[PATCH 01/12] score/cpu: Add CPU_Per_CPU_control
Mon Aug 5 14:08:08 UTC 2013
Add CPU port specific per-CPU control.
 cpukit/score/cpu/arm/rtems/score/cpu.h     |    6 ++++++
 cpukit/score/cpu/avr/rtems/score/cpu.h     |    6 ++++++
 cpukit/score/cpu/bfin/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/h8300/rtems/score/cpu.h   |    6 ++++++
 cpukit/score/cpu/i386/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/lm32/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/m32c/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/m32r/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/m68k/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/mips/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/cpu/moxie/rtems/score/cpu.h   |    6 ++++++
 cpukit/score/cpu/nios2/rtems/score/cpu.h   |    6 ++++++
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h  |   18 ++++++++++++++++++
 cpukit/score/cpu/powerpc/rtems/score/cpu.h |    6 ++++++
 cpukit/score/cpu/sh/rtems/score/cpu.h      |    6 ++++++
 cpukit/score/cpu/sparc/rtems/score/cpu.h   |    7 +++++++
 cpukit/score/cpu/sparc64/rtems/score/cpu.h |    6 ++++++
 cpukit/score/cpu/v850/rtems/score/cpu.h    |    6 ++++++
 cpukit/score/include/rtems/score/percpu.h  |    9 +++++++--
 cpukit/score/src/percpuasm.c               |    5 +++++
 20 files changed, 133 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index a8e9493..a11de9a 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -208,6 +208,8 @@
 #define CPU_USE_GENERIC_BITFIELD_DATA TRUE
+#define CPU_PER_CPU_CONTROL_SIZE 0
 #ifdef ARM_MULTILIB_VFP_D32
@@ -234,6 +236,10 @@ extern "C" {
 typedef struct {
+  /* There is no CPU specific per-CPU state */
+} CPU_Per_CPU_control;
+typedef struct {
 #if defined(ARM_MULTILIB_ARCH_V4)
   uint32_t register_cpsr;
   uint32_t register_r4;
diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
index 080f387..b67b241 100644
--- a/cpukit/score/cpu/avr/rtems/score/cpu.h
+++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
@@ -374,6 +374,8 @@ extern "C" {
 #define CPU_MODES_INTERRUPT_MASK   0x00000001
  *  Processor defined structures required for cpukit/score.
@@ -386,6 +388,10 @@ extern "C" {
 #ifndef ASM
+typedef struct {
  * Contexts
diff --git a/cpukit/score/cpu/bfin/rtems/score/cpu.h b/cpukit/score/cpu/bfin/rtems/score/cpu.h
index 8065bbf..e309432 100644
--- a/cpukit/score/cpu/bfin/rtems/score/cpu.h
+++ b/cpukit/score/cpu/bfin/rtems/score/cpu.h
@@ -397,6 +397,8 @@ extern "C" {
@@ -407,6 +409,10 @@ extern "C" {
 /* may need to put some structures here.  */
+typedef struct {
  * @defgroup CPUContext Processor Dependent Context Management
diff --git a/cpukit/score/cpu/h8300/rtems/score/cpu.h b/cpukit/score/cpu/h8300/rtems/score/cpu.h
index ea0ee7c..f75f2e5 100644
--- a/cpukit/score/cpu/h8300/rtems/score/cpu.h
+++ b/cpukit/score/cpu/h8300/rtems/score/cpu.h
@@ -342,6 +342,8 @@ extern "C" {
@@ -393,6 +395,10 @@ extern "C" {
 #ifndef ASM
+typedef struct {
 #define nogap __attribute__ ((packed))
 typedef struct {
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index d23926e..43422ed 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -126,10 +126,16 @@ extern "C" {
 #define CPU_BIG_ENDIAN                           FALSE
 #define CPU_LITTLE_ENDIAN                        TRUE
 /* structures */
 #ifndef ASM
+typedef struct {
  *  Basic integer context for the i386 family.
diff --git a/cpukit/score/cpu/lm32/rtems/score/cpu.h b/cpukit/score/cpu/lm32/rtems/score/cpu.h
index eef9ac8..95553ef 100644
--- a/cpukit/score/cpu/lm32/rtems/score/cpu.h
+++ b/cpukit/score/cpu/lm32/rtems/score/cpu.h
@@ -391,6 +391,8 @@ extern "C" {
@@ -401,6 +403,10 @@ extern "C" {
+typedef struct {
diff --git a/cpukit/score/cpu/m32c/rtems/score/cpu.h b/cpukit/score/cpu/m32c/rtems/score/cpu.h
index ccb9e38..5841885 100644
--- a/cpukit/score/cpu/m32c/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32c/rtems/score/cpu.h
@@ -414,6 +414,8 @@ extern "C" {
@@ -424,6 +426,10 @@ extern "C" {
+typedef struct {
diff --git a/cpukit/score/cpu/m32r/rtems/score/cpu.h b/cpukit/score/cpu/m32r/rtems/score/cpu.h
index 2c97ddb..0fea7bd 100644
--- a/cpukit/score/cpu/m32r/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m32r/rtems/score/cpu.h
@@ -407,6 +407,8 @@ extern "C" {
@@ -417,6 +419,10 @@ extern "C" {
+typedef struct {
diff --git a/cpukit/score/cpu/m68k/rtems/score/cpu.h b/cpukit/score/cpu/m68k/rtems/score/cpu.h
index 2af5be8..ccec3a6 100644
--- a/cpukit/score/cpu/m68k/rtems/score/cpu.h
+++ b/cpukit/score/cpu/m68k/rtems/score/cpu.h
@@ -112,6 +112,8 @@ extern "C" {
 #define CPU_BIG_ENDIAN                           TRUE
 #define CPU_LITTLE_ENDIAN                        FALSE
 #if ( CPU_HARDWARE_FP == TRUE ) && !defined( __mcoldfire__ )
   #if defined( __mc68060__ )
     #define M68K_FP_STATE_SIZE 16
@@ -124,6 +126,10 @@ extern "C" {
 /* structures */
+typedef struct {
  *  Basic integer context for the m68k family.
