[PATCH v2] score: Per-CPU thread dispatch disable level
Tue Aug 6 11:09:36 UTC 2013
Use a per-CPU thread dispatch disable level.  So instead of one global
thread dispatch disable level we have now one instance per processor.
This is a major performance improvement for SMP.  On non-SMP
configurations this may simplifiy the interrupt entry/exit code.
The giant lock is still present, but it is now decoupled from the thread
dispatching in _Thread_Dispatch(), _Thread_Handler(),
_Thread_Restart_self() and the interrupt entry/exit.   Access to the
giant lock is now available via _Giant_Acquire() and _Giant_Release().
The giant lock is still implicitly acquired via
_Thread_Dispatch_decrement_disable_level().
The giant lock is only acquired for high-level operations in interrupt
handlers (e.g. release of a semaphore, sending of an event).
As a side-effect this change fixes the lost thread dispatch necessary
indication bug in _Thread_Dispatch().
A per-CPU thread dispatch disable level greatly simplifies the SMP
support for the interrupt entry/exit code since no spin locks have to be
acquired in this area.  It is only necessary to get the current
processor index and use this to calculate the address of the own per-CPU
control.  This reduces the interrupt latency considerably.
All elements for the interrupt entry/exit code are now part of the
Per_CPU_Control structure: thread dispatch disable level, ISR nest level
and thread dispatch necessary.  Nothing else is required (except CPU
port specific stuff like on SPARC).
 cpukit/rtems/src/taskrestart.c                     |   10 ++-
 cpukit/score/Makefile.am                           |    1 -
 cpukit/score/include/rtems/score/isr.h             |   22 ----
 cpukit/score/include/rtems/score/objectimpl.h      |   17 +++
 cpukit/score/include/rtems/score/percpu.h          |   21 +++-
 cpukit/score/include/rtems/score/threaddispatch.h  |   95 ++++++++--------
 cpukit/score/include/rtems/score/threadimpl.h      |    4 +
 .../score/src/assertthreaddispatchingrepressed.c   |   11 ++-
 cpukit/score/src/isrsmp.c                          |   76 -------------
 cpukit/score/src/percpuasm.c                       |    6 +
 cpukit/score/src/schedulersimplesmp.c              |   10 ++
 cpukit/score/src/threaddispatch.c                  |  107 ++++++++----------
 cpukit/score/src/threaddispatchdisablelevel.c      |  119 +++++++++++++-------
 cpukit/score/src/threadhandler.c                   |   90 ++++++++++++---
 cpukit/score/src/threadloadenv.c                   |   14 ++-
 cpukit/score/src/threadrestart.c                   |    3 -
 cpukit/score/src/threadstartmultitasking.c         |    9 +-
 testsuites/tmtests/tm26/task1.c                    |   36 ++++---
 18 files changed, 361 insertions(+), 290 deletions(-)
 delete mode 100644 cpukit/score/src/isrsmp.c
diff --git a/cpukit/rtems/src/taskrestart.c b/cpukit/rtems/src/taskrestart.c
index 10b159d..27b1ec4 100644
--- a/cpukit/rtems/src/taskrestart.c
+++ b/cpukit/rtems/src/taskrestart.c
@@ -34,7 +34,15 @@ rtems_status_code rtems_task_restart(
     case OBJECTS_LOCAL:
       if ( _Thread_Restart( the_thread, NULL, argument ) ) {
-        _Objects_Put( &the_thread->Object );
+        if ( _Thread_Is_executing( the_thread ) ) {
+          _Objects_Put_and_keep_thread_dispatch_disabled(
+            &the_thread->Object
+          _Thread_Restart_self();
+        } else {
+          _Objects_Put( &the_thread->Object );
         return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 173f151..4f9164c 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -118,7 +118,6 @@ libscore_a_SOURCES += src/mpci.c src/objectmp.c src/threadmp.c
 endif
 if HAS_SMP
-libscore_a_SOURCES += src/isrsmp.c
 libscore_a_SOURCES += src/schedulersimplesmp.c
 libscore_a_SOURCES += src/smp.c
 endif
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index 8d57db2..4d4a5f3 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -96,28 +96,6 @@ SCORE_EXTERN ISR_Handler_entry *_ISR_Vector_table;
 void _ISR_Handler_initialization ( void );
-#if defined( RTEMS_SMP )
- *  @brief Enter SMP interrupt code.
