Dependencies issue with the test applications
Thu Aug 1 07:22:53 UTC 2013
On 2013-07-30 15:06, Gedare Bloom wrote:
> When I modify source code files that exist, I can just type "make" to
> rebuild rtems. However, the test suite applications are not dependent
> on the libraries, sas pointed out by Sebastian, so I also will "make
> clean" in testsuites (or whichever test suite I want to run, e.g.
> samples, or just hello) and then "make".
Yes, we all have our workarounds.  This make clean all takes considerable
longer than a simple linker invocation.  We should start to address the build
system issues in RTEMS 4.12.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
