[PATCH] licenses: relocate and update
Gedare Bloom
gedare at rtems.org
Wed Apr 24 22:48:59 UTC 2013
LICENSE | 20 ----------------
LICENSE.NET | 59 ------------------------------------------------
LICENSE.RPCXDR | 40 --------------------------------
LICENSE.WEBSERVER | 4 ---
LICENSE/LICENSE | 20 ++++++++++++++++
LICENSE/LICENSE.NET | 59 ++++++++++++++++++++++++++++++++++++++++++++++++
LICENSE/LICENSE.RPCXDR | 40 ++++++++++++++++++++++++++++++++
7 files changed, 119 insertions(+), 123 deletions(-)
delete mode 100644 LICENSE
delete mode 100644 LICENSE.NET
delete mode 100644 LICENSE.RPCXDR
delete mode 100644 LICENSE.WEBSERVER
create mode 100644 LICENSE/LICENSE
create mode 100644 LICENSE/LICENSE.NET
create mode 100644 LICENSE/LICENSE.RPCXDR
diff --git a/LICENSE b/LICENSE
deleted file mode 100644
index 1d85bbf..0000000
--- a/LICENSE
+++ /dev/null
@@ -1,20 +0,0 @@
- LICENSE INFORMATION
-RTEMS is free software; you can redistribute it and/or modify it under
-terms of the GNU General Public License as published by the
-Free Software Foundation; either version 2, or (at your option) any
-later version. RTEMS is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-General Public License for more details. You should have received
-a copy of the GNU General Public License along with RTEMS; see
-file COPYING. If not, write to the Free Software Foundation, 675
-Mass Ave, Cambridge, MA 02139, USA.
-As a special exception, including RTEMS header files in a file,
-instantiating RTEMS generics or templates, or linking other files
-with RTEMS objects to produce an executable application, does not
-by itself cause the resulting executable application to be covered
-by the GNU General Public License. This exception does not
-however invalidate any other reasons why the executable file might be
-covered by the GNU Public License.
diff --git a/LICENSE.NET b/LICENSE.NET
index 68bcbc9..0000000
--- a/LICENSE.NET
+++ /dev/null
@@ -1,59 +0,0 @@
-The RTEMS TCP/IP stack is a port of the FreeBSD TCP/IP stack. The following
-copyright and licensing information applies to this code.
-This code is found under the c/src/libnetworking directory but does not
-constitute the entire contents of that subdirectory.
-Copyright (c) 1980, 1983, 1988, 1993
- The Regents of the University of California. All rights reserved.
-Redistribution and use in source and binary forms, with or without
-modification, are permitted provided that the following conditions
-are met:
-1. Redistributions of source code must retain the above copyright
- notice, this list of conditions and the following disclaimer.
-2. Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
-3. All advertising materials mentioning features or use of this software
- must display the following acknowledgment:
- This product includes software developed by the University of
- California, Berkeley and its contributors.
-4. Neither the name of the University nor the names of its contributors
- may be used to endorse or promote products derived from this software
- without specific prior written permission.
-THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
-ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
-FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
-DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
-OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
-HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
-LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
-OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
-SUCH DAMAGE.
-Portions Copyright (c) 1993 by Digital Equipment Corporation.
-Permission to use, copy, modify, and distribute this software for any
-purpose with or without fee is hereby granted, provided that the above
-copyright notice and this permission notice appear in all copies, and that
-the name of Digital Equipment Corporation not be used in advertising or
-publicity pertaining to distribution of the document or software without
-specific, written prior permission.
-THE SOFTWARE IS PROVIDED "AS IS" AND DIGITAL EQUIPMENT CORP. DISCLAIMS ALL
-WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES
-OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL DIGITAL EQUIPMENT
-CORPORATION BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL
-DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
-PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
-ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
-SOFTWARE.
diff --git a/LICENSE.RPCXDR b/LICENSE.RPCXDR
index 1da6174..0000000
--- a/LICENSE.RPCXDR
+++ /dev/null
@@ -1,40 +0,0 @@
-The RTEMS RPC/XDR support is a port of the freely distributed
-Sun Microsystems implementation. The following copyright and
-licensing information applies to this code.
-This code is in the c/src/librpc directory.
-Copyright (C) 1984, Sun Microsystems, Inc.
-Sun RPC is a product of Sun Microsystems, Inc. and is provided for
-unrestricted use provided that this legend is included on all tape
-media and as a part of the software program in whole or part. Users
-may copy or modify Sun RPC without charge, but are not authorized
-to license or distribute it to anyone else except as part of a product or
-program developed by the user.
-SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
-WARRANTIES OF DESIGN, MERCHANTIBILITY AND FITNESS FOR A PARTICULAR
-PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
-Sun RPC is provided with no support and without any obligation on the
-part of Sun Microsystems, Inc. to assist in its use, correction,
-modification or enhancement.
-SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
-INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
-OR ANY PART THEREOF.
-In no event will Sun Microsystems, Inc. be liable for any lost revenue
-or profits or other special, indirect and consequential damages, even if
-Sun has been advised of the possibility of such damages.
-Sun Microsystems, Inc.
