[PATCH 09/12] sparc: Move _CPU_Context_switch(), etc.
Mon Aug 5 14:08:16 UTC 2013
Move the _CPU_Context_switch(), _CPU_Context_restore() and
_CPU_Context_switch_to_first_task_smp() code since the method to obtain
the processor index is BSP specific.
 c/src/lib/libbsp/sparc/shared/irq_asm.S |  224 +++++++++++++++++++++++++++++++
 cpukit/score/cpu/sparc/cpu_asm.S        |  224 -------------------------------
 2 files changed, 224 insertions(+), 224 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index f28046d..d0550df 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -42,6 +42,230 @@
 .endm
+ *  void _CPU_Context_switch(
+ *    Context_Control  *run,
+ *    Context_Control  *heir
+ *  This routine performs a normal non-FP context switch.
+        .align 4
+        PUBLIC(_CPU_Context_switch)
+SYM(_CPU_Context_switch):
+        ! skip g0
+        st      %g1, [%o0 + G1_OFFSET]       ! save the global registers
+        std     %g2, [%o0 + G2_OFFSET]
+        std     %g4, [%o0 + G4_OFFSET]
+        std     %g6, [%o0 + G6_OFFSET]
+        ! load the address of the ISR stack nesting prevention flag
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %g2
+        ld       [%g2 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %g2
+        ! save it a bit later so we do not waste a couple of cycles
+        std     %l0, [%o0 + L0_OFFSET]       ! save the local registers
+        std     %l2, [%o0 + L2_OFFSET]
+        std     %l4, [%o0 + L4_OFFSET]
+        std     %l6, [%o0 + L6_OFFSET]
+        ! Now actually save ISR stack nesting prevention flag
+        st       %g2, [%o0 + ISR_DISPATCH_DISABLE_STACK_OFFSET]
+        std     %i0, [%o0 + I0_OFFSET]       ! save the input registers
+        std     %i2, [%o0 + I2_OFFSET]
+        std     %i4, [%o0 + I4_OFFSET]
+        std     %i6, [%o0 + I6_FP_OFFSET]
+        std     %o0, [%o0 + O0_OFFSET]       ! save the output registers
+        std     %o2, [%o0 + O2_OFFSET]
+        std     %o4, [%o0 + O4_OFFSET]
+        std     %o6, [%o0 + O6_SP_OFFSET]
+        rd      %psr, %o2
+        st      %o2, [%o0 + PSR_OFFSET]      ! save status register
+         *  This is entered from _CPU_Context_restore with:
+         *    o1 = context to restore
+         *    o2 = psr
+        PUBLIC(_CPU_Context_restore_heir)
+SYM(_CPU_Context_restore_heir):
+         *  Flush all windows with valid contents except the current one.
+         *  In examining the set register windows, one may logically divide
+         *  the windows into sets (some of which may be empty) based on their
+         *  current status:
+         *    + current (i.e. in use),
+         *    + used (i.e. a restore would not trap)
+         *    + invalid (i.e. 1 in corresponding bit in WIM)
+         *    + unused
+         *  Either the used or unused set of windows may be empty.
+         *  NOTE: We assume only one bit is set in the WIM at a time.
+         *  Given a CWP of 5 and a WIM of 0x1, the registers are divided
+         *  into sets as follows:
+         *    + 0   - invalid
+         *    + 1-4 - unused
+         *    + 5   - current
+         *    + 6-7 - used
+         *  In this case, we only would save the used windows -- 6 and 7.
+         *   Traps are disabled for the same logical period as in a
+         *     flush all windows trap handler.
+         *    Register Usage while saving the windows:
+         *      g1 = current PSR
+         *      g2 = current wim
+         *      g3 = CWP
+         *      g4 = wim scratch
+         *      g5 = scratch
+        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = saved psr
+        and     %o2, SPARC_PSR_CWP_MASK, %g3  ! g3 = CWP
+                                              ! g1 = psr w/o cwp
+        andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
+        or      %g1, %g3, %g1                 ! g1 = heirs psr
+        mov     %g1, %psr                     ! restore status register and
+                                              ! **** DISABLE TRAPS ****
+        mov     %wim, %g2                     ! g2 = wim
+        mov     1, %g4
+        sll     %g4, %g3, %g4                 ! g4 = WIM mask for CW invalid
+save_frame_loop:
+        sll     %g4, 1, %g5                   ! rotate the "wim" left 1
+        srl     %g4, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g4
+        or      %g4, %g5, %g4                 ! g4 = wim if we do one restore
+         *  If a restore would not underflow, then continue.