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index 229490b..beb03bf 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -353,6 +353,8 @@ extern "C" {
 #define CPU_SIZEOF_POINTER 4
@@ -399,6 +401,10 @@ extern "C" {
 #ifndef ASM
+typedef struct {
 /* WARNING: If this structure is modified, the constants in cpu.h must be updated. */
 #if (__mips == 1) || (__mips == 32)
 #define __MIPS_REGISTER_TYPE     uint32_t
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index 7c48d7b..309110a 100644
--- a/cpukit/score/cpu/moxie/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -330,6 +330,8 @@ extern "C" {
@@ -340,6 +342,10 @@ extern "C" {
+typedef struct {
  * Contexts
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index d3b5046..e0dfd9f 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -112,8 +112,14 @@ extern "C" {
 #define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
 #ifndef ASM
+typedef struct {
  * @brief Thread register context.
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 0ffce81..391ade1 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -474,6 +474,14 @@ extern "C" {
+ * @brief The size of the CPU specific per-CPU control.
+ * This define must be visible to assember files since it is used to derive
+ * structure offsets.
@@ -485,6 +493,16 @@ extern "C" {
+ * @brief The CPU specific per-CPU control.
+ * The CPU port can place here all state information that must be available and
+ * maintained for each CPU in the system.
+typedef struct {
+  /* CPU specific per-CPU state */
  * From the highest level viewpoint, there are 2 types of context to save.
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 1ad56dc..3d88d9d 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -212,6 +212,8 @@ extern "C" {
 #define CPU_IDLE_TASK_IS_FP      FALSE
@@ -267,6 +269,10 @@ extern "C" {
 #ifndef ASM
+typedef struct {
 /* Non-volatile context according to E500ABIUG and EABI */
 typedef struct {
   uint32_t gpr1;
diff --git a/cpukit/score/cpu/sh/rtems/score/cpu.h b/cpukit/score/cpu/sh/rtems/score/cpu.h
index d4412f6..41d9638 100644
--- a/cpukit/score/cpu/sh/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sh/rtems/score/cpu.h
@@ -297,12 +297,18 @@ extern "C" {
 #define CPU_MODES_INTERRUPT_MASK   0x0000000f
+typedef struct {
  * Contexts
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 20040a9..61f0410 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -357,6 +357,8 @@ typedef struct {
 /** This defines the size of the minimum stack frame. */
 #define CPU_MINIMUM_STACK_FRAME_SIZE          0x60
  * @defgroup Contexts SPARC Context Structures
@@ -379,6 +381,11 @@ typedef struct {
 #ifndef ASM
+typedef struct {
  * @brief SPARC basic context.
diff --git a/cpukit/score/cpu/sparc64/rtems/score/cpu.h b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
index 314143b..8d3e273 100644
--- a/cpukit/score/cpu/sparc64/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc64/rtems/score/cpu.h
@@ -224,6 +224,8 @@ extern "C" {
 #define CPU_MODES_INTERRUPT_MASK   0x0000000F
  *  This structure represents the organization of the minimum stack frame
  *  for the SPARC.  More framing information is required in certain situaions
 #ifndef ASM
 typedef struct {
+typedef struct {
   uint64_t    l0;
   uint64_t    l1;
   uint64_t    l2;
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 12c824b..3e110b5 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -395,6 +395,12 @@ extern "C" {
+typedef struct {
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 14eed5a..e6713bf 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -141,6 +141,11 @@ typedef enum {
  *  This structure is used to hold per core state information.
 typedef struct {
+   * @brief CPU port specific control.
+  CPU_Per_CPU_control cpu_per_cpu;
   #if (CPU_ALLOCATE_INTERRUPT_STACK == TRUE) || \
       (CPU_HAS_SOFTWARE_INTERRUPT_STACK == TRUE)
@@ -310,7 +315,7 @@ void _Per_CPU_Wait_for_state(
    *  we need to have places in the per CPU table to hold them.
   #define PER_CPU_INTERRUPT_STACK_LOW \
-    0
+    CPU_PER_CPU_CONTROL_SIZE
   #define PER_CPU_INTERRUPT_STACK_HIGH \
     PER_CPU_INTERRUPT_STACK_LOW + CPU_SIZEOF_POINTER
   #define PER_CPU_END_STACK             \
@@ -322,7 +327,7 @@ void _Per_CPU_Wait_for_state(
     (SYM(_Per_CPU_Information) + PER_CPU_INTERRUPT_STACK_HIGH)
 #else
-    0
 #endif
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 60ca48d..968bc48 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -33,6 +33,11 @@ RTEMS_STATIC_ASSERT(
 #endif
+RTEMS_STATIC_ASSERT(
+  sizeof( CPU_Per_CPU_control ) == CPU_PER_CPU_CONTROL_SIZE,
 #if defined( RTEMS_SMP )
     sizeof( Per_CPU_Control_envelope ) == PER_CPU_CONTROL_SIZE,
1.7.7
