Please summarize isr SMP changes
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Aug 5 14:20:30 UTC 2013
Hi
I can't tell what the ultimate result of all these changes is. I see code using the per CPU structure without indexing it but can't tell if that is uniprocessor specific.
Can you please write up the intended design/behavior? Ultimately that needs to be in the porting guide.