- *  This method is used to enter the SMP interrupt section.
- *  @retval This method returns the isr level.
-int _ISR_SMP_Enter(void);
- *  @brief Exit SMP interrupt code.
- *  This method is used to exit the SMP interrupt.
- *  @retval This method returns 0 on a simple return and returns 1 on a
- *  dispatching return.
-int _ISR_SMP_Exit(void);
-#endif /* defined( RTEMS_SMP ) */
  *  @brief Install interrupt handler vector.
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index c7ed94c..c6c870f 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -880,6 +880,23 @@ RTEMS_INLINE_ROUTINE void _Objects_Put_without_thread_dispatch(
+ * @brief Puts back an object obtained with _Objects_Get().
+ * The thread dispatch disable level will remain unchanged.
+ * On SMP configurations the Giant lock will be released.
+RTEMS_INLINE_ROUTINE void _Objects_Put_and_keep_thread_dispatch_disabled(
+  Objects_Control *the_object
+  (void) the_object;
+#if defined(RTEMS_SMP)
+  _Giant_Release();
+#endif
  * @brief Puts back an object obtained with _Objects_Get_isr_disable().
 RTEMS_INLINE_ROUTINE void _Objects_Put_for_get_isr_disable(
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 7a4c70e..0ba4bbe 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -166,6 +166,12 @@ typedef struct {
   uint32_t isr_nest_level;
+   * @brief The thread dispatch critical section nesting counter which is used
+   * to prevent context switches at inopportune moments.
+  volatile uint32_t thread_dispatch_disable_level;
   /** This is set to true when this CPU needs to run the dispatcher. */
   volatile bool dispatch_necessary;
@@ -267,9 +273,14 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
 static inline Per_CPU_Control *_Per_CPU_Get( void )
-  _Assert_Thread_dispatching_repressed();
+  Per_CPU_Control *per_cpu =
+    &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu;
-  return &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu;
+  _Assert(
+    per_cpu->thread_dispatch_disable_level != 0 || _ISR_Get_level() != 0
+  return per_cpu;
 #else
 #define _Per_CPU_Get() ( &_Per_CPU_Information[ 0 ].per_cpu )
@@ -325,6 +336,8 @@ void _Per_CPU_Wait_for_state(
  * On a non SMP system, the _SMP_Get_current_processor() is defined to 0.
  * Thus when built for non-SMP, there should be no performance penalty.
+#define _Thread_Dispatch_disable_level \
+  _Per_CPU_Get()->thread_dispatch_disable_level
 #define _Thread_Heir \
   _Per_CPU_Get()->heir
 #define _Thread_Executing \
@@ -373,8 +386,10 @@ void _Per_CPU_Wait_for_state(
 #define PER_CPU_ISR_NEST_LEVEL \
   PER_CPU_END_STACK
-#define PER_CPU_DISPATCH_NEEDED \
+#define PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL \
   PER_CPU_ISR_NEST_LEVEL + 4
+#define PER_CPU_DISPATCH_NEEDED \
+  PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL + 4
 #define ISR_NEST_LEVEL \
   (SYM(_Per_CPU_Information) + PER_CPU_ISR_NEST_LEVEL)
diff --git a/cpukit/score/include/rtems/score/threaddispatch.h b/cpukit/score/include/rtems/score/threaddispatch.h
index 7e7afb9..9cd1287 100644
--- a/cpukit/score/include/rtems/score/threaddispatch.h
+++ b/cpukit/score/include/rtems/score/threaddispatch.h
@@ -14,7 +14,7 @@
 #ifndef _RTEMS_SCORE_THREADDISPATCH_H
 #define _RTEMS_SCORE_THREADDISPATCH_H
-#include <rtems/score/cpu.h>
+#include <rtems/score/percpu.h>
 #include <rtems/score/smplock.h>
 #ifdef __cplusplus
@@ -40,13 +40,6 @@ extern "C" {
- *  The following declares the dispatch critical section nesting
- *  counter which is used to prevent context switches at inopportune
- *  moments.
