[PATCH 1/3] Implement a generic atomic ops for all UP mode architectures with disable/enable-IRQ function simulated.
WeiY
wei.a.yang at gmail.com
Tue Apr 23 16:34:15 UTC 2013
cpukit/score/Makefile.am | 1 +
.../score/include/rtems/score/genericatomicops.h | 274 ++++++++++++++++++++
cpukit/score/preinstall.am | 4 +
3 files changed, 279 insertions(+), 0 deletions(-)
create mode 100644 cpukit/score/include/rtems/score/genericatomicops.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 8da32a5..396cccf 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -60,6 +60,7 @@ include_rtems_score_HEADERS += include/rtems/score/basedefs.h
if ATOMIC
include_rtems_score_HEADERS += include/rtems/score/atomic.h
include_rtems_score_HEADERS += include/rtems/score/genericcpuatomic.h
+include_rtems_score_HEADERS += include/rtems/score/genericatomicops.h
endif
if HAS_SMP
include_rtems_score_HEADERS += include/rtems/score/smplock.h
diff --git a/cpukit/score/include/rtems/score/genericatomicops.h b/cpukit/score/include/rtems/score/genericatomicops.h
new file mode 100644
index 0000000..1c530c1
--- /dev/null
+++ b/cpukit/score/include/rtems/score/genericatomicops.h
@@ -0,0 +1,274 @@
+ * @file rtems/score/genericatomicops.h
+ * This include file includes the general atomic functions
+ * for all the uniprocessors or working in UP mode architectures.
+ * If the architecture is working at the UP mode, the atomic
+ * operations will be simulated by disable/enable-irq functions.
+ * Supposing that if the macro "RTEMS_SMP" is defined it works
+ * in SMP mode, otherwise UP mode.
+ * COPYRIGHT (c) 2013 Deng Hengyi.
+#ifndef _RTEMS_SCORE_GENERAL_ATOMIC_OPS_H
+#define _RTEMS_SCORE_GEMERAL_ATOMIC_OPS_H
+#include <rtems/score/genericcpuatomic.h>
+#include <rtems/score/isr.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMS generic UP atomic implementation
+ * @brief Atomically load an atomic type value from address @a address.
+#define ATOMIC_LOAD(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE Atomic_##TYPE _CPU_Atomic_Load_##NAME( \
+ volatile Atomic_##TYPE *address \
+ Atomic_##TYPE tmp; \
+ ISR_Level level; \
+ _ISR_Disable( level ); \
+ tmp = *address; \
+ _ISR_Enable( level ); \
+ return tmp; \
+ATOMIC_LOAD(int, Int);
+ATOMIC_LOAD(acq_int, Int);
+ATOMIC_LOAD(long, Long);
+ATOMIC_LOAD(acq_long, Long);
+ATOMIC_LOAD(ptr, Pointer);
+ATOMIC_LOAD(acq_ptr, Pointer);
+ATOMIC_LOAD(32, Int32);
+ATOMIC_LOAD(acq_32, Int32);
+ATOMIC_LOAD(64, Int64);
+ATOMIC_LOAD(acq_64, Int64);
+ * @brief Atomically store an atomic type value @a value into address @a
+ * address.
+#define ATOMIC_STORE(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Store_##NAME( \
+ volatile Atomic_##TYPE *address, \
+ Atomic_##TYPE value \
+ *address = value; \
+ATOMIC_STORE(int, Int);
+ATOMIC_STORE(rel_int, Int);
+ATOMIC_STORE(long, Long);
+ATOMIC_STORE(rel_long, Long);
+ATOMIC_STORE(ptr, Pointer);
+ATOMIC_STORE(rel_ptr, Pointer);
+ATOMIC_STORE(32, Int32);
+ATOMIC_STORE(rel_32, Int32);
+ATOMIC_STORE(64, Int64);
+ATOMIC_STORE(rel_64, Int64);
+ * @brief Atomically load-add-store an atomic type value @a value into address
+ * @a address.
+#define ATOMIC_FETCH_ADD(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_add_##NAME( \
+ *address += value; \
+ATOMIC_FETCH_ADD(int, Int);
+ATOMIC_FETCH_ADD(acq_int, Int);
+ATOMIC_FETCH_ADD(rel_int, Int);
+ATOMIC_FETCH_ADD(long, Long);
+ATOMIC_FETCH_ADD(acq_long, Long);
+ATOMIC_FETCH_ADD(rel_long, Long);
+ATOMIC_FETCH_ADD(ptr, Pointer);
+ATOMIC_FETCH_ADD(acq_ptr, Pointer);
+ATOMIC_FETCH_ADD(rel_ptr, Pointer);
+ATOMIC_FETCH_ADD(32, Int32);
+ATOMIC_FETCH_ADD(acq_32, Int32);
+ATOMIC_FETCH_ADD(rel_32, Int32);
+ATOMIC_FETCH_ADD(64, Int64);
+ATOMIC_FETCH_ADD(acq_64, Int64);
+ATOMIC_FETCH_ADD(rel_64, Int64);
+ * @brief Atomically load-sub-store an atomic type value @a value into address
+ * @a address.
