Inconsistencies around TERMIOS_TASK_DRIVEN and deviceOutputUsesInterrupts
R. Diez
rdiezmail-rtems at yahoo.de
Thu Aug 1 10:51:33 UTC 2013
Hallo all:
File cpukit/libcsupport/include/rtems/termiostypes.h defines the following constants:
* FIXME: this should move to libio.h!
* values for rtems_termios_callbacks.outputUsesInterrupts
#define TERMIOS_POLLED 0
#define TERMIOS_IRQ_DRIVEN 1
#define TERMIOS_TASK_DRIVEN 2
However, some modules initialise rtems_termios_callbacks structures with fixed values like this:
.outputUsesInterrupts = 1,
Others use one of the constants above.
I noticed because some drivers initialise a similar field in structure console_fns with true/false, while others use the same constants as above. Routine console_open() in c/src/lib/libbsp/shared/console.c copies this flag as follows:
Callbacks.outputUsesInterrupts = cptr->pDeviceFns->deviceOutputUsesInterrupts;
That is copying information from structure console_fns to structure rtems_termios_callbacks, but cptr->pDeviceFns->deviceOutputUsesInterrupts is of type bool, whereas Callbacks.outputUsesInterrupts is an int.
What does TERMIOS_TASK_DRIVEN mean anyway? I didn't manage to find any documentation about it.
Thanks,
rdiez
