[PATCH 2/2] Initial bsp for Tiny6410
Thu Apr 18 16:50:32 UTC 2013
The previous version indicated you copied code from other parts of
RTEMS. If you retained the copied code, you should also retain the
code's copyright notice and add your own copyright if you made
changes.
On Thu, Apr 18, 2013 at 10:47 AM, Peng Fan <van.freenix at gmail.com> wrote:
>  c/src/lib/libbsp/arm/acinclude.m4                  |    2 +
>  c/src/lib/libbsp/arm/tiny6410/Makefile.am          |   62 ++++++
>  c/src/lib/libbsp/arm/tiny6410/README               |   39 ++++
>  c/src/lib/libbsp/arm/tiny6410/bsp_specs            |   13 ++
>  c/src/lib/libbsp/arm/tiny6410/configure.ac         |   23 ++
>  c/src/lib/libbsp/arm/tiny6410/console/uart.c       |  226 +++++++++++++++++++
>  c/src/lib/libbsp/arm/tiny6410/debug/debug.c        |   28 +++
>  c/src/lib/libbsp/arm/tiny6410/include/bsp.h        |   50 +++++
>  .../libbsp/arm/tiny6410/make/custom/tiny6410.cfg   |   21 ++
>  c/src/lib/libbsp/arm/tiny6410/preinstall.am        |   83 +++++++
>  c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c    |   21 ++
>  c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c   |   49 +++++
>  c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c   |   80 +++++++
>  .../libbsp/arm/tiny6410/startup/bspstarthooks.c    |  133 ++++++++++++
>  c/src/lib/libbsp/arm/tiny6410/startup/linkcmds     |   28 +++
>  c/src/lib/libbsp/arm/tiny6410/startup/memmap.c     |   27 +++
>  c/src/lib/libcpu/arm/Makefile.am                   |   25 +++
>  c/src/lib/libcpu/arm/configure.ac                  |    2 +
>  c/src/lib/libcpu/arm/preinstall.am                 |   13 ++
>  c/src/lib/libcpu/arm/s3c6410/clock/clockdrv.c      |  144 +++++++++++++
>  c/src/lib/libcpu/arm/s3c6410/clock/support.c       |   55 +++++
>  c/src/lib/libcpu/arm/s3c6410/include/s3c6410.h     |  227 ++++++++++++++++++++
>  c/src/lib/libcpu/arm/s3c6410/include/s3c64xx.h     |   20 ++
>  c/src/lib/libcpu/arm/s3c6410/irq/irq.c             |   84 ++++++++
>  c/src/lib/libcpu/arm/s3c6410/irq/irq.h             |   98 +++++++++
>  25 files changed, 1553 insertions(+)
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/Makefile.am
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/README
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/bsp_specs
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/configure.ac
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/console/uart.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/debug/debug.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/include/bsp.h
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/preinstall.am
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
>  create mode 100644 c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/clock/clockdrv.c
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/clock/support.c
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/include/s3c6410.h
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/include/s3c64xx.h
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/irq/irq.c
>  create mode 100644 c/src/lib/libcpu/arm/s3c6410/irq/irq.h
> diff --git a/c/src/lib/libbsp/arm/acinclude.m4 b/c/src/lib/libbsp/arm/acinclude.m4
> index 9512b26..277c144 100644
> --- a/c/src/lib/libbsp/arm/acinclude.m4
> +++ b/c/src/lib/libbsp/arm/acinclude.m4
> @@ -30,6 +30,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>      AC_CONFIG_SUBDIRS([smdk2410]);;
>    stm32f4 )
>      AC_CONFIG_SUBDIRS([stm32f4]);;
> +  tiny6410 )
> +    AC_CONFIG_SUBDIRS([tiny6410]);;
>      AC_MSG_ERROR([Invalid BSP]);;
>    esac
> diff --git a/c/src/lib/libbsp/arm/tiny6410/Makefile.am b/c/src/lib/libbsp/arm/tiny6410/Makefile.am
> new file mode 100644
> index 0000000..f01c45a
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/Makefile.am
> @@ -0,0 +1,62 @@
> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
> +include $(top_srcdir)/../../../../automake/compile.am
> +include_bspdir = $(includedir)/bsp
> +dist_project_lib_DATA = bsp_specs
> +include_HEADERS = include/bsp.h
> +include_HEADERS += ../../shared/include/tm27.h
> +include_bsp_HEADERS = ../shared/include/start.h
> +include_bsp_HEADERS += ../shared/include/linker-symbols.h
> +nodist_include_HEADERS = include/bspopts.h
> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> +DISTCLEANFILES = include/bspopts.h
> +nodist_include_HEADERS += ../../shared/include/coverhd.h
> +noinst_LIBRARIES = libbspstart.a
> +libbspstart_a_SOURCES = ../shared/start/start.S
> +#libbspstart_a_SOURCES = start/start.S
> +project_lib_DATA = start.$(OBJEXT)
> +dist_project_lib_DATA += startup/linkcmds
> +noinst_LIBRARIES += libbsp.a
> +libbsp_a_SOURCES =
> +# startup
> +libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> +libbsp_a_SOURCES += ../../shared/bsplibc.c ../../shared/bsppost.c \
> +    ../../shared/bsppredriverhook.c ../../shared/bspgetworkarea.c \
> +    ../../shared/bsppretaskinghook.c startup/bspstart.c startup/bspidle.c \
> +    ../../shared/bspclean.c startup/bspreset.c \
> +    startup/memmap.c ../../shared/bootcard.c ../../shared/sbrk.c \
> +    ../../shared/gnatinstallhandler.c startup/bspstarthooks.c
> +# low-level debug
> +libbsp_a_SOURCES += debug/debug.c
> +# console
> +libbsp_a_SOURCES += console/uart.c ../../shared/console.c \
> +    ../../shared/console_select.c  ../../shared/console_control.c \
> +    ../../shared/console_read.c ../../shared/console_write.c
> +# IRQ
> +include_bsp_HEADERS += ../../shared/include/irq-generic.h \
> +       ../../shared/include/irq-info.h
> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
> +libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
> +libbsp_a_SOURCES += ../../shared/src/irq-server.c
> +libbsp_a_SOURCES += ../../shared/src/irq-shell.c
> +# abort
> +libbsp_a_SOURCES += ../shared/abort/abort.c
> +libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
> +    ../../../libcpu/@RTEMS_CPU@/s3c6410/clock.rel \
> +    ../../../libcpu/@RTEMS_CPU@/s3c6410/irq.rel
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/../../../../automake/local.am
> diff --git a/c/src/lib/libbsp/arm/tiny6410/README b/c/src/lib/libbsp/arm/tiny6410/README
> index 0000000..fc15796
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/README
> @@ -0,0 +1,39 @@
> +This is the BSP for FriendlyARM tiny6410 board, a single board
> +computer using the Samsung S3C6410 SoC CPU.
> +S3C6410 is an arm1176jzf-s processor. About the mmu related,
> +here still use the arm920 mmu management.This may be seperated,
> +for there may some difference between 920 and 1176jzf-s.
> +Most of the hardware configuration is done in uboot.This maybe
> +migrated to rtems from uboot in future.