-SCORE_EXTERN volatile uint32_t   _Thread_Dispatch_disable_level;
  * @brief Indicates if the executing thread is inside a thread dispatch
  * critical section.
@@ -56,36 +49,64 @@ SCORE_EXTERN volatile uint32_t   _Thread_Dispatch_disable_level;
 RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
-  return _Thread_Dispatch_disable_level == 0;
+  bool enabled;
-  typedef struct {
-    SMP_lock_Control lock;
-    uint32_t owner_cpu;
-    uint32_t nest_level;
-  } Thread_Dispatch_disable_level_lock_control;
+  ISR_Level level;
-   * The following declares the smp spinlock to be used to control
-   * the dispatch critical section accesses across cpus.
-  SCORE_EXTERN Thread_Dispatch_disable_level_lock_control
-    _Thread_Dispatch_disable_level_lock;
+  _ISR_Disable( level );
+#endif
+  enabled = _Thread_Dispatch_disable_level == 0;
+  _ISR_Enable( level );
+#endif
+  return enabled;
+ * @briefs Gets thread dispatch disable level.
+ * @return The value of the thread dispatch level.
+RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level(void)
+  return _Thread_Dispatch_disable_level;
+ * @brief Thread dispatch initialization.
+ * This routine initializes the thread dispatching subsystem.
+RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization( void )
+  _Thread_Dispatch_disable_level = 1;
-   *  @brief Initializes the thread dispatching subsystem.
+   * @brief Acquires the giant lock.
+   * The giant lock is a recursive SMP lock protecting nearly all operating
+   * system services.
+   * This lock is implicitly acquired in
+   * _Thread_Dispatch_increment_disable_level().
-   *  This routine initializes the thread dispatching subsystem.
+   * Thread dispatching must be disabled before this lock can be acquired.
-  void _Thread_Dispatch_initialization(void);
+  void _Giant_Acquire( void );
-   *  @brief Returns value of the the thread dispatch level.
+   * @brief Releases the giant lock.
-   * This routine returns value of the the thread dispatch level.
+   * This lock is implicitly released in
+   * _Thread_Dispatch_decrement_disable_level().
-  uint32_t _Thread_Dispatch_get_disable_level(void);
+  void _Giant_Release( void );
    *  @brief Sets thread dispatch level to the value passed in.
@@ -110,16 +131,6 @@ RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
   uint32_t _Thread_Dispatch_decrement_disable_level(void);
 #else /* RTEMS_SMP */
-   * @brief Get thread dispatch disable level.
-  RTEMS_INLINE_ROUTINE uint32_t _Thread_Dispatch_get_disable_level(void)
-    return _Thread_Dispatch_disable_level;
    * @brief Set thread dispatch disable level.
    * This routine sets thread dispatch level to the
@@ -160,16 +171,6 @@ RTEMS_INLINE_ROUTINE bool _Thread_Dispatch_is_enabled(void)
     return level;
-   * @brief Thread dispatch initialization.
