msp430 - was Re: GSOC Student Reminder
Joel Sherrill
joel.sherrill at OARcorp.com
Sat Apr 27 20:14:31 UTC 2013
On 4/26/2013 10:40 PM, Gedare Bloom wrote:
> Adding on:
> * is there gcc support for the cpu already?
Yes .. but not in FSF gcc source. There is a separate sourceforge
project for it.
Ditto for gdb.
binutils builds.
> * is there license compatible code available for the hw especially
> helpful is boot and console code. This is not a blocker but can help
> get going easier.
This is a small architecture and a port would probably want to
use the msp430 C library. I didn't look at the license.
It appears to be divided into a "portable" and CPU model part.
Figuring out how to handle this in a general way would be required.
> * is there any free simulator that we can use to test your code on?
I came across one in Java which appears GUI heavy and didn't look
to be updated in 5 years. I saw another but the links died.
> * are there quirks with the arch that might make a port hard?
Small like the avr. C library gets tailored to microcontroller model.
Cynthia's work to use avr-libc, disable POSIX etc. and use Classic API
only would be beneficial
> Some of the issues to consider. No gcc or simulator may be blockers.
My initial impression is that even though RedHat did the port, it is
in an unmerged and possibly out-dated state.
If someone wants to dig through source and find out who did the
work, I can contact them about what happened. But at this point,
those independently maintaining it would have to have FSF assignments
and want to do the work to get it merged.
--joel
> On Apr 26, 2013 11:27 PM, "Gedare Bloom" <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> Then this might be too much for a gsoc project, but you can
> certainly propose it... definitely there is enough work, but the
> risk is whether you can achieve the goals in time.
> On Apr 26, 2013 9:33 PM, "Joel Sherrill"
> <Joel.Sherrill at oarcorp.com <mailto:Joel.Sherrill at oarcorp.com>> wrote:
> MSP430 is not a currently supported architecture. So a whole port is required.
> Should also have a libre simulator bsp
> Gedare Bloom <gedare at rtems.org <mailto:gedare at rtems.org>> wrote:
> Is the MCU supported in rtems or do you need to port it? Is it
> just a bsp or is the cpu also new for rtems?
> In general a new bsp is an ok project, and coupling it with
> something else like a GPS processing library might make a good
> project.
> -Gedare
> On Apr 26, 2013 4:06 PM, "Namrata Kamte"
> <namrata.kamte at gmail.com <mailto:namrata.kamte at gmail.com>> wrote:
> Hello,
> Thank you so much for the prompt response. I have gone
> through the Start up guide for the participating students
> and I can see that writing the proposal is quite a
> rigorous process in this case.
> Hence, I would like to pitch my project idea to you in a
> couple sentences. It is a humble request to you to tell me
> if this idea is eligible for a proposal or if it is
> completely off the topic:
> *We, at the Satellite Technology Laboratory, are working
> on Chip-scale satellites.*
> *At this juncture, we have a TI CC430 Microcontroller that
> I need to program so that it can actively communicate with
> the ground station i.e. send encoded data and be
> decoded/filtered at the ground station. We have a USRP at
> the Lab to be our ground station for testing purposes. *
> *I need to write the code that will enable the CC430 to
> receive data from the GPS chip, process it and send it
> down to the ground station.*
> Please let me know if the idea is worth writing a proposal
> for.
> Please feel free to be honest. Any kind of
> suggestion/criticism is welcome.
> Thanks and regards,
> Namrata Kamte
> Research Assistant
> The University of Texas at Arlington.
> On Fri, Apr 26, 2013 at 2:05 PM, Gedare Bloom
> I will also chime in. There is one week left for the
> deadline for
> students to submit proposals, but your project has a
> MUCH higher
> chance to be accepted if you get the proposal up early
> for reviewing
> and resubmitting. You can update your proposal as many
> times as you
> like until the deadline.
> -Gedare
> On Wed, Apr 24, 2013 at 11:04 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
> > Hi
> > Gedare reminded a student today that no matter how much
> > you talk to us or share a fabulous proposal via
> Google Docs,
> > you have to be registered with Google to be considered.
> http://www.google-melange.com/gsoc/homepage/google/gsoc2013
> > Sign up. Put a version of your proposal there with a
> link to
> > the Google Doc at the top.
> > Joel Sherrill, Ph.D. Director of Research & Development
> > joel.sherrill at OARcorp.com On-Line Applications Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
> <tel:%28256%29%20722-9985>
> > rtems-devel mailing list
> > rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
> > http://www.rtems.org/mailman/listinfo/rtems-devel
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130427/c014d060/attachment-0001.html>
