priority inheritance algorithms
Pavel Pisa
ppisa4lists at pikron.com
Thu Apr 25 06:27:08 UTC 2013
Hello Deng Hengyi,
On Thursday 25 April 2013 07:27:20 wei.a.yang wrote:
> Hi, Pavel. Thank you for your advice. And in my former mail my proposal is
> very similar with the mechanism in the Linux. But the different is that I
> use two min-heap instead of two plist because of good algorithm complexity
> of min-heap.
It worth to evaluate what is better algorithm - RB-tree or min-heap.
RB tree allows to use "static" nodes which are part of the task
structure. The classic array base heap tree with 2n and 2n+1 children
requires per queue array allocation and result in the limited/compile
time defined depth or requires reallocations. But may it be you have
other algorithm on mind.
> > I have done some testing of RTEMS and Linux PI implementations.
> > You can find my test code cor RTEMS classic API
> > and POSIX RTEMS and Linux in the repo
> Good work. But I want to know the mechanism of RTEMS test. You know there
> are two PI algorithms in RTEMS. One is used by default, the other one
> should define __RTEMS_STRICT_ORDER_MUTEX__ to use it. You test two
> algorithms all?
I have tested default one. The __RTEMS_STRICT_ORDER_MUTEX__ should
behave as expected but there is risk that some code/libray we use
does not access mutexes in the strict LIFO order.
Best wishes,
Pavel
