[PATCH] posix: Reimplement POSIX Key manager to use a red-black tree.
Ashi
ashi08104 at gmail.com
Fri Aug 2 11:01:22 UTC 2013
On Fri, Aug 2, 2013 at 2:38 PM, Sebastian Huber <
> On 2013-08-02 03:03, Ashi wrote:
>> + /** This field points to parent freechain node */
>> + POSIX_Keys_Freechain_node *fc_node_ptr;
>> I don't think we need this fc_node_ptr.
>> Do you mean use a 'Container' macro instead?
> Not necessarily, see below.
>> + /** This field is the POSIX key used as an rbtree key */
>> + pthread_key_t key;
>> + /** This field is the Thread id also used as an rbtree key */
>> + Objects_Id thread_id;
>> + /** This field points to the POSIX key value of specific
>> thread */
>> + void *value;
>> +} POSIX_Keys_Rbtree_node;
>> I would call this POSIX_Keys_Key_value_pair.
>> + * @brief POSIX_Keys_Freechain is used in Freechain structure
>> +typedef struct {
>> + Freechain_Control super_fc;
>> + size_t bump_count;
>> +} POSIX_Keys_Freechain;
>> + * @brief POSIX_Keys_Freechain_node is freechain node
>> +struct POSIX_Keys_Freechain_node___**struct {
>> + Chain_Node ch_node;
>> + POSIX_Keys_Rbtree_node rb_node;
>> Why not use POSIX_Keys_Rbtree_node directly?
>> Since every freechain node needs a Chain_Node in its first field. There
>> is a
>> Chain_Node in POSIX_Keys_Rbtree_node, but it is used in each thread's key
>> value chain. So I add a Chain_Node to POSIX_Keys_Rbtree_node.
> The key value pairs on the free chain are unused, thus not part of other
> data structures. So basically you can cast an unused object to any type
> provided it has enough storage.
Cool! I see. I didn't realise the whole key value pairs is actually unused
until it moves from Freechain to POSIX key value pair.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130802/155fdb61/attachment.html>
