CentOS 4.11 RTEMS VM cannot be upgraded?
Joel Sherrill Joel.Sherrill at OARcorp.com
Thu Apr 18 00:14:46 UTC 2013
This is because the kernel upgrade broke the virtualbox guest extensions. Please see http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
I should be on irc in the morning Chicago time of you need help.
--joel
Ye Xu <xy008areshsu at gmail.com> wrote:
Hello,
I loaded centOS virtual machine in virtual box and ran: yum upgrade. But after that, when I powered it off and started it again, it was stuck in the starting process and never finished. Does anyone else have this problem?
PS: my friend used windows OS and had the same problem. Before yum upgrade, he could reboot centOS VM, but after upgrading he just had the same problem as I did.
Best regards,
Ye Xu
Best Regards,
Ares Hsu
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130417/739955cf/attachment-0001.html>
