[PATCH] Updated legacy code in ata & dec21140
Vipul Nayyar
nayyar_vipul at yahoo.com
Thu Aug 1 16:30:24 UTC 2013
Ok, I understand that including irq-extension.h in libchip drivers is not required.
So, you agree that using ifdefs is the way to go. I should use IRQ API methods & rtems_interrupt_catch() for simple vectored architectures like it's done in ata.c. Right ?
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: Joel Sherrill <joel.sherrill at oarcorp.com>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Thursday, 1 August 2013 9:24 PM
Subject: Re: [PATCH] Updated legacy code in ata & dec21140
On 2013-08-01 17:41, Vipul Nayyar wrote:
> I added "#include <rtems/irq-extension.h>" in ata.c so that the generic
> methods could work. Shouldn't including the extensions header solve the problem ?
The BSPs providing the IRQ extensions API include this file via <bsp/irq.h>
indirectly and they should define BSP_FEATURE_IRQ_EXTENSION in <bsp.h>.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130802/364d7ad0/attachment.html>