+        andcc   %g4, %g2, %g0                 ! Any windows to flush?
+        bnz     done_flushing                 ! No, then continue
+        nop
+        restore                               ! back one window
+         *  Now save the window just as if we overflowed to it.
+        std     %l0, [%sp + CPU_STACK_FRAME_L0_OFFSET]
+        std     %l2, [%sp + CPU_STACK_FRAME_L2_OFFSET]
+        std     %l4, [%sp + CPU_STACK_FRAME_L4_OFFSET]
+        std     %l6, [%sp + CPU_STACK_FRAME_L6_OFFSET]
+        std     %i0, [%sp + CPU_STACK_FRAME_I0_OFFSET]
+        std     %i2, [%sp + CPU_STACK_FRAME_I2_OFFSET]
+        std     %i4, [%sp + CPU_STACK_FRAME_I4_OFFSET]
+        std     %i6, [%sp + CPU_STACK_FRAME_I6_FP_OFFSET]
+        ba      save_frame_loop
+        nop
+done_flushing:
+        add     %g3, 1, %g3                   ! calculate desired WIM
+        and     %g3, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
+        mov     1, %g4
+        sll     %g4, %g3, %g4                 ! g4 = new WIM
+        mov     %g4, %wim
+        or      %g1, SPARC_PSR_ET_MASK, %g1
+        mov     %g1, %psr                     ! **** ENABLE TRAPS ****
+                                              !   and restore CWP
+        nop
+        nop
+        nop
+        ! skip g0
+        ld      [%o1 + G1_OFFSET], %g1        ! restore the global registers
+        ldd     [%o1 + G2_OFFSET], %g2
+        ldd     [%o1 + G4_OFFSET], %g4
+        ldd     [%o1 + G6_OFFSET], %g6
+        ! Load thread specific ISR dispatch prevention flag
+        ld      [%o1 + ISR_DISPATCH_DISABLE_STACK_OFFSET], %o2
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %o3
+        ! Store it to memory later to use the cycles
+        ldd     [%o1 + L0_OFFSET], %l0        ! restore the local registers
+        ldd     [%o1 + L2_OFFSET], %l2
+        ldd     [%o1 + L4_OFFSET], %l4
+        ldd     [%o1 + L6_OFFSET], %l6
+        ! Now restore thread specific ISR dispatch prevention flag
+        st       %o2,[%o3 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+        ldd     [%o1 + I0_OFFSET], %i0        ! restore the output registers
+        ldd     [%o1 + I2_OFFSET], %i2
+        ldd     [%o1 + I4_OFFSET], %i4
+        ldd     [%o1 + I6_FP_OFFSET], %i6
+        ldd     [%o1 + O2_OFFSET], %o2        ! restore the output registers
+        ldd     [%o1 + O4_OFFSET], %o4
+        ldd     [%o1 + O6_SP_OFFSET], %o6
+        ! do o0/o1 last to avoid destroying heir context pointer
+        ldd     [%o1 + O0_OFFSET], %o0        ! overwrite heir pointer
+        jmp     %o7 + 8                       ! return
+        nop                                   ! delay slot
+ *  void _CPU_Context_restore(
+ *    Context_Control *new_context
+ *  This routine is generally used only to perform restart self.
+ *  NOTE: It is unnecessary to reload some registers.
+        .align 4
+        PUBLIC(_CPU_Context_restore)
+SYM(_CPU_Context_restore):
+        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
+        rd      %psr, %o2
+        ba      SYM(_CPU_Context_restore_heir)
+        mov     %i0, %o1                      ! in the delay slot
+        .align 4
+#if defined(RTEMS_SMP)
+ *  void _CPU_Context_switch_to_first_task_smp(
+ *  This routine is only used to switch to the first task on a
+ *  secondary core in an SMP configuration.  We do not need to
+ *  flush any windows and, in fact, this can be dangerous
+ *  as they may or may not be initialized properly.  So we just
+ *  reinitialize the PSR and WIM.
