Zynq BSP progress
Claus, Ric claus at slac.stanford.edu
Thu Apr 18 21:37:03 UTC 2013
My goal is to submit a preliminary version within the next few days, provided I don't get hung up in gitisms.
	Ric
On Apr 18, 2013, at 2:31 PM, Chris Johns wrote:
> Claus, Ric wrote:
>> If anyone is still trying to help solve this issue, thanks, but you can stop.  When I RTFM enough times, I finally start to understand bits and pieces of what is being said.  In this case, there is a Network Configuration register with which one can tell the DMA engine to offset where it deposits the data by 0 to 3 bytes from the beginning of the buffer.  Probably not something that should be done on a per frame basis, though.  I now have a truly working Network Driver.
> Great work.
> I am interested in this BSP. When would it be available ?
> Chris