+#define ATOMIC_FETCH_SUB(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_sub_##NAME( \
+ *address -= value; \
+ATOMIC_FETCH_SUB(int, Int);
+ATOMIC_FETCH_SUB(acq_int, Int);
+ATOMIC_FETCH_SUB(rel_int, Int);
+ATOMIC_FETCH_SUB(long, Long);
+ATOMIC_FETCH_SUB(acq_long, Long);
+ATOMIC_FETCH_SUB(rel_long, Long);
+ATOMIC_FETCH_SUB(ptr, Pointer);
+ATOMIC_FETCH_SUB(acq_ptr, Pointer);
+ATOMIC_FETCH_SUB(rel_ptr, Pointer);
+ATOMIC_FETCH_SUB(32, Int32);
+ATOMIC_FETCH_SUB(acq_32, Int32);
+ATOMIC_FETCH_SUB(rel_32, Int32);
+ATOMIC_FETCH_SUB(64, Int64);
+ATOMIC_FETCH_SUB(acq_64, Int64);
+ATOMIC_FETCH_SUB(rel_64, Int64);
+ * @brief Atomically load-or-store an atomic type value @a value into address
+ * @a address.
+#define ATOMIC_FETCH_OR(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_or_##NAME( \
+ *address |= value; \
+ATOMIC_FETCH_OR(int, Int);
+ATOMIC_FETCH_OR(acq_int, Int);
+ATOMIC_FETCH_OR(rel_int, Int);
+ATOMIC_FETCH_OR(long, Long);
+ATOMIC_FETCH_OR(acq_long, Long);
+ATOMIC_FETCH_OR(rel_long, Long);
+ATOMIC_FETCH_OR(ptr, Pointer);
+ATOMIC_FETCH_OR(acq_ptr, Pointer);
+ATOMIC_FETCH_OR(rel_ptr, Pointer);
+ATOMIC_FETCH_OR(32, Int32);
+ATOMIC_FETCH_OR(acq_32, Int32);
+ATOMIC_FETCH_OR(rel_32, Int32);
+ATOMIC_FETCH_OR(64, Int64);
+ATOMIC_FETCH_OR(acq_64, Int64);
+ATOMIC_FETCH_OR(rel_64, Int64);
+ * @brief Atomically load-and-store an atomic type value @a value into address
+ * @a address.
+#define ATOMIC_FETCH_AND(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_and_##NAME( \
+ *address &= value; \
+ATOMIC_FETCH_AND(int, Int);
+ATOMIC_FETCH_AND(acq_int, Int);
+ATOMIC_FETCH_AND(rel_int, Int);
+ATOMIC_FETCH_AND(long, Long);
+ATOMIC_FETCH_AND(acq_long, Long);
+ATOMIC_FETCH_AND(rel_long, Long);
+ATOMIC_FETCH_AND(ptr, Pointer);
+ATOMIC_FETCH_AND(acq_ptr, Pointer);
+ATOMIC_FETCH_AND(rel_ptr, Pointer);
+ATOMIC_FETCH_AND(32, Int32);
+ATOMIC_FETCH_AND(acq_32, Int32);
+ATOMIC_FETCH_AND(rel_32, Int32);
+ATOMIC_FETCH_AND(64, Int64);
+ATOMIC_FETCH_AND(acq_64, Int64);
+ATOMIC_FETCH_AND(rel_64, Int64);
+ * @brief Atomically compare the value stored at @a address with @a
+ * old_value and if the two values are equal, update the value of @a
+ * address with @a new_value. Returns zero if the compare failed,
+ * nonzero otherwise.
+#define ATOMIC_COMPARE_EXCHANGE(NAME, TYPE) \
+RTEMS_INLINE_ROUTINE int _CPU_Atomic_Compare_exchange_##NAME( \
+ Atomic_##TYPE old_value, \
+ Atomic_##TYPE new_value \
+ int ret; \
+ if (*address == old_value) { \
+ *address = new_value; \
+ ret = TRUE; \
+ } else { \
+ ret = FALSE; \
+ return ret; \
+ATOMIC_COMPARE_EXCHANGE(int, Int);
+ATOMIC_COMPARE_EXCHANGE(acq_int, Int);
+ATOMIC_COMPARE_EXCHANGE(rel_int, Int);
+ATOMIC_COMPARE_EXCHANGE(long, Long);
+ATOMIC_COMPARE_EXCHANGE(acq_long, Long);
+ATOMIC_COMPARE_EXCHANGE(rel_long, Long);
+ATOMIC_COMPARE_EXCHANGE(ptr, Pointer);
+ATOMIC_COMPARE_EXCHANGE(acq_ptr, Pointer);
+ATOMIC_COMPARE_EXCHANGE(rel_ptr, Pointer);
+ATOMIC_COMPARE_EXCHANGE(32, Int32);
+ATOMIC_COMPARE_EXCHANGE(acq_32, Int32);
+ATOMIC_COMPARE_EXCHANGE(rel_32, Int32);
+ATOMIC_COMPARE_EXCHANGE(64, Int64);
+ATOMIC_COMPARE_EXCHANGE(acq_64, Int64);
+ATOMIC_COMPARE_EXCHANGE(rel_64, Int64);
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index a346c79..7054c3d 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -219,6 +219,10 @@ PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/atomic.h
$(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h: include/rtems/score/genericcpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h
+$(PROJECT_INCLUDE)/rtems/score/genericatomicops.h: include/rtems/score/genericatomicops.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
endif
if HAS_SMP
$(PROJECT_INCLUDE)/rtems/score/smplock.h: include/rtems/score/smplock.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
1.7.1