> +Now only serial and timer is supported, other IP modules' driver
> +will be added in future.
> +hello.exe ticker.exe nsecs.exe fileio runs. Others have not been
> +tested.
> +How to use this bsp
> +1.When downloaded the source, first "bootstrap -c; bootstrap -p;
> +bootstrap"
> +2.Look at the following script to configure for this bsp
> +3.use dnw,tftp or other ways to download the bin file to 0xC0104000
> +       MINI6410 # dnw 0xc0104000
> +       When finished download, use go command to run the bin file
> +       MINI6410 # go 0xc0104000
> +script:
> +#!/bin/sh
> +mkdir build
> +cd build
> +../rtems/configure --target=arm-rtemseabi4.11 \
> +--enable-rtemsbsp="tiny6410" --enable-test=samples --disable-posix
> +rm `find . -name hello.exe`
> +gmake all
> +rm hello.*
> +rm init.*
> +cp  -f `find . -name hello.exe` .
> +cp arm-rtemseabi4.11/c/tiny6410/testsuites/samples/hello/init.o .
> +arm-rtemseabi4.11-objcopy -O binary -S hello.exe hello.bin
> +arm-rtemseabi4.11-objdump -D hello.exe > hello.s
> +arm-rtemseabi4.11-objdump -D init.o > init.s
> diff --git a/c/src/lib/libbsp/arm/tiny6410/bsp_specs b/c/src/lib/libbsp/arm/tiny6410/bsp_specs
> index 0000000..082653a
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/bsp_specs
> @@ -0,0 +1,13 @@
> +%rename endfile old_endfile
> +%rename startfile old_startfile
> +%rename link old_link
> +*startfile:
> +%{!qrtems: %(old_startfile)} \
> +%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
> +*link:
> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
> +*endfile:
> +%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
> diff --git a/c/src/lib/libbsp/arm/tiny6410/configure.ac b/c/src/lib/libbsp/arm/tiny6410/configure.ac
> index 0000000..11966e0
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/configure.ac
> @@ -0,0 +1,23 @@
> +## Process this file with autoconf to produce a configure script.
> +AC_PREREQ([2.69])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-tiny6410],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> +AC_CONFIG_SRCDIR([bsp_specs])
> +RTEMS_TOP(../../../../../..)
> +RTEMS_CANONICAL_TARGET_CPU
> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> +RTEMS_BSP_CONFIGURE
> +RTEMS_PROG_CC_FOR_TARGET
> +RTEMS_CANONICALIZE_TOOLS
> +RTEMS_PROG_CCAS
> +RTEMS_CHECK_NETWORKING
> +AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
> +RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
> +# Explicitly list all Makefiles here
> +AC_CONFIG_FILES([Makefile])
> +AC_OUTPUT
> diff --git a/c/src/lib/libbsp/arm/tiny6410/console/uart.c b/c/src/lib/libbsp/arm/tiny6410/console/uart.c
> index 0000000..9501207
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/console/uart.c
> @@ -0,0 +1,226 @@
> + * console driver for S3C6410 UARTs
> + * This driver uses the shared console driver in
> + * ...../libbsp/shared/console.c
> + * If you want the driver to be interrupt driven, you
> + * need to write the ISR, and in the ISR insert the
> + * chars into termios's queue.
> + * Copyright (c) 2013 by PengFan <van.freenix at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#include <bsp.h>                /* Must be before libio.h */
> +#include <rtems/libio.h>
> +#include <termios.h>
> +#include <rtems/bspIo.h>
> +/* Put the CPU (or UART) specific header file #include here */
> +#include <s3c64xx.h>
> +#include <libchip/serial.h>
> +#include <libchip/sersupp.h>
> +/* How many serial ports? */
> +#define NUM_DEVS       1
> +int uart_poll_read(int minor);
> +int dbg_dly;
> +/* static function prototypes */
> +static int     uart_first_open(int major, int minor, void *arg);
> +static int     uart_last_close(int major, int minor, void *arg);
> +static int     uart_read(int minor);
> +static ssize_t uart_write(int minor, const char *buf, size_t len);
> +static void    uart_init(int minor);
> +static void    uart_write_polled(int minor, char c);
> +static int     uart_set_attributes(int minor, const struct termios *t);
> +/* These are used by code in console.c */
> +unsigned long Console_Configuration_Count = NUM_DEVS;
> +/* Pointers to functions for handling the UART. */
> +const console_fns uart_fns =
> +    libchip_serial_default_probe,
> +    uart_first_open,
> +    uart_last_close,
> +    uart_read,
> +    uart_write,
> +    uart_init,
> +    uart_write_polled,   /* not used in this driver */
> +    uart_set_attributes,
> +    FALSE      /* TRUE if interrupt driven, FALSE if not. */
> + * There's one item in array for each UART.
> + * Some of these fields are marked "NOT USED". They are not used
> + * by console.c, but may be used by drivers in libchip
> +console_tbl Console_Configuration_Ports[] = {
> +        "/dev/com0",                      /* sDeviceName */
> +        SERIAL_CUSTOM,                    /* deviceType */
> +        &uart_fns,                        /* pDeviceFns */
> +        NULL,                             /* deviceProbe */
> +        NULL,                             /* pDeviceFlow */
> +        0,                                /* ulMargin - NOT USED */
> +        0,                                /* ulHysteresis - NOT USED */
> +        NULL,                             /* pDeviceParams */
> +        0,                                /* ulCtrlPort1  - NOT USED */
> +        0,                                /* ulCtrlPort2  - NOT USED */
> +        0,                                /* ulDataPort  - NOT USED */
> +        NULL,                             /* getRegister - NOT USED */
> +        NULL,                             /* setRegister - NOT USED */
> +        NULL,                             /* getData - NOT USED */
> +        NULL,                             /* setData - NOT USED */
> +        0,                                /* ulClock - NOT USED */
> +        0                                 /* ulIntVector - NOT USED */
> +/* Functions called via termios callbacks (i.e. the ones in uart_fns */
> + * This is called the first time each device is opened. If the driver
> + * is interrupt driven, you should enable interrupts here. Otherwise,
> + * it's probably safe to do nothing.
> + * Since micromonitor already set up the UART, we do nothing.
> +    return 0;
> + * This is called the last time each device is closed. If the driver
> + * is interrupt driven, you should disable interrupts here. Otherwise,
> +    return 0;
> + * Read one character from UART.
> + * Return -1 if there's no data, otherwise return
> + * the character in lowest 8 bits of returned int.
> +    char c;
> +    if (minor == 0) {
> +        if (rUTRSTAT0 & 0x1) {
> +            c = rURXH0 & 0xff;
> +            return c;
> +        } else {
> +            return -1;
> +    } else {
> +        printk("Unknown console minor number: %d\n", minor);
> +        return -1;
> + * Write buffer to UART
> + * return 1 on success, -1 on error
> +    int i;
> +    if (minor == 0) {
> +        for (i = 0; i < len; i++) {
> +            /* Wait for fifo to have room */
> +            while(!(rUTRSTAT0 & 0x2)) {
> +                continue;
> +           rUTXH0 = (char) buf[i];
> +    } else {
> +        return -1;
> +    return 1;
> +/* Set up the UART. */
> +       int i;
> +       unsigned int reg = 0;
> +       /* Migrate the configuration from uboot in future */
> +       printk("%s\n", __func__);
> +/* I'm not sure this is needed for the shared console driver. */
> +    uart_write(minor, &c, 1);
> +/* This is for setting baud rate, bits, etc. */
> +    return 0;
> + * The following functions are not used by TERMIOS, but other RTEMS
> + * functions use them instead.