+        PUBLIC(_CPU_Context_switch_to_first_task_smp)
+SYM(_CPU_Context_switch_to_first_task_smp):
+	mov	%psr, %g1		! Turn of traps when modifying WIM
+	andn	%g1, SPARC_PSR_ET_MASK, %g1
+	mov	%g1, %psr
+	/* WIM and PSR will be set in done_flushing, it need args:
+	 * g1=PSR, g3=CWP, o1=Context
+	and	%g1, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
+	nop
+	mov	%o0, %o1		! in the delay slot
+	ba,a	done_flushing
+#endif
  *  void _ISR_Handler()
  *  This routine provides the RTEMS interrupt management.
diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
index ac8d799..a9d1326 100644
--- a/cpukit/score/cpu/sparc/cpu_asm.S
+++ b/cpukit/score/cpu/sparc/cpu_asm.S
@@ -128,228 +128,4 @@ SYM(_CPU_Context_restore_fp):
 #endif /* SPARC_HAS_FPU */
- *  void _CPU_Context_switch(
- *    Context_Control  *run,
- *    Context_Control  *heir
- *  This routine performs a normal non-FP context switch.
-        .align 4
-        PUBLIC(_CPU_Context_switch)
-SYM(_CPU_Context_switch):
-        ! skip g0
-        st      %g1, [%o0 + G1_OFFSET]       ! save the global registers
-        std     %g2, [%o0 + G2_OFFSET]
-        std     %g4, [%o0 + G4_OFFSET]
-        std     %g6, [%o0 + G6_OFFSET]
-        ! load the address of the ISR stack nesting prevention flag
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %g2
-        ld       [%g2 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %g2
-        ! save it a bit later so we do not waste a couple of cycles
-        std     %l0, [%o0 + L0_OFFSET]       ! save the local registers
-        std     %l2, [%o0 + L2_OFFSET]
-        std     %l4, [%o0 + L4_OFFSET]
-        std     %l6, [%o0 + L6_OFFSET]
-        ! Now actually save ISR stack nesting prevention flag
-        st       %g2, [%o0 + ISR_DISPATCH_DISABLE_STACK_OFFSET]
-        std     %i0, [%o0 + I0_OFFSET]       ! save the input registers
-        std     %i2, [%o0 + I2_OFFSET]
-        std     %i4, [%o0 + I4_OFFSET]
-        std     %i6, [%o0 + I6_FP_OFFSET]
-        std     %o0, [%o0 + O0_OFFSET]       ! save the output registers
-        std     %o2, [%o0 + O2_OFFSET]
-        std     %o4, [%o0 + O4_OFFSET]
-        std     %o6, [%o0 + O6_SP_OFFSET]
-        rd      %psr, %o2
-        st      %o2, [%o0 + PSR_OFFSET]      ! save status register
-         *  This is entered from _CPU_Context_restore with:
-         *    o1 = context to restore
-         *    o2 = psr
-        PUBLIC(_CPU_Context_restore_heir)
-SYM(_CPU_Context_restore_heir):
-         *  Flush all windows with valid contents except the current one.
-         *  In examining the set register windows, one may logically divide
-         *  the windows into sets (some of which may be empty) based on their
-         *  current status:
-         *    + current (i.e. in use),
-         *    + used (i.e. a restore would not trap)
-         *    + invalid (i.e. 1 in corresponding bit in WIM)
-         *    + unused
-         *  Either the used or unused set of windows may be empty.
-         *  NOTE: We assume only one bit is set in the WIM at a time.
-         *  Given a CWP of 5 and a WIM of 0x1, the registers are divided
-         *  into sets as follows:
-         *    + 0   - invalid
-         *    + 1-4 - unused
-         *    + 5   - current
-         *    + 6-7 - used
-         *  In this case, we only would save the used windows -- 6 and 7.
-         *   Traps are disabled for the same logical period as in a
-         *     flush all windows trap handler.
-         *    Register Usage while saving the windows:
-         *      g1 = current PSR
-         *      g2 = current wim
-         *      g3 = CWP
-         *      g4 = wim scratch
-         *      g5 = scratch
-        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = saved psr
-        and     %o2, SPARC_PSR_CWP_MASK, %g3  ! g3 = CWP
-                                              ! g1 = psr w/o cwp
-        andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
-        or      %g1, %g3, %g1                 ! g1 = heirs psr
-        mov     %g1, %psr                     ! restore status register and
-                                              ! **** DISABLE TRAPS ****
-        mov     %wim, %g2                     ! g2 = wim
-        mov     1, %g4
-        sll     %g4, %g3, %g4                 ! g4 = WIM mask for CW invalid
-save_frame_loop:
-        sll     %g4, 1, %g5                   ! rotate the "wim" left 1
-        srl     %g4, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g4
-        or      %g4, %g5, %g4                 ! g4 = wim if we do one restore
-         *  If a restore would not underflow, then continue.
-        andcc   %g4, %g2, %g0                 ! Any windows to flush?