-2550 Garcia Avenue
-Mountain View, California 94043
diff --git a/LICENSE.WEBSERVER b/LICENSE.WEBSERVER
index 65e3757..0000000
--- a/LICENSE.WEBSERVER
+++ /dev/null
@@ -1,4 +0,0 @@
-The source code in c/src/libnetworking/rtems_webserver is a port
-of the Go Ahead Software, Inc. WebServer. Their copyright and
-licensing terms apply. See c/src/libnetworking/rtems_webserver/license.txt
-for details.
diff --git a/LICENSE/LICENSE b/LICENSE/LICENSE
new file mode 100644
index 0000000..1d85bbf
--- /dev/null
+++ b/LICENSE/LICENSE
@@ -0,0 +1,20 @@
+ LICENSE INFORMATION
+RTEMS is free software; you can redistribute it and/or modify it under
+terms of the GNU General Public License as published by the
+Free Software Foundation; either version 2, or (at your option) any
+later version. RTEMS is distributed in the hope that it will be useful,
+but WITHOUT ANY WARRANTY; without even the implied warranty of
+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+General Public License for more details. You should have received
+a copy of the GNU General Public License along with RTEMS; see
+file COPYING. If not, write to the Free Software Foundation, 675
+Mass Ave, Cambridge, MA 02139, USA.
+As a special exception, including RTEMS header files in a file,
+instantiating RTEMS generics or templates, or linking other files
+with RTEMS objects to produce an executable application, does not
+by itself cause the resulting executable application to be covered
+by the GNU General Public License. This exception does not
+however invalidate any other reasons why the executable file might be
+covered by the GNU Public License.
diff --git a/LICENSE/LICENSE.NET b/LICENSE/LICENSE.NET
index 0000000..4977517
--- /dev/null
+++ b/LICENSE/LICENSE.NET
@@ -0,0 +1,59 @@
+The RTEMS TCP/IP stack is a port of the FreeBSD TCP/IP stack. The following
+copyright and licensing information applies to this code.
+This code is found under the cpukit/libnetworking directory but does not
+constitute the entire contents of that subdirectory.
+Copyright (c) 1980, 1983, 1988, 1993
+ The Regents of the University of California. All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions
+are met:
+1. Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+2. Redistributions in binary form must reproduce the above copyright
+ notice, this list of conditions and the following disclaimer in the
+ documentation and/or other materials provided with the distribution.
+3. All advertising materials mentioning features or use of this software
+ must display the following acknowledgment:
+ This product includes software developed by the University of
+ California, Berkeley and its contributors.
+4. Neither the name of the University nor the names of its contributors
+ may be used to endorse or promote products derived from this software
+ without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+SUCH DAMAGE.
+Portions Copyright (c) 1993 by Digital Equipment Corporation.
+Permission to use, copy, modify, and distribute this software for any
+purpose with or without fee is hereby granted, provided that the above
+copyright notice and this permission notice appear in all copies, and that
+the name of Digital Equipment Corporation not be used in advertising or
+publicity pertaining to distribution of the document or software without
+specific, written prior permission.
+THE SOFTWARE IS PROVIDED "AS IS" AND DIGITAL EQUIPMENT CORP. DISCLAIMS ALL
+WARRANTIES WITH REGARD TO THIS SOFTWARE, INCLUDING ALL IMPLIED WARRANTIES
+OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL DIGITAL EQUIPMENT
+CORPORATION BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL
+DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR
+PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS
+ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
+SOFTWARE.
diff --git a/LICENSE/LICENSE.RPCXDR b/LICENSE/LICENSE.RPCXDR
index 0000000..ca58eaa
--- /dev/null
+++ b/LICENSE/LICENSE.RPCXDR
@@ -0,0 +1,40 @@
+The RTEMS RPC/XDR support is a port of the freely distributed
+Sun Microsystems implementation. The following copyright and
+licensing information applies to this code.
+This code is in the cpukit/librpc directory.
+Copyright (C) 1984, Sun Microsystems, Inc.
+Sun RPC is a product of Sun Microsystems, Inc. and is provided for
+unrestricted use provided that this legend is included on all tape
+media and as a part of the software program in whole or part. Users
+may copy or modify Sun RPC without charge, but are not authorized
+to license or distribute it to anyone else except as part of a product or
+program developed by the user.
+SUN RPC IS PROVIDED AS IS WITH NO WARRANTIES OF ANY KIND INCLUDING THE
+WARRANTIES OF DESIGN, MERCHANTIBILITY AND FITNESS FOR A PARTICULAR
+PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE OR TRADE PRACTICE.
+Sun RPC is provided with no support and without any obligation on the
+part of Sun Microsystems, Inc. to assist in its use, correction,
+modification or enhancement.
+SUN MICROSYSTEMS, INC. SHALL HAVE NO LIABILITY WITH RESPECT TO THE
+INFRINGEMENT OF COPYRIGHTS, TRADE SECRETS OR ANY PATENTS BY SUN RPC
+OR ANY PART THEREOF.
+In no event will Sun Microsystems, Inc. be liable for any lost revenue
+or profits or other special, indirect and consequential damages, even if
+Sun has been advised of the possibility of such damages.
+Sun Microsystems, Inc.
+2550 Garcia Avenue
+Mountain View, California 94043
1.7.1