> + * Read from UART. This is used in the exit code, and can't
> + * rely on interrupts.
> +    return uart_read(minor);
> + * Write a character to the console. This is used by printk() and
> + * maybe other low level functions. It should not use interrupts or any
> + * RTEMS system calls. It needs to be very simple
> +static void _BSP_put_char( char c ) {
> +    uart_write_polled(0, c);
> +    if (c == '\n') {
> +        uart_write_polled(0, '\r');
> +BSP_output_char_function_type BSP_output_char = _BSP_put_char;
> +static int _BSP_get_char(void)
> +  return uart_poll_read(0);
> +BSP_polling_getchar_function_type BSP_poll_char = _BSP_get_char;
> diff --git a/c/src/lib/libbsp/arm/tiny6410/debug/debug.c b/c/src/lib/libbsp/arm/tiny6410/debug/debug.c
> index 0000000..91f2be9
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/debug/debug.c
> @@ -0,0 +1,28 @@
> + * Low level debug function
> +#include <bsp.h>
> +/*  rGPKDAT = 0:led on ; rGPKDAT = 1:led off
> + *  the four leds is connected with GPK4-7
> +void led_on()
> +       rGPKCON0 = (0x1111<<16)| (rGPKCON0 & 0xffff);
> +       rGPKDAT &= ~(0xf << 4);
> +void led_off()
> +       rGPKDAT |= 0xf << 4;
> diff --git a/c/src/lib/libbsp/arm/tiny6410/include/bsp.h b/c/src/lib/libbsp/arm/tiny6410/include/bsp.h
> index 0000000..9540b1c
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/include/bsp.h
> @@ -0,0 +1,50 @@
> +/* bsp.h
> +#ifndef _BSP_H
> +#define _BSP_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <bspopts.h>
> +#include <bsp/default-initial-extension.h>
> +#include <rtems.h>
> +#include <rtems/iosupp.h>
> +#include <rtems/console.h>
> +#include <rtems/clockdrv.h>
> +/*functions to get the differents s3c6410 clks*/
> +uint32_t get_FCLK(void);
> +uint32_t get_HCLK(void);
> +uint32_t get_PCLK(void);
> +uint32_t get_UCLK(void);
> + *  This BSP provides its own IDLE thread to override the RTEMS one.
> + *  So we prototype it and define the constant confdefs.h expects
> + *  to configure a BSP specific one.
> +void *bsp_idle_thread(uintptr_t ignored);
> +#define BSP_IDLE_TASK_BODY bsp_idle_thread
> +#ifdef __cplusplus
> +#endif
> +#endif /* _BSP_H */
> diff --git a/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg b/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
> index 0000000..44b0ca6
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/make/custom/tiny6410.cfg
> @@ -0,0 +1,21 @@
> +#  Config file for ARM S3C6410
> +include $(RTEMS_ROOT)/make/custom/default.cfg
> +RTEMS_CPU=arm
> +RTEMS_CPU_MODEL=s3c6410
> +#  This contains the compiler options necessary to select the CPU model
> +#  and (hopefully) optimize for it.
> +CPU_CFLAGS = -mstructure-size-boundary=32 -mcpu=arm1176jzf-s -mfpu=vfp -mfloat-abi=soft -DCPU_S3C6410
> +# optimize flag: typically -O2
> +CFLAGS_OPTIMIZE_V = -O2 -g
> +define bsp-post-link
> +       $(OBJCOPY) -O binary $(basename $@).exe $(basename $@)$(DOWNEXT)
> +       $(default-bsp-post-link)
> +endef
> diff --git a/c/src/lib/libbsp/arm/tiny6410/preinstall.am b/c/src/lib/libbsp/arm/tiny6410/preinstall.am
> index 0000000..ca20008
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/preinstall.am
> @@ -0,0 +1,83 @@
> +## Automatically generated by ampolish3 - Do not edit
> +if AMPOLISH3
> +$(srcdir)/preinstall.am: Makefile.am
> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> +endif
> +PREINSTALL_DIRS =
> +DISTCLEANFILES += $(PREINSTALL_DIRS)
> +all-local: $(TMPINSTALL_FILES)
> +TMPINSTALL_FILES =
> +CLEANFILES = $(TMPINSTALL_FILES)
> +all-am: $(PREINSTALL_FILES)
> +PREINSTALL_FILES =
> +CLEANFILES += $(PREINSTALL_FILES)
> +$(PROJECT_LIB)/$(dirstamp):
> +       @$(MKDIR_P) $(PROJECT_LIB)
> +       @: > $(PROJECT_LIB)/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
> +$(PROJECT_INCLUDE)/$(dirstamp):
> +       @$(MKDIR_P) $(PROJECT_INCLUDE)
> +       @: > $(PROJECT_INCLUDE)/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
> +       @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
> +$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
> +$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
> +$(PROJECT_INCLUDE)/bsp/linker-symbols.h: ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
> +PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
> +$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c b/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
> index 0000000..d8aca1c
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspidle.c
> @@ -0,0 +1,21 @@
> + * BSP specific Idle thread
> +#include <bsp.h>
> +  while(1) {
> +    __asm__ volatile ("MCR p15,0,r0,c7,c0,4     \n");
> +  return NULL;
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c b/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
> index 0000000..baf2320
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspreset.c
> @@ -0,0 +1,49 @@
> + * Bsp Reset
> +#include <bsp.h>
> +void bsp_reset(void)
> +  rtems_interrupt_level level;
> +  rtems_interrupt_disable(level);
> +  /* disable mmu, invalide i-cache, clean and invalidate d-cache
> +        * and mov pc to 0 */
> +  __asm__ volatile(""
> +    "mrc    p15,0,r0,c1,c0,0  \n"
> +    "bic    r0,r0,#1          \n"
> +    "mcr    p15,0,r0,c1,c0,0  \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "mov    r0,#0             \n"
> +    "MCR    p15,0,r0,c7,c5,0  \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "mov    r0,#0             \n"
> +    "MCR    p15,0,r0,c7,c14,0 \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +    "nop                      \n"
> +               "ldr            pc,                                             =0x0"
> +    : "r0"
> +  /* we should be back in bios now */
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c b/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
> index 0000000..d6edecf
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspstart.c
> @@ -0,0 +1,80 @@
> + * This file contains the ARM BSP startup package. It includes application,
> + * board, and monitor specific initialization and configuration. The generic CPU
> + * dependent initialization has been performed before this routine is invoked.