-  RTEMS_INLINE_ROUTINE void _Thread_Dispatch_initialization( void )
-    _Thread_Dispatch_set_disable_level( 1 );
 #endif /* RTEMS_SMP */
diff --git a/cpukit/score/include/rtems/score/threadimpl.h b/cpukit/score/include/rtems/score/threadimpl.h
index 128820b..06d4ee6 100644
--- a/cpukit/score/include/rtems/score/threadimpl.h
+++ b/cpukit/score/include/rtems/score/threadimpl.h
@@ -527,6 +527,10 @@ RTEMS_INLINE_ROUTINE void _Thread_Unblock (
 RTEMS_INLINE_ROUTINE void _Thread_Restart_self( void )
+  _Per_CPU_Acquire( _Per_CPU_Get() );
+#endif
 #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
   if ( _Thread_Executing->fp_context != NULL )
     _Context_Restore_fp( &_Thread_Executing->fp_context );
diff --git a/cpukit/score/src/assertthreaddispatchingrepressed.c b/cpukit/score/src/assertthreaddispatchingrepressed.c
index 44907f6..0d586f8 100644
--- a/cpukit/score/src/assertthreaddispatchingrepressed.c
+++ b/cpukit/score/src/assertthreaddispatchingrepressed.c
@@ -23,6 +23,15 @@
 #if defined( RTEMS_DEBUG )
   void _Assert_Thread_dispatching_repressed( void )
-    _Assert( !_Thread_Dispatch_is_enabled() || _ISR_Get_level() != 0 );
+    bool dispatch_is_disabled;
+    ISR_Level level;
+    Per_CPU_Control *per_cpu;
+    per_cpu = _Per_CPU_Get_by_index( _SMP_Get_current_processor() );
+    dispatch_is_disabled = per_cpu->thread_dispatch_disable_level != 0;
+    _Assert( dispatch_is_disabled || _ISR_Get_level() != 0 );
 #endif
diff --git a/cpukit/score/src/isrsmp.c b/cpukit/score/src/isrsmp.c
deleted file mode 100644
index 2f292b0..0000000
--- a/cpukit/score/src/isrsmp.c
+++ /dev/null
@@ -1,76 +0,0 @@
- *  @file
- *  @brief Initialize, Disable, Enable, Flash, Enter, Exit ISR Implementation
- *  @ingroup ScoreISR
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems/system.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/threaddispatch.h>
-#include <rtems/score/smp.h>
-  uint32_t isr_nest_level;
-  ISR_Level level;
-  /* FIXME: Where is the corresponding _ISR_Enable()? */
-  _ISR_Disable( level );
-  isr_nest_level = _ISR_Nest_level++;
-  _Thread_Disable_dispatch();
-  return isr_nest_level;
-  ISR_Level level;
-  int       retval;
-  retval = 0;
-  _ISR_Nest_level--;
-  if ( _ISR_Nest_level == 0 ) {
-    if ( _Thread_Dispatch_necessary ) {
-      if ( _Thread_Dispatch_get_disable_level() == 1 ) {
-        retval = 1;
-   *  SPARC has special support to avoid some nasty recursive type behaviour.
-   *  When dispatching in a thread and we want to return to it then it needs
-   *  to finish.
-  #if defined(__sparc__)
-    if ( _CPU_ISR_Dispatch_disable )
-      retval = 0;
-  #endif
-  _ISR_Enable( level );
-  _Thread_Dispatch_decrement_disable_level();
-  return retval;
diff --git a/cpukit/score/src/percpuasm.c b/cpukit/score/src/percpuasm.c
index 968bc48..ecb4357 100644
--- a/cpukit/score/src/percpuasm.c
+++ b/cpukit/score/src/percpuasm.c
@@ -51,6 +51,12 @@ RTEMS_STATIC_ASSERT(
+  offsetof(Per_CPU_Control, thread_dispatch_disable_level)
+    == PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL,
+RTEMS_STATIC_ASSERT(
   offsetof(Per_CPU_Control, dispatch_necessary) == PER_CPU_DISPATCH_NEEDED,
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index aeef215..db08b96 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -50,6 +50,8 @@ static void _Scheduler_simple_smp_Allocate_processor(
   scheduled->is_scheduled = true;
   victim->is_scheduled = false;
+  _Per_CPU_Acquire( cpu_of_scheduled );
   if ( scheduled->is_executing ) {
     heir = cpu_of_scheduled->heir;
     cpu_of_scheduled->heir = scheduled;
@@ -57,10 +59,18 @@ static void _Scheduler_simple_smp_Allocate_processor(
     heir = scheduled;
+  _Per_CPU_Release( cpu_of_scheduled );
   if ( heir != victim ) {
     const Per_CPU_Control *cpu_of_executing = _Per_CPU_Get();
     heir->cpu = cpu_of_victim;
+     * FIXME: Here we need atomic store operations with a relaxed memory order.
