[PATCH 0/3] *** implementation of generic atomic ops for UP ***
Gedare Bloom
gedare at rtems.org
Tue Apr 23 19:49:50 UTC 2013
The testsuite fixes can be done separately. I have tested psim and
jmr3904, logs are attached. Many of the jmr3904 tests did not
terminate. But what did run seems correct.
On Tue, Apr 23, 2013 at 3:46 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Some of the spatomic tests are not terminating within the 60 second
> window used by the rtems-testing scripts. My guess is that the "Wait
> task" is wasting a lot of time while spinning. Maybe reduce its
> priority so it will only be scheduled when the other tasks are done?
> On Tue, Apr 23, 2013 at 12:34 PM, WeiY <wei.a.yang at gmail.com> wrote:
>> From: WeiY <wei.a.yang at gmail.com>
>> *** BLURB HERE ***
>> WeiY (3):
>> Implement a generic atomic ops for all UP mode architectures with
>> disable/enable-IRQ function simulated.
>> Using the generic atomic ops to implement UP mode atomic for all
>> architectures. SMP atomic port will be later.
>> Clear the atomic conditional compilation.
>> cpukit/configure.ac | 7 -
>> cpukit/rtems/Makefile.am | 2 -
>> cpukit/rtems/preinstall.am | 3 +-
>> cpukit/score/Makefile.am | 3 +-
>> cpukit/score/cpu/arm/Makefile.am | 1 +
>> cpukit/score/cpu/arm/preinstall.am | 3 +
>> cpukit/score/cpu/arm/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/avr/Makefile.am | 1 +
>> cpukit/score/cpu/avr/preinstall.am | 4 +
>> cpukit/score/cpu/avr/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/bfin/Makefile.am | 1 +
>> cpukit/score/cpu/bfin/preinstall.am | 3 +
>> cpukit/score/cpu/bfin/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/h8300/Makefile.am | 1 +
>> cpukit/score/cpu/h8300/preinstall.am | 3 +
>> cpukit/score/cpu/h8300/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/lm32/Makefile.am | 1 +
>> cpukit/score/cpu/lm32/preinstall.am | 3 +
>> cpukit/score/cpu/lm32/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/m32c/Makefile.am | 1 +
>> cpukit/score/cpu/m32c/preinstall.am | 3 +
>> cpukit/score/cpu/m32c/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/m32r/Makefile.am | 1 +
>> cpukit/score/cpu/m32r/preinstall.am | 3 +
>> cpukit/score/cpu/m32r/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/m68k/Makefile.am | 1 +
>> cpukit/score/cpu/m68k/preinstall.am | 3 +
>> cpukit/score/cpu/m68k/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/mips/Makefile.am | 1 +
>> cpukit/score/cpu/mips/preinstall.am | 3 +
>> cpukit/score/cpu/mips/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/moxie/Makefile.am | 1 +
>> cpukit/score/cpu/moxie/preinstall.am | 3 +
>> cpukit/score/cpu/moxie/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/nios2/Makefile.am | 1 +
>> cpukit/score/cpu/nios2/preinstall.am | 3 +
>> cpukit/score/cpu/nios2/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/sh/Makefile.am | 1 +
>> cpukit/score/cpu/sh/preinstall.am | 3 +
>> cpukit/score/cpu/sh/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/sparc/Makefile.am | 1 +
>> cpukit/score/cpu/sparc/preinstall.am | 3 +
>> cpukit/score/cpu/sparc/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/sparc64/Makefile.am | 1 +
>> cpukit/score/cpu/sparc64/preinstall.am | 3 +
>> cpukit/score/cpu/sparc64/rtems/score/cpuatomic.h | 40 +++
>> cpukit/score/cpu/v850/Makefile.am | 1 +
>> cpukit/score/cpu/v850/preinstall.am | 3 +
>> cpukit/score/cpu/v850/rtems/score/cpuatomic.h | 40 +++
>> .../score/include/rtems/score/genericatomicops.h | 274 ++++++++++++++++++++
>> cpukit/score/preinstall.am | 7 +-
>> testsuites/sptests/configure.ac | 4 -
>> testsuites/sptests/spatomic01/Makefile.am | 4 -
>> testsuites/sptests/spatomic02/Makefile.am | 4 -
>> testsuites/sptests/spatomic03/Makefile.am | 4 -
>> testsuites/sptests/spatomic04/Makefile.am | 4 -
>> testsuites/sptests/spatomic05/Makefile.am | 4 -
>> testsuites/sptests/spatomic06/Makefile.am | 4 -
>> testsuites/sptests/spatomic07/Makefile.am | 4 -
>> 59 files changed, 942 insertions(+), 47 deletions(-)
>> create mode 100644 cpukit/score/cpu/arm/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/avr/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/bfin/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/h8300/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/lm32/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/m32c/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/m32r/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/m68k/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/mips/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/moxie/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/nios2/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/sh/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/sparc/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/sparc64/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/cpu/v850/rtems/score/cpuatomic.h
>> create mode 100644 cpukit/score/include/rtems/score/genericatomicops.h
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Type: application/x-gzip
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130423/563bcb51/attachment-0002.bin>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130423/563bcb51/attachment-0003.bin>