> +#include <bsp.h>
> +#include <bsp/irq-generic.h>
> + * External Prototypes
> +extern void rtems_exception_init_mngt(void);
> + *  BSP Specific Initialization in C
> +void bsp_start_default( void )
> +  uint32_t cr;
> +  uint32_t pend,last;
> +  uint32_t REFCNT;
> +  uint32_t i;
> +  /* stop RTC */
> +  rTICCNT = 0x0;
> +  /* stop watchdog,ADC and timers */
> +  rWTCON = 0x0;
> +  rTCON = 0x0;
> +  rADCCON = 0x0;
> +  /* disable interrupts */
> +  rVIC0_INTENCLEAR = 0x0;
> +  rVIC1_INTENCLEAR = 0x0;
> +  /* interrupt select, irq or fiq?*/
> +  rVIC0_INTSELECT = 0x0;
> +  rVIC1_INTSELECT = 0x0;
> +  /* clear external interrupt pending*/
> +  rEINT0PEND = ~0x0; /* write 1 to clear */
> +  /* clear pending interrupt */
> +  rVIC0_ADDRESS = 0x0;
> +  rVIC1_ADDRESS = 0x0;
> +#if 0
> +  /* system clock may be migrated to here from uboot */
> +  /* setup clocks */
> +#endif
> +       led_off();
> +   * Init rtems exceptions management
> +  rtems_exception_init_mngt();
> +   * Init rtems interrupt management
> +  bsp_interrupt_initialize();
> + *  By making this a weak alias for bsp_start_default, a brave soul
> + *  can override the actual bsp_start routine used.
> +void bsp_start (void) __attribute__ ((weak, alias("bsp_start_default")));
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
> index 0000000..6950d2e
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/bspstarthooks.c
> @@ -0,0 +1,133 @@
> +#include <bsp.h>
> +#include <bsp/start.h>
> +#include <bsp/irq.h>
> +#include <bsp/linker-symbols.h>
> +#include <libcpu/arm-cp15.h>
> +#include <libcpu/mmu.h>
> +extern void bsp_reset(void);
> +void SWI_Handler(void)
> +       while(1);
> +static BSP_START_TEXT_SECTION void clear_bss(void)
> +  const int *end = (const int *) bsp_section_bss_end;
> +  int *out = (int *) bsp_section_bss_begin;
> +  /* Clear BSS */
> +  while (out != end) {
> +    *out = 0;
> +    ++out;
> +extern mmu_sect_map_t mem_map[];
> +static BSP_START_TEXT_SECTION void setup_mmu_and_cache(void)
> +  uint32_t ctrl = 0;
> +  /* Disable MMU and cache, basic settings */
> +  ctrl = arm_cp15_get_control();
> +  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
> +    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
> +  ctrl |=  ARM_CP15_CTRL_A;
> +  arm_cp15_set_control(ctrl);
> +  arm_cp15_data_cache_clean_and_invalidate();
> +  arm_cp15_cache_invalidate(); //cache clean and invalidate ??
> +  arm_cp15_tlb_invalidate();
> +  #ifndef S3C64XX_DISABLE_MMU
> +    mmu_init(mem_map);
> +  #endif
> +static BSP_START_TEXT_SECTION void setup_pll(void)
> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
> +  setup_pll();
> +  setup_mmu_and_cache();
> +static BSP_START_TEXT_SECTION void stop_dma_activities(void)
> +static BSP_START_TEXT_SECTION void setup_uarts(void)
> +static BSP_START_TEXT_SECTION void setup_timer(void)
> +       /* May be removed */
> +#if 0
> +/* vector_begin will be copied to address 0 */
> +/* Keep here for future use */
> +uint32_t vector_begin[] = {
> +       0xe59ff018, //ldr     pc, [pc, #24]
> +       0xe59ff018,
> +       0xe59ff018,
> +       0xe59ff018,
> +       0xe59ff018,
> +       0xe320f000, //nop
> +       0xe59ff018,
> +       0xe59ff018,
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +       0xe320f000, //nop
> +#endif
> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
> +  int i = 0;
> +  stop_dma_activities();
> +  setup_uarts();
> +  setup_timer();
> +  arm_cp15_cache_invalidate(); //??
> +  /* Copy vector table to address 0*/
> +  bsp_start_memcpy(
> +         (int *)0,
> +         (const int*)bsp_start_vector_table_begin,
> +         (size_t)64
> +  /* VIC is not enabled for this vector interrupt processor,
> +   * This may be done in the future to use vector interrupt.
> +  /* Clear .bss section */
> +  clear_bss();
> +  /* At this point we can use objects outside the .start section */
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds b/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
> index 0000000..e148ada
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/linkcmds
> @@ -0,0 +1,28 @@
> +MEMORY {
> +       SDRAM_INTERRUPT : ORIGIN = 0x50000000, LENGTH = 4k
> +       SDRAM_MMU : ORIGIN = 0x50100000, LENGTH = 16k
> +       SDRAM : ORIGIN = 0x50104000, LENGTH = 128M - 1M - 16k
> +REGION_ALIAS ("REGION_START", SDRAM);
> +REGION_ALIAS ("REGION_VECTOR", SDRAM);
> +REGION_ALIAS ("REGION_TEXT", SDRAM);
> +REGION_ALIAS ("REGION_TEXT_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_RODATA", SDRAM);
> +REGION_ALIAS ("REGION_RODATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_DATA", SDRAM);
> +REGION_ALIAS ("REGION_DATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_FAST_TEXT", SDRAM);
> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_FAST_DATA", SDRAM);
> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", SDRAM);
> +REGION_ALIAS ("REGION_BSS", SDRAM);
> +REGION_ALIAS ("REGION_WORK", SDRAM);
> +REGION_ALIAS ("REGION_STACK", SDRAM);
> +_ttbl_base = ORIGIN (SDRAM_MMU);
> +bsp_stack_svc_size = DEFINED (bsp_stack_svc_size) ? bsp_stack_svc_size : 4096;
> +bsp_stack_svc_size = ALIGN (bsp_stack_svc_size, bsp_stack_align);
> +INCLUDE linkcmds.armv4
> diff --git a/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c b/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
> index 0000000..b79973e
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/tiny6410/startup/memmap.c
> @@ -0,0 +1,27 @@
> + *  s3c6410 Memory Map
> + *  Copyright (c) 2013 by PengFan van.freenix at gmail.com
> +#include <rtems.h>
> +/*ARM1176jzf-s consider TLB related*/
> +/*Here not implement 2-level page table considering tlb miss
> +  Maybe a tlb management structure should be implemented.