+     * The _CPU_SMP_Send_interrupt() will ensure that the change can be
+     * observed consistently.
     cpu_of_victim->heir = heir;
     cpu_of_victim->dispatch_necessary = true;
diff --git a/cpukit/score/src/threaddispatch.c b/cpukit/score/src/threaddispatch.c
index c659f9f..3b5fb42 100644
--- a/cpukit/score/src/threaddispatch.c
+++ b/cpukit/score/src/threaddispatch.c
@@ -20,6 +20,7 @@
 #include <rtems/score/apiext.h>
+#include <rtems/score/assert.h>
@@ -28,60 +29,47 @@
 void _Thread_Dispatch( void )
   Thread_Control   *executing;
   Thread_Control   *heir;
   ISR_Level         level;
-  #if defined(RTEMS_SMP)
-     * WARNING: The SMP sequence has severe defects regarding the real-time
-     * performance.
-     * Consider the following scenario.  We have three tasks L (lowest
-     * priority), M (middle priority), and H (highest priority).  Now let a
-     * thread dispatch from M to L happen.  An interrupt occurs in
-     * _Thread_Dispatch() here:
-     * void _Thread_Dispatch( void )
-     * post_switch:
-     *   _ISR_Enable( level );
-     *   <-- INTERRUPT
-     *   <-- AFTER INTERRUPT
-     *   _Thread_Unnest_dispatch();
-     *   _API_extensions_Run_post_switch();
-     * The interrupt event makes task H ready.  The interrupt code will see
-     * _Thread_Dispatch_disable_level > 0 and thus doesn't perform a
-     * _Thread_Dispatch().  Now we return to position "AFTER INTERRUPT".  This
-     * means task L executes now although task H is ready!  Task H will execute
-     * once someone calls _Thread_Dispatch().
-  #else
-  #endif
+#if defined( RTEMS_SMP )
+#endif
+  per_cpu = _Per_CPU_Get();
+  _Assert( per_cpu->thread_dispatch_disable_level == 0 );
+  per_cpu->thread_dispatch_disable_level = 1;
+#endif
    *  Now determine if we need to perform a dispatch on the current CPU.
-  executing   = _Thread_Executing;
-  while ( _Thread_Dispatch_necessary == true ) {
-    heir = _Thread_Heir;
-      executing->is_executing = false;
-      heir->is_executing = true;
-    #endif
-    _Thread_Dispatch_necessary = false;
-    _Thread_Executing = heir;
+  executing = per_cpu->executing;
+  _Per_CPU_ISR_disable_and_acquire( per_cpu, level );
+   * On SMP the complete context switch must be atomic with respect to one
+   * processor.  The scheduler must obtain the per-CPU lock to check if a
+   * thread is executing and to update the heir.  This ensures that a thread
+   * cannot execute on more than one processor at a time.  See also
+   * _Thread_Handler() since _Context_switch() may branch to this function.
+  if ( per_cpu->dispatch_necessary ) {
+#else
+  while ( per_cpu->dispatch_necessary ) {
+#endif
+    heir = per_cpu->heir;
+    per_cpu->dispatch_necessary = false;
+    per_cpu->executing = heir;
+    executing->is_executing = false;
+    heir->is_executing = true;
+#endif
      *  When the heir and executing are the same, then we are being
@@ -102,16 +90,18 @@ void _Thread_Dispatch( void )
     if ( heir->budget_algorithm == THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE )
       heir->cpu_time_budget = _Thread_Ticks_per_timeslice;
+#if !defined( RTEMS_SMP )
+#endif
     #ifndef __RTEMS_USE_TICKS_FOR_STATISTICS__
       _Thread_Update_cpu_time_used(
         executing,
-        &_Thread_Time_of_last_context_switch
+        &per_cpu->time_of_last_context_switch
     #else
-        _TOD_Get_uptime( &_Thread_Time_of_last_context_switch );
+        _TOD_Get_uptime( &per_cpu->time_of_last_context_switch );
         heir->cpu_time_used++;
     #endif
@@ -165,21 +155,24 @@ void _Thread_Dispatch( void )
 #endif
 #endif
+     * We have to obtain these values again after the context switch since the
+     * heir thread may have migrated from another processor.  Values from the
+     * stack or non-volatile registers reflect the old execution environment.
