ESA SOCIS - Fault injection tools topic
    Krzysztof Mięsowicz
    krzysztof.miesowicz at gmail.com
    Thu Aug  1 12:36:51 UTC 2013
Hi,
I would also like to ask if I have to prove my ability to work with RTEMS
again (as last year I did Hello World, and then I worked on project during
SOCIS)?
Thanks in advance for replies.
Krzysiek
2013/7/29 Krzysztof Mięsowicz <krzysztof.miesowicz at gmail.com>
> Thank you for all replies very much.
> I read about libfiu and it seems really interesting and I believe it can
> be quite easy applied to RTEMS testing. I hope so :)
> According to Joel's mail:
> *Another area which we need help in is the coverage and testing
> scripts. The coverage reporting really should be by directory or
> capability. It is now reported in "lumps" that are too large.
> Also rewriting as much of this as possible in Python including the
> sim-scripts is highly desirable.*
> Do you mean that coverage reporting framework should be rewrited and
> reports should be generated for source directories instead of core and
> developmental parts (as it is done now) ?
> And what particularly do you mean by "rewriting as much of THIS as
> possible" - do you mean all coverage reporting scripts which is now written
> as bash scripts? Do I understand you correctly?
> Greetings,
> Krzysiek
> 2013/7/29 Rempel, Cynthia <cynt6007 at vandals.uidaho.edu>
> Hi,
>> Did a quick write-up on the fault-injection open-project...
>> http://blitiri.com.ar/p/libfiu/ looks interesting... (the python
>> bindings have been Debian packaged)
>> it would probably need to be evaluated more thoroughly as part of the
>> project though...
>> Thanks,
>> Cindy
>> ________________________________________
>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on
>> behalf of Rempel, Cynthia [cynt6007 at vandals.uidaho.edu]
>> Sent: Monday, July 29, 2013 9:06 AM
>> To: Joel Sherrill; Gedare Bloom
>> Cc: Krzysztof Mięsowicz; rtems-devel at rtems.org
>> Subject: RE: ESA SOCIS - Fault injection tools topic
>> Hi,
>> Thanks for the link! This will be helpful with fleshing out the project...
>> Yes, the initial idea was to get a tool the RTEMS development community
>> could use to help with certification efforts...
>> and having the certification report would be very helpful...
>> Given this information, we can start to write an open-project page for
>> this...
>> The criteria we typically use for evaluating other projects are:
>> 1. Free and open source (usually modified BSD or special exception GPLv2,
>> but as this is testing GPL would be fine)
>> 2. Works under Linux and Windows
>> 3. Still under maintainence
>> Thanks!
>> Cindy
>> behalf of Joel Sherrill [joel.sherrill at OARcorp.com]
>> Sent: Monday, July 29, 2013 8:23 AM
>> To: Gedare Bloom
>> Subject: Re: ESA SOCIS - Fault injection tools topic
>> If I forgot the link:
>> ftp://www.rtems.org/pub/rtems/esa_validation_report_450/
>> On 7/29/2013 9:45 AM, Gedare Bloom wrote:
>> > This seems like a good project. Ballista looks like it is "dead"
>> > upstream. You'll want to scope your project to decide what / how much
>> > of RTEMS you can reasonably instrument with fault injection. I also
>> > wonder if it would be sensible to first start with a tool that can
>> > support test input "fuzzing", which is related to but somewhat
>> > different than fault injection. I think "fuzzing" is more
>> > appropriately related to test coverage /testing, whereas fault
>> > injection can include also non-valid inputs and faults, such as
>> > flipping bits in code or modifying values on-the-fly.
>> > On Mon, Jul 29, 2013 at 4:25 AM, Krzysztof Mięsowicz
>> > <krzysztof.miesowicz at gmail.com> wrote:
>> >> Hi!
>> >> My name is Krzysiek. I participated in ESA SOCIS 2012 for RTEMS and
>> worked
>> >> on improving test coverage. I'm interested in participating in this
>> edition
>> >> of SOCIS again.
>> >> I browse Open Projects page of RTEMS and I have question about topic
>> related
>> >> to fault injection tools. Have you any tips or suggestions to this
>> topic
>> >> (especially which tools are most desired or promising and how this
>> project
>> >> should look in details).
>> >> I googled a bit about fault injection and free tools and find some:
>> >> Ballista, LFI, Fuzz, or JACA which potentially could be applied to
>> RTEMS
>> >> testing. But I'm looking forward to any tips or thoughts from you and
>> >> additionaly is it possible to be selected again this year.
>> >> Thanks in advance for your replies.
>> >> Krzysiek Mięsowicz
>> >> _______________________________________________
>> >> rtems-devel mailing list
>> >> http://www.rtems.org/mailman/listinfo/rtems-devel
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130801/e81a97cf/attachment.html>