> +       To real time task, TLB entry is locked and should not incur
> +       TLB miss. But to non real time task, TLB miss is not cared
> +       Not sure about this. May have a try to do this in future
> +mmu_sect_map_t mem_map[] = {
> +/*  <phys addr>  <virt addr> <size> <flags> */
> +    {0x00000000, 0x00000000, 4096, MMU_CACHE_NONE},
> +    {0x50000000, 0x00000000, 1, MMU_CACHE_NONE},
> +    {0x50000000, 0x50000000, 128, MMU_CACHE_NONE},
> +    {0x00000000, 0x00000000,   0,    0}                   /* The end */
> diff --git a/c/src/lib/libcpu/arm/Makefile.am b/c/src/lib/libcpu/arm/Makefile.am
> index e488c45..880a726 100644
> --- a/c/src/lib/libcpu/arm/Makefile.am
> +++ b/c/src/lib/libcpu/arm/Makefile.am
> @@ -157,6 +157,31 @@ s3c24xx_irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
>  s3c24xx_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>  endif
> +if s3c6410
> +include_HEADERS = s3c6410/include/s3c64xx.h s3c6410/include/s3c6410.h
> +## s3c6410/clock
> +noinst_PROGRAMS += s3c6410/clock.rel
> +s3c6410_clock_rel_SOURCES = s3c6410/clock/clockdrv.c s3c6410/clock/support.c
> +s3c6410_clock_rel_CPPFLAGS = $(AM_CPPFLAGS)
> +s3c6410_clock_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +## s3c6410/timer
> +#noinst_PROGRAMS += s3c6410/timer.rel
> +#s3c6410_timer_rel_SOURCES = s3c6410/timer/timer.c
> +#s3c6410_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
> +#s3c6410_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +## s3c6410/interrupt
> +include_bsp_HEADERS += s3c6410/irq/irq.h
> +noinst_PROGRAMS += s3c6410/irq.rel
> +s3c6410_irq_rel_SOURCES = s3c6410/irq/irq.c \
> +    s3c6410/irq/irq.h
> +s3c6410_irq_rel_CPPFLAGS = $(AM_CPPFLAGS)
> +s3c6410_irq_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
> +endif
>  if lpc22xx
>  include_HEADERS = lpc22xx/include/lpc22xx.h
> diff --git a/c/src/lib/libcpu/arm/configure.ac b/c/src/lib/libcpu/arm/configure.ac
> index ae0967b..5c36803 100644
> --- a/c/src/lib/libcpu/arm/configure.ac
> +++ b/c/src/lib/libcpu/arm/configure.ac
> @@ -23,6 +23,7 @@ AM_CONDITIONAL(shared, test "$RTEMS_CPU_MODEL" = "at91rm9200" || \
>                        test "$RTEMS_CPU_MODEL" = "mc9328mxl" || \
>                        test "$RTEMS_CPU_MODEL" = "s3c2410" || \
>                        test "$RTEMS_CPU_MODEL" = "s3c2400" || \
> +                      test "$RTEMS_CPU_MODEL" = "s3c6410" || \
>                        test "$RTEMS_CPU_MODEL" = "pxa255")
>  AM_CONDITIONAL(at91rm9200, test "$RTEMS_CPU_MODEL" = "at91rm9200")
> @@ -31,6 +32,7 @@ AM_CONDITIONAL(lpc22xx, test "$RTEMS_CPU_MODEL" = "lpc22xx")
>  AM_CONDITIONAL(pxa255, test "$RTEMS_CPU_MODEL" = "pxa255")
>  AM_CONDITIONAL(s3c24xx, test "$RTEMS_CPU_MODEL" = "s3c2400" ||\
>                          test "$RTEMS_CPU_MODEL" = "s3c2410")
> +AM_CONDITIONAL(s3c6410, test "$RTEMS_CPU_MODEL" = "s3c6410")
>  RTEMS_AMPOLISH3
> diff --git a/c/src/lib/libcpu/arm/preinstall.am b/c/src/lib/libcpu/arm/preinstall.am
> index 751a085..19765e2 100644
> --- a/c/src/lib/libcpu/arm/preinstall.am
> +++ b/c/src/lib/libcpu/arm/preinstall.am
> @@ -113,6 +113,19 @@ $(PROJECT_INCLUDE)/bsp/irq.h: s3c24xx/irq/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstam
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>  PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>  endif
> +if s3c6410
> +$(PROJECT_INCLUDE)/s3c64xx.h: s3c6410/include/s3c64xx.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/s3c64xx.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/s3c64xx.h
> +$(PROJECT_INCLUDE)/s3c6410.h: s3c6410/include/s3c6410.h $(PROJECT_INCLUDE)/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/s3c6410.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/s3c6410.h
> +$(PROJECT_INCLUDE)/bsp/irq.h: s3c6410/irq/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
> +endif
>  if lpc22xx
>  $(PROJECT_INCLUDE)/lpc22xx.h: lpc22xx/include/lpc22xx.h $(PROJECT_INCLUDE)/$(dirstamp)
>         $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/lpc22xx.h
> diff --git a/c/src/lib/libcpu/arm/s3c6410/clock/clockdrv.c b/c/src/lib/libcpu/arm/s3c6410/clock/clockdrv.c
> index 0000000..fac1da0
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/clock/clockdrv.c
> @@ -0,0 +1,144 @@
> + * S3C6410 clock specific using the System Timer
> + * This is hardware specific part of the clock driver. At the end of this
> + * file, the generic part of the driver is #included.
> +#include <rtems.h>
> +#include <bsp.h>
> +void Clock_isr(rtems_irq_hdl_param arg);
> +static void clock_isr_on(const rtems_irq_connect_data *unused);
> +static void clock_isr_off(const rtems_irq_connect_data *unused);
> +static int clock_isr_is_on(const rtems_irq_connect_data *irq);
> +rtems_irq_connect_data clock_isr_data = {
> +  .name   = BSP_TIMER4,
> +  .hdl    = Clock_isr,
> +  .handle = NULL,
> +  .on     = clock_isr_on,
> +  .off    = clock_isr_off,
> +  .isOn   = clock_isr_is_on,
> + *  Return the nanoseconds since last tick
> +uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
> +  return 0;
> +#define Clock_driver_nanoseconds_since_last_tick \
> +  clock_driver_get_nanoseconds_since_last_tick
> + * When we get the clock interrupt
> + *    - clear the interrupt bit?
> + *    - restart the timer?
> +        Clear BIT_TIMER4 interrupt;                   \
> +#define Clock_driver_support_at_tick()                \
> +  do {                                                \
> +         rTINT_CSTAT |= 1 << 9;\
> +  } while(0)
> + * Installs the clock ISR. You shouldn't need to change this.
> +extern uint32_t *VIC0_VECTADDR;
> +extern uint32_t *VIC1_VECTADDR;
> +#define Clock_driver_support_install_isr( _new, _old ) \
> +  do {                                                 \
> +    _old = NULL;                                       \
> +    VIC0_VECTADDR[BSP_TIMER4] = _new;                  \
> +    rtems_interrupt_handler_install(clock_isr_data.name,\
> +                   "TICK TIMER",\
> +                   RTEMS_INTERRUPT_UNIQUE,\
> +                   clock_isr_data.hdl,\
> +                   clock_isr_data.handle);\
> +  } while(0)
> + * Initialize the hardware for the clock
> + *   - Set the frequency
> + *   - enable it
> + *   - clear any pending interrupts
> + * Since you may want the clock always running, you can
> + * enable interrupts here. If you do so, the clock_isr_on(),
> + * clock_isr_off(), and clock_isr_is_on() functions can be
> + * NOPs.