+#endif
 post_switch:
-  #ifndef RTEMS_SMP
-    _Thread_Dispatch_set_disable_level( 0 );
-  #endif
+  _Assert( per_cpu->thread_dispatch_disable_level == 1 );
+  per_cpu->thread_dispatch_disable_level = 0;
-  #ifdef RTEMS_SMP
-    _Thread_Unnest_dispatch();
-  #endif
+  _Per_CPU_Release_and_ISR_enable( per_cpu, level );
   _API_extensions_Run_post_switch( executing );
diff --git a/cpukit/score/src/threaddispatchdisablelevel.c b/cpukit/score/src/threaddispatchdisablelevel.c
index 816959a..50af367 100644
--- a/cpukit/score/src/threaddispatchdisablelevel.c
+++ b/cpukit/score/src/threaddispatchdisablelevel.c
@@ -15,59 +15,69 @@
-#include <rtems/score/apiext.h>
-#include <rtems/score/context.h>
-#include <rtems/score/interr.h>
-#include <rtems/score/priority.h>
 #define NO_OWNER_CPU 0xffffffffU
-void _Thread_Dispatch_initialization( void )
+typedef struct {
+  SMP_lock_Control lock;
+  uint32_t owner_cpu;
+  uint32_t nest_level;
+} Giant_Control;
+static Giant_Control _Giant = {
+  .lock = SMP_LOCK_INITIALIZER,
+  .owner_cpu = NO_OWNER_CPU,
+  .nest_level = 0
+static void _Giant_Do_acquire( uint32_t self_cpu_index )
-  Thread_Dispatch_disable_level_lock_control *level_lock =
-    &_Thread_Dispatch_disable_level_lock;
+  Giant_Control *giant = &_Giant;
-  _Thread_Dispatch_disable_level = 0;
-  _SMP_lock_Initialize( &level_lock->lock );
-  level_lock->owner_cpu = NO_OWNER_CPU;
+  if ( giant->owner_cpu != self_cpu_index ) {
+    _SMP_lock_Acquire( &giant->lock );
+    giant->owner_cpu = self_cpu_index;
+    giant->nest_level = 1;
+  } else {
+    ++giant->nest_level;
-uint32_t _Thread_Dispatch_get_disable_level(void)
+static void _Giant_Do_release( void )
+  --giant->nest_level;
+  if ( giant->nest_level == 0 ) {
+    giant->owner_cpu = NO_OWNER_CPU;
+    _SMP_lock_Release( &giant->lock );
 uint32_t _Thread_Dispatch_increment_disable_level( void )
   ISR_Level isr_level;
-  uint32_t self_cpu;
+  uint32_t self_cpu_index;
   uint32_t disable_level;
+  Per_CPU_Control *self_cpu;
   _ISR_Disable( isr_level );
-   * We must obtain the processor ID after interrupts are disabled since a
-   * non-optimizing compiler may store the value on the stack and read it back.
+   * We must obtain the processor ID after interrupts are disabled to prevent
+   * thread migration.
-  self_cpu = _SMP_Get_current_processor();
+  self_cpu_index = _SMP_Get_current_processor();
-  if ( level_lock->owner_cpu != self_cpu ) {
-    _SMP_lock_Acquire( &level_lock->lock );
-    level_lock->owner_cpu = self_cpu;
-    level_lock->nest_level = 1;
-  } else {
-    ++level_lock->nest_level;
+  _Giant_Do_acquire( self_cpu_index );
-  disable_level = _Thread_Dispatch_disable_level;
+  self_cpu = _Per_CPU_Get_by_index( self_cpu_index );
+  disable_level = self_cpu->thread_dispatch_disable_level;
   ++disable_level;
-  _Thread_Dispatch_disable_level = disable_level;
+  self_cpu->thread_dispatch_disable_level = disable_level;
   _ISR_Enable( isr_level );
@@ -76,22 +86,18 @@ uint32_t _Thread_Dispatch_increment_disable_level( void )
 uint32_t _Thread_Dispatch_decrement_disable_level( void )
+  self_cpu = _Per_CPU_Get();
   --disable_level;
-  --level_lock->nest_level;
-  if ( level_lock->nest_level == 0 ) {
-    _SMP_lock_Release( &level_lock->lock );
+  _Giant_Do_release();
@@ -110,13 +116,20 @@ uint32_t _Thread_Dispatch_decrement_disable_level( void )
 uint32_t _Thread_Dispatch_set_disable_level(uint32_t value)
+  ISR_Level isr_level;
+  uint32_t disable_level;
+  _ISR_Disable( isr_level );
+  disable_level = _Thread_Dispatch_disable_level;
+  _ISR_Enable( isr_level );
    * If we need the dispatch level to go higher
    * call increment method the desired number of times.
