation and result in the limited/compile
> time defined depth or requires reallocations. But may it be you have
> other algorithm on mind.
> Yeah, now in my opinion the algorithm candidates are RB tree and
min-heap.
But just as you said the disadvantage of min-heap is its size allocation.
So i will
evalutate the two and select a more suitable for RTEMS. If you have any
more
better way please comment freely.
> > I have done some testing of RTEMS and Linux PI implementations.
> > > You can find my test code cor RTEMS classic API
> > > and POSIX RTEMS and Linux in the repo
> > Good work. But I want to know the mechanism of RTEMS test. You know there
> > are two PI algorithms in RTEMS. One is used by default, the other one
> > should define __RTEMS_STRICT_ORDER_MUTEX__ to use it. You test two
> > algorithms all?
> I have tested default one. The __RTEMS_STRICT_ORDER_MUTEX__ should
> behave as expected but there is risk that some code/libray we use
> does not access mutexes in the strict LIFO order.
> Best wishes,
> Pavel
Wei Yang
Best Regards
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130425/76b9d46b/attachment.html>