> + * The bit and constant number should be redifined using macros
> +#define Clock_driver_support_initialize_hardware() \
> +  do { \
> +         rTCON = 0x0;\
> +         rTINT_CSTAT |= 1 << 4;\
> +         bsp_interrupt_vector_enable(BSP_TIMER4);\
> +         rTCFG0 = 0x0101;\
> +         rTCFG1 = (rTCFG1 & 0xf0000) | 0x40000;\
> +         rTCNTB4 = 0x512d;\
> +         rTCON = (rTCON & ~0x00700000) | (1<<22) | (1<<21);\
> +         rTCON = (rTCON & ~0x00700000) | (1<<22) | (1<<20);\
> +         /* auto load, start Timer 4 */\
> +    } while (0)
> + * Do whatever you need to shut the clock down and remove the
> + * interrupt handler. Since this normally only gets called on
> + * RTEMS shutdown, you may not need to do anything other than
> + * remove the ISR.
> +#define Clock_driver_support_shutdown_hardware()                        \
> +  do {        \
> +        /* Disable timer */ \
> +        BSP_remove_rtems_irq_handler(&clock_isr_data);                  \
> +     } while (0)
> + * Enables clock interrupt.
> + * If the interrupt is always on, this can be a NOP.
> + * Disables clock interrupts
> +         rTINT_CSTAT &= ~(1 << 4);
> +    return;
> + * Tests to see if clock interrupt is enabled, and returns 1 if so.
> + * If interrupt is not enabled, returns 0.
> + * If the interrupt is always on, this always returns 1.
> +                               return (rTINT_CSTAT & (0x1 << 4)) >> 4;
> +/* Make sure to include this, and only at the end of the file */
> +#include "../../../../libbsp/shared/clockdrv_shell.h"
> diff --git a/c/src/lib/libcpu/arm/s3c6410/clock/support.c b/c/src/lib/libcpu/arm/s3c6410/clock/support.c
> index 0000000..01a7848
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/clock/support.c
> @@ -0,0 +1,55 @@
> + * Support code for hardware clock
> +#include <rtems.h>
> +#include <bsp.h>
> +/* NOTE: This describes the proper use of this file.
> + * Now the clock related setting is done in uboot.
> + * This will be fixed in future
> + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of
> + * the specified bus in HZ.
> +/* return FCLK frequency */
> +       /* not implemented */
> +       return 0;
> +/* return UCLK frequency */
> +       return 0;
> +/* return HCLK frequency */
> +       return 0;
> +/* return PCLK frequency */
> +       /* Just return uboot configured freq.
> +        * Fix this in future
> +       return 66000000;
> diff --git a/c/src/lib/libcpu/arm/s3c6410/include/s3c6410.h b/c/src/lib/libcpu/arm/s3c6410/include/s3c6410.h
> index 0000000..96de85e
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/include/s3c6410.h
> @@ -0,0 +1,227 @@
> + * S3C6410 header file
> +#ifndef __S3C6410_H__
> +#define __S3C6410_H__
> +#define __reg(addr)    (*(volatile unsigned *)(addr))
> +/* UART */
> +#define UART_BASE              (0x7F005000)
> +#define UART0_BASE     (UART_BASE + 0x0)
> +#define UART1_BASE     (UART_BASE + 0x400)
> +#define UART2_BASE     (UART_BASE + 0x800)
> +#define UART2_BASE     (UART_BASE + 0xC00)
> +#define rULCON0                __reg(UART0_BASE + 0x00)
> +#define rUCON0         __reg(UART0_BASE + 0x04)
> +#define rUFCON0                __reg(UART0_BASE + 0x08)
> +#define rUMCON0                __reg(UART0_BASE + 0x0C)
> +#define rUTRSTAT0      __reg(UART0_BASE + 0x10)
> +#define rUERSTAT0      __reg(UART0_BASE + 0x14)
> +#define rUFSTAT0       __reg(UART0_BASE + 0x18)
> +#define rUMSTAT0       __reg(UART0_BASE + 0x1C)
> +#define rUTXH0         __reg(UART0_BASE + 0x20)
> +#define rURXH0         __reg(UART0_BASE + 0x24)
> +#define rUBRDIV0       __reg(UART0_BASE + 0x28)
> +#define rUDIVSLOT0     __reg(UART0_BASE + 0x2C)
> +#define rUINTP0                __reg(UART0_BASE + 0x30)
> +#define rUINTSP0       __reg(UART0_BASE + 0x34)
> +#define rUINTM0                __reg(UART0_BASE + 0x38)
> +#define rULCON1                __reg(UART1_BASE + 0x00)
> +#define rUCON1         __reg(UART1_BASE + 0x04)
> +#define rUFCON1                __reg(UART1_BASE + 0x08)
> +#define rUMCON1                __reg(UART1_BASE + 0x0C)
> +#define rUTRSTAT1      __reg(UART1_BASE + 0x10)
> +#define rUERSTAT1      __reg(UART1_BASE + 0x14)
> +#define rUFSTAT1       __reg(UART1_BASE + 0x18)
> +#define rUMSTAT1       __reg(UART1_BASE + 0x1C)
> +#define rUTXH1         __reg(UART1_BASE + 0x20)
> +#define rURXH1         __reg(UART1_BASE + 0x24)
> +#define rUBRDIV1       __reg(UART1_BASE + 0x28)
> +#define rUDIVSLOT1     __reg(UART1_BASE + 0x2C)
> +#define rUINTP1                __reg(UART1_BASE + 0x30)
> +#define rUINTSP1       __reg(UART1_BASE + 0x34)
> +#define rUINTM1                __reg(UART1_BASE + 0x38)
> +/* GPIO */
> +#define GPIO_BASE              (0x7F008000)
> +#define GPIOA_BASE     GPIO_BASE
> +/* GPIO K CONTROL REGISTERS */
> +#define rGPKCON0               __reg(0x7F008800)
> +#define rGPKCON1               __reg(0x7F008804)
> +#define rGPKDAT                        __reg(0x7F008808)
> +#define rGPKPUD                        __reg(0x7F00880C)
> +/* GPIO K CONTROL BIT DESCRITPTION*/
> +#define GPKCON_Input           0x0
> +#define GPKCON_Output          0x1
> +#define GPKCON_HOST_IF 0x2
> +#define GPKCON_HSI                     0x3
> +#define GPKCON_CF                              0x5
> +#define GPKPUD_PUDD                    0x0 /*pull up/down disable*/
> +#define GPKPUD_PDE                     0x1 /*pull down enable*/
> +#define GPKPUD_PUE                     0x2 /*pull up enable*/
> +#define rEINT0PEND     __reg(0x7F008924)
> +/* TIMER */
> +#define TIMER_BASE     (0x7F006000)
> +#define rTCFG0         __reg(TIMER_BASE + 0x0)
> +#define rTCFG1         __reg(TIMER_BASE + 0x4)
> +#define rTCON                  __reg(TIMER_BASE + 0x8)
> +#define rTCNTB0                __reg(TIMER_BASE + 0xC)
> +#define rTCMPB0                __reg(TIMER_BASE + 0x10)
> +#define rTCNTO0                __reg(TIMER_BASE + 0x14)
> +#define rTCNTB1                __reg(TIMER_BASE + 0x18)
> +#define rTCMPB1                __reg(TIMER_BASE + 0x1C)
> +#define rTCNTO1                __reg(TIMER_BASE + 0x20)
> +#define rTCNTB2                __reg(TIMER_BASE + 0x24)
> +#define rTCNTO2                __reg(TIMER_BASE + 0x2C)
> +#define rTCNTB3                __reg(TIMER_BASE + 0x30)
> +#define rTCNTO3                __reg(TIMER_BASE + 0x38)
> +#define rTCNTB4                __reg(TIMER_BASE + 0x3C)
> +#define rTCNTO4                __reg(TIMER_BASE + 0x40)
> +#define rTINT_CSTAT    __reg(TIMER_BASE + 0x44)
> + * Interrupt
> +/* VIC */
> +#define VIC0_BASE_ADDR                 (0x71200000)
> +#define VIC1_BASE_ADDR                 (0x71300000)
> +#define rVIC0_IRQSTATUS                        __reg(VIC0_BASE_ADDR + 0x0)
> +#define rVIC0_FIQSTATUS                        __reg(VIC0_BASE_ADDR + 0x4)
> +#define rVIC0_RAWINTR                          __reg(VIC0_BASE_ADDR + 0x8)
> +#define rVIC0_INTSELECT                        __reg(VIC0_BASE_ADDR + 0xC)
> +#define rVIC0_INTENABLE                        __reg(VIC0_BASE_ADDR + 0x10)
> +#define rVIC0_INTENCLEAR               __reg(VIC0_BASE_ADDR + 0x14)
> +#define rVIC0_SOFTINT                          __reg(VIC0_BASE_ADDR + 0x18)