-  while ( value > _Thread_Dispatch_disable_level ) {
-    _Thread_Dispatch_increment_disable_level();
+  while ( value > disable_level ) {
+    disable_level = _Thread_Dispatch_increment_disable_level();
@@ -124,9 +137,29 @@ uint32_t _Thread_Dispatch_set_disable_level(uint32_t value)
-  while ( value < _Thread_Dispatch_disable_level ) {
+  while ( value < disable_level ) {
+    disable_level = _Thread_Dispatch_decrement_disable_level();
   return value;
+void _Giant_Acquire( void )
+  _Assert( _Thread_Dispatch_disable_level != 0 );
+  _Giant_Do_acquire( _SMP_Get_current_processor() );
+void _Giant_Release( void )
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 1fde4cd..80941f8 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -19,6 +19,7 @@
 #endif
 #include <rtems/score/isrlevel.h>
 #include <rtems/score/userextimpl.h>
@@ -46,12 +47,46 @@
   #define EXECUTE_GLOBAL_CONSTRUCTORS
 #endif
+#if defined(EXECUTE_GLOBAL_CONSTRUCTORS)
+  static bool _Thread_Handler_is_constructor_execution_required(
+    Thread_Control *executing
+    static bool doneConstructors;
+    bool doCons = false;
+    #if defined(RTEMS_SMP)
+      static SMP_lock_Control constructor_lock = SMP_LOCK_INITIALIZER;
+      if ( !doneConstructors ) {
+        _SMP_lock_Acquire( &constructor_lock );
+    #endif
+    #if defined(RTEMS_MULTIPROCESSING)
+      doCons = !doneConstructors
+        && _Objects_Get_API( executing->Object.id ) != OBJECTS_INTERNAL_API;
+      if (doCons)
+        doneConstructors = true;
+    #else
+      (void) executing;
+      doCons = !doneConstructors;
+    #endif
+        _SMP_lock_Release( &constructor_lock );
+    #endif
+    return doCons;
+#endif
 void _Thread_Handler( void )
   ISR_Level  level;
-    static bool doneConstructors;
     bool doCons;
   #endif
@@ -64,23 +99,17 @@ void _Thread_Handler( void )
   _Context_Initialization_at_thread_begin();
-   * have to put level into a register for those cpu's that use
-   * inline asm here
-  level = executing->Start.isr_level;
-  _ISR_Set_level(level);
+  #if !defined(RTEMS_SMP)
+     * have to put level into a register for those cpu's that use
+     * inline asm here
+    level = executing->Start.isr_level;
+    _ISR_Set_level( level );
+  #endif
-    #if defined(RTEMS_MULTIPROCESSING)
-      doCons = !doneConstructors
-        && _Objects_Get_API( executing->Object.id ) != OBJECTS_INTERNAL_API;
-      if (doCons)
-        doneConstructors = true;
-    #else
-      doCons = !doneConstructors;
-    #endif
+    doCons = _Thread_Handler_is_constructor_execution_required( executing );
   #endif
@@ -109,7 +138,34 @@ void _Thread_Handler( void )
    *  At this point, the dispatch disable level BETTER be 1.
-  _Thread_Enable_dispatch();
+       * On SMP we enter _Thread_Handler() with interrupts disabled and
+       * _Thread_Dispatch() obtained the per-CPU lock for us.  We have to
+       * release it here and set the desired interrupt level of the thread.