-        bnz     done_flushing                 ! No, then continue
-        nop
-        restore                               ! back one window
-         *  Now save the window just as if we overflowed to it.
-        std     %l0, [%sp + CPU_STACK_FRAME_L0_OFFSET]
-        std     %l2, [%sp + CPU_STACK_FRAME_L2_OFFSET]
-        std     %l4, [%sp + CPU_STACK_FRAME_L4_OFFSET]
-        std     %l6, [%sp + CPU_STACK_FRAME_L6_OFFSET]
-        std     %i0, [%sp + CPU_STACK_FRAME_I0_OFFSET]
-        std     %i2, [%sp + CPU_STACK_FRAME_I2_OFFSET]
-        std     %i4, [%sp + CPU_STACK_FRAME_I4_OFFSET]
-        std     %i6, [%sp + CPU_STACK_FRAME_I6_FP_OFFSET]
-        ba      save_frame_loop
-        nop
-done_flushing:
-        add     %g3, 1, %g3                   ! calculate desired WIM
-        and     %g3, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
-        mov     1, %g4
-        sll     %g4, %g3, %g4                 ! g4 = new WIM
-        mov     %g4, %wim
-        or      %g1, SPARC_PSR_ET_MASK, %g1
-        mov     %g1, %psr                     ! **** ENABLE TRAPS ****
-                                              !   and restore CWP
-        nop
-        nop
-        nop
-        ! skip g0
-        ld      [%o1 + G1_OFFSET], %g1        ! restore the global registers
-        ldd     [%o1 + G2_OFFSET], %g2
-        ldd     [%o1 + G4_OFFSET], %g4
-        ldd     [%o1 + G6_OFFSET], %g6
-        ! Load thread specific ISR dispatch prevention flag
-        ld      [%o1 + ISR_DISPATCH_DISABLE_STACK_OFFSET], %o2
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %o3
-        ! Store it to memory later to use the cycles
-        ldd     [%o1 + L0_OFFSET], %l0        ! restore the local registers
-        ldd     [%o1 + L2_OFFSET], %l2
-        ldd     [%o1 + L4_OFFSET], %l4
-        ldd     [%o1 + L6_OFFSET], %l6
-        ! Now restore thread specific ISR dispatch prevention flag
-        st       %o2,[%o3 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
-        ldd     [%o1 + I0_OFFSET], %i0        ! restore the output registers
-        ldd     [%o1 + I2_OFFSET], %i2
-        ldd     [%o1 + I4_OFFSET], %i4
-        ldd     [%o1 + I6_FP_OFFSET], %i6
-        ldd     [%o1 + O2_OFFSET], %o2        ! restore the output registers
-        ldd     [%o1 + O4_OFFSET], %o4
-        ldd     [%o1 + O6_SP_OFFSET], %o6
-        ! do o0/o1 last to avoid destroying heir context pointer
-        ldd     [%o1 + O0_OFFSET], %o0        ! overwrite heir pointer
-        jmp     %o7 + 8                       ! return
-        nop                                   ! delay slot
- *  void _CPU_Context_restore(
- *    Context_Control *new_context
- *  This routine is generally used only to perform restart self.
- *  NOTE: It is unnecessary to reload some registers.
-        .align 4
-        PUBLIC(_CPU_Context_restore)
-SYM(_CPU_Context_restore):
-        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
-        rd      %psr, %o2
-        ba      SYM(_CPU_Context_restore_heir)
-        mov     %i0, %o1                      ! in the delay slot
-        .align 4
-#if defined(RTEMS_SMP)
- *  void _CPU_Context_switch_to_first_task_smp(
- *  This routine is only used to switch to the first task on a
- *  secondary core in an SMP configuration.  We do not need to
- *  flush any windows and, in fact, this can be dangerous
- *  as they may or may not be initialized properly.  So we just
- *  reinitialize the PSR and WIM.
-        PUBLIC(_CPU_Context_switch_to_first_task_smp)
-SYM(_CPU_Context_switch_to_first_task_smp):
-	mov	%psr, %g1		! Turn of traps when modifying WIM
-	andn	%g1, SPARC_PSR_ET_MASK, %g1
-	mov	%g1, %psr
-	/* WIM and PSR will be set in done_flushing, it need args:
-	 * g1=PSR, g3=CWP, o1=Context
-	and	%g1, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
-	nop
-	mov	%o0, %o1		! in the delay slot
-	ba,a	done_flushing
-#endif
 /* end of file */
1.7.7