> +#define rVIC0_SOFTINTCLEAR     __reg(VIC0_BASE_ADDR + 0x1C)
> +#define rVIC0_PROTECTION               __reg(VIC0_BASE_ADDR + 0x20)
> +#define rVIC0_SWPPIORITYMASK   __reg(VIC0_BASE_ADDR + 0x24)
> +#define rVIC0_PRIORITYDAISY    __reg(VIC0_BASE_ADDR + 0x28)
> +#define VIC0_VECTADDR_BASE     (VIC0_BASE_ADDR + 0x100)
> +#define rVIC0_ADDRESS                          __reg(VIC0_BASE_ADDR + 0xF00)
> +#define rVIC1_IRQSTATUS                        __reg(VIC1_BASE_ADDR + 0x0)
> +#define rVIC1_FIQSTATUS                        __reg(VIC1_BASE_ADDR + 0x4)
> +#define rVIC1_RAWINTR                          __reg(VIC1_BASE_ADDR + 0x8)
> +#define rVIC1_INTSELECT                        __reg(VIC1_BASE_ADDR + 0xC)
> +#define rVIC1_INTENABLE                        __reg(VIC1_BASE_ADDR + 0x10)
> +#define rVIC1_INTENCLEAR               __reg(VIC1_BASE_ADDR + 0x14)
> +#define rVIC1_SOFTINT                          __reg(VIC1_BASE_ADDR + 0x18)
> +#define rVIC1_SOFTINTCLEAR     __reg(VIC1_BASE_ADDR + 0x1C)
> +#define rVIC1_PROTECTION               __reg(VIC1_BASE_ADDR + 0x20)
> +#define rVIC1_SWPPIORITYMASK   __reg(VIC1_BASE_ADDR + 0x24)
> +#define rVIC1_PRIORITYDAISY    __reg(VIC1_BASE_ADDR + 0x28)
> +#define VIC1_VECTADDR_BASE     (VIC1_BASE_ADDR + 0x100)
> +#define rVIC1_ADDRESS                          __reg(VIC1_BASE_ADDR + 0xF00)
> +/* ADC */
> +#define rADCCON                                                        __reg(0x7E00B000)
> +#define rADCTSC                                                        __reg(0x7E00B004)
> +#define rADCDLY                                                        __reg(0x7E00B008)
> +#define rADCDAT0                                               __reg(0x7E00B00C)
> +#define rADCDAT1                                               __reg(0x7E00B010)
> +#define rADCUPDN                                               __reg(0x7E00B014)
> +#define rADCCLRINT                                     __reg(0x7E00B018)
> +#define rADCCLRINTPNDNUP               __reg(0x7E00B020)
> +/* WATCH DOG */
> +#define rWTCON                                                 __reg(0x7E004000)
> +#define rWTDAT                                                 __reg(0x7E004004)
> +#define rWTCNT                                                 __reg(0x7E004008)
> +#define rWTCLRINT                                              __reg(0x7E00400C)
> +/* RTC */
> +#define rINTP                                                          __reg(0x7E005030)
> +#define rTICCNT                                                        __reg(0x7E005044)
> +/* NAND */
> +#define  NAND_BASE                             (0x70200000)
> +#define rNFCONF                                                __reg(NAND_BASE + 0x0)
> +#define rNFCONT                                                __reg(NAND_BASE + 0x4)
> +#define rNFCNND                                                __reg(NAND_BASE + 0x8)
> +#define rNFADDR                                                __reg(NAND_BASE + 0xC)
> +#define rNFDATA                                                __reg(NAND_BASE + 0x10)
> +#define rNFMECCD0                                      __reg(NAND_BASE + 0x14)
> +#define rNFMECCD1                                      __reg(NAND_BASE + 0x18)
> +#define rNFSECCD                                       __reg(NAND_BASE + 0x1C)
> +#define rNFSBLK                                                __reg(NAND_BASE + 0x20)
> +#define rNFEBLK                                                __reg(NAND_BASE + 0x24)
> +#define rNFSTAT                                                __reg(NAND_BASE + 0x28)
> +#define rNFECCERR0                             __reg(NAND_BASE + 0x2C)
> +#define rNFECCERR1                             __reg(NAND_BASE + 0x30)
> +#define rNFMECC0                                       __reg(NAND_BASE + 0x34)
> +#define rNFMECC1                                       __reg(NAND_BASE + 0x38)
> +#define rNFSECC                                                __reg(NAND_BASE + 0x3C)
> +#define rNFMLCBITPT                            __reg(NAND_BASE + 0x40)
> +#define rNF8ECCERR0                            __reg(NAND_BASE + 0x44)
> +#define rNF8ECCERR1                            __reg(NAND_BASE + 0x48)
> +#define rNF8ECCERR2                            __reg(NAND_BASE + 0x4C)
> +#define rNFM8ECC0                                      __reg(NAND_BASE + 0x50)
> +#define rNFM8ECC1                                      __reg(NAND_BASE + 0x54)
> +#define rNFM8ECC2                                      __reg(NAND_BASE + 0x58)
> +#define rNFM8ECC3                                      __reg(NAND_BASE + 0x5C)
> +#define rNFMLC8BITPT0                  __reg(NAND_BASE + 0x60)
> +#define rNFMLC8BITPT1                  __reg(NAND_BASE + 0x64)
> +#define BIT0                   0x00000001
> +#define BIT1                   0x00000002
> +#define BIT2                   0x00000004
> +#define BIT3                   0x00000008
> +#define BIT4                   0x00000010
> +#define BIT5                   0x00000020
> +#define BIT6                   0x00000040
> +#define BIT7                   0x00000080
> +#define BIT8                   0x00000100
> +#define BIT9                   0x00000200
> +#define BIT10                  0x00000400
> +#define BIT11                  0x00000800
> +#define BIT12                  0x00001000
> +#define BIT13                  0x00002000
> +#define BIT14                  0x00004000
> +#define BIT15                  0x00008000
> +#define BIT16                  0x00010000
> +#define BIT17                  0x00020000
> +#define BIT18                  0x00040000
> +#define BIT19                  0x00080000
> +#define BIT20                  0x00100000
> +#define BIT21                  0x00200000
> +#define BIT22                  0x00400000
> +#define BIT23                  0x00800000
> +#define BIT24                  0x01000000
> +#define BIT25                  0x02000000
> +#define BIT26                  0x04000000
> +#define BIT27                  0x08000000
> +#define BIT28                  0x10000000
> +#define BIT29                  0x20000000
> +#define BIT30                  0x40000000
> +#define BIT31                  0x80000000
> +#endif /*__S3C6410_H__*/
> diff --git a/c/src/lib/libcpu/arm/s3c6410/include/s3c64xx.h b/c/src/lib/libcpu/arm/s3c6410/include/s3c64xx.h
> index 0000000..14e672d
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/include/s3c64xx.h
> @@ -0,0 +1,20 @@
> + * S3C64xx header file
> + * share code for different Samsung CPU
> +#ifndef S3C64XX_H_
> +#define S3C64XX_H_
> +#ifdef CPU_S3C6410
> +#include <s3c6410.h>
> +#endif
> +#endif /*S3C64XX_H_*/
> diff --git a/c/src/lib/libcpu/arm/s3c6410/irq/irq.c b/c/src/lib/libcpu/arm/s3c6410/irq/irq.c
> index 0000000..3c24acc
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/irq/irq.c
> @@ -0,0 +1,84 @@
> + * This file contains the implementation of the function described in irq.h
> + * Note: s3c6410 support VIC.The current code implementation does not
> + * use this feature. This will be done in future.
> +#include <rtems/score/armv4.h>
> +#include <bsp.h>
> +uint32_t *VIC0_VECTADDR = (uint32_t *)VIC0_VECTADDR_BASE;
> +uint32_t *VIC1_VECTADDR = (uint32_t *)VIC1_VECTADDR_BASE;
> +typedef void (*vicfunc)(void);
> +void bsp_interrupt_dispatch(void)
> +       uint32_t vector_addr0 = rVIC0_ADDRESS;
> +       uint32_t vector_addr1 = rVIC1_ADDRESS;
> +       if (vector_addr0 != 0){
> +               void (*vicfunc)(void) = (void(*)(void))rVIC0_ADDRESS;
> +               vicfunc();
> +       if (vector_addr1 != 0){
> +               void (*vicfunc)(void) = (void(*)(void))rVIC1_ADDRESS;
> +               vicfunc();
> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> +  if (vector < 32)
> +       rVIC0_INTENABLE |= 1 << vector;
> +  else if (vector < 64)
> +       rVIC1_INTENABLE |= 1 << (vector - 32);
> +  else
> +         printk("%s failed\n", __func__);
> +  return RTEMS_SUCCESSFUL;
> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
> +  if (vector < 32)
> +       rVIC0_INTENCLEAR |= 1 << vector;
> +       rVIC1_INTENCLEAR |= 1 << (vector - 32);
> +  else
> +rtems_status_code bsp_interrupt_facility_initialize(void)
> +  _CPU_ISR_install_vector(ARM_EXCEPTION_IRQ, _ARMV4_Exception_interrupt, NULL);
> diff --git a/c/src/lib/libcpu/arm/s3c6410/irq/irq.h b/c/src/lib/libcpu/arm/s3c6410/irq/irq.h
> index 0000000..14857fd
> --- /dev/null
> +++ b/c/src/lib/libcpu/arm/s3c6410/irq/irq.h
> @@ -0,0 +1,98 @@
> +/* irq.h
> +#ifndef _IRQ_H_
> +#define _IRQ_H_
> +#ifndef ASM
> +#include <rtems.h>
> +#include <rtems/irq.h>
> +#include <rtems/irq-extension.h>
> +#ifdef CPU_S3C6410
> +  /* possible interrupt sources */
> +#define BSP_EINT0                      0
> +#define BSP_EINT1                      1
> +#define BSP_RTC_TIC            2
> +#define BSP_CAMIF_C            3
> +#define BSP_CAMIF_P            4
> +#define        BSP_I2C1                        5
> +#define BSP_I2S0_1_V40 6
> +/* 7 is reserved */
> +#define BSP_3D                         8
> +#define BSP_POST0                      9
> +#define BSP_RPTATOR            10
> +#define BSP_2D                         11
> +#define BSP_TVENC                      12
> +#define BSP_SCALER             13
> +#define BSP_BATF                       14
> +#define BSP_JPEG                       15
> +#define BSP_MFC                                16
> +#define BSP_SDMA0                      17
> +#define BSP_SDMA1                      18
> +#define BSP_ARM_DMAERR 19
> +#define BSP_ARM_DMA            20
> +#define BSP_ARM_DMAS   21
> +#define BSP_KEYPAD             22
> +#define        BSP_TIMER0              23
> +#define BSP_TIMER1             24
> +#define BSP_TIMER2             25
> +#define BSP_WDT                                26
> +#define BSP_TIMER3             27
> +#define BSP_TIMER4             28
> +#define BSP_LCD0                       29
> +#define BSP_LCD1                       30
> +#define BSP_LCD2                       31
> +#define BSP_EINT2                      32
> +#define BSP_EINT3                      33
> +#define BSP_PCM0                       34
> +#define BSP_PCM1                       35
> +#define BSP_AC97                       36
> +#define BSP_UART0                      37
> +#define BSP_UART1                      38
> +#define BSP_UART2                      39
> +#define BSP_UART3                      40
> +#define BSP_DMA0                       41
> +#define BSP_DMA1                       42
> +#define BSP_ONENAND0   43
> +#define BSP_ONENAND1   44
> +#define BSP_NFC                                45
> +#define BSP_CFC                                46
> +#define BSP_UHOST                      47
> +#define BSP_SPI0                       48
> +#define BSP_SPI1                       49
> +#define BSP_HSMMC2             49
> +#define BSP_I2C0                       50
> +#define BSP_HSItx                      51
> +#define BSP_HSIrx                      52
> +#define BSP_EINT4                      53
> +#define BSP_MSM                                54
> +#define BSP_HOSTIF             55
> +#define BSP_HSMMC0             56
> +#define BSP_HSMMC1             57
> +#define BSP_OTG                                58
> +#define BSP_IrDA                       59
> +#define BSP_RTC_ALARM  60
> +#define BSP_SEC                                61
> +#define BSP_PENDNUP            62
> +#define BSP_ADC                                63
> +#define BSP_MAX_INT            64
> +#endif
> +#define BSP_INTERRUPT_VECTOR_MIN 0
> +#define BSP_INTERRUPT_VECTOR_MAX (BSP_MAX_INT - 1)
> +#endif /* ASM */
> +#endif /* _IRQ_H_ */
> +/* end of include file */
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