+      Per_CPU_Control *per_cpu = _Per_CPU_Get();
+      _Assert( _ISR_Get_level() != 0 );
+      _Per_CPU_Release( per_cpu );
+      _ISR_Set_level( level);
+       * The thread dispatch level changed from one to zero.  Make sure we lose
+       * no thread dispatch necessary update.
+      _Thread_Dispatch();
+  #else
+    _Thread_Enable_dispatch();
+  #endif
diff --git a/cpukit/score/src/threadloadenv.c b/cpukit/score/src/threadloadenv.c
index ad33626..eb3cc63 100644
--- a/cpukit/score/src/threadloadenv.c
+++ b/cpukit/score/src/threadloadenv.c
@@ -26,6 +26,7 @@ void _Thread_Load_environment(
   bool is_fp;
+  uint32_t isr_level;
   if ( the_thread->Start.fp_context ) {
@@ -40,11 +41,22 @@ void _Thread_Load_environment(
   the_thread->budget_algorithm = the_thread->Start.budget_algorithm;
   the_thread->budget_callout   = the_thread->Start.budget_callout;
+   * On SMP we have to start the threads with interrupts disabled, see also
+   * _Thread_Handler() and _Thread_Dispatch().  In _Thread_Handler() the
+   * _ISR_Set_level() is used to set the desired interrupt state of the thread.
+  isr_level = CPU_MODES_INTERRUPT_MASK;
+#else
+  isr_level = the_thread->Start.isr_level;
+#endif
   _Context_Initialize(
     &the_thread->Registers,
     the_thread->Start.Initial_stack.area,
     the_thread->Start.Initial_stack.size,
-    the_thread->Start.isr_level,
+    isr_level,
     _Thread_Handler,
     is_fp
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 24ad48a..726cfa9 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -39,9 +39,6 @@ bool _Thread_Restart(
     _User_extensions_Thread_restart( the_thread );
-    if ( _Thread_Is_executing ( the_thread ) )
-      _Thread_Restart_self();
     return true;
diff --git a/cpukit/score/src/threadstartmultitasking.c b/cpukit/score/src/threadstartmultitasking.c
index b6ff073..74ed40c 100644
--- a/cpukit/score/src/threadstartmultitasking.c
+++ b/cpukit/score/src/threadstartmultitasking.c
@@ -28,6 +28,8 @@ void _Thread_Start_multitasking( Context_Control *context )
   _Per_CPU_Change_state( self_cpu, PER_CPU_STATE_UP );
+  _Per_CPU_Acquire( self_cpu );
   self_cpu->executing->is_executing = false;
 #endif
@@ -70,10 +72,11 @@ void _Thread_Start_multitasking( Context_Control *context )
   } else {
-     * Threads begin execution in the _Thread_Handler() function.   This function
-     * will call _Thread_Enable_dispatch().
+     * Threads begin execution in the _Thread_Handler() function.   This
+     * function will set the thread dispatch disable level to zero and calls
+     * _Per_CPU_Release().
+    self_cpu->thread_dispatch_disable_level = 1;
     _CPU_Context_switch_to_first_task_smp( &heir->Registers );
diff --git a/testsuites/tmtests/tm26/task1.c b/testsuites/tmtests/tm26/task1.c
index 26785b2..fbe0d2f 100644
--- a/testsuites/tmtests/tm26/task1.c
+++ b/testsuites/tmtests/tm26/task1.c
@@ -127,6 +127,24 @@ static void set_thread_executing( Thread_Control *thread )
 #endif
+static void thread_disable_dispatch( void )
+  rtems_interrupt_level level;
+  rtems_interrupt_disable( level );
+  ( void ) level;
+#else
+  _Thread_Disable_dispatch();
+#endif
 rtems_task null_task(
   rtems_task_argument argument
@@ -306,7 +324,7 @@ rtems_task Middle_task(
   set_thread_dispatch_necessary( false );
+  thread_disable_dispatch();
   benchmark_timer_initialize();
     _Context_Switch(
@@ -350,7 +368,7 @@ rtems_task Low_task(
 #if (CPU_HARDWARE_FP == 1) || (CPU_SOFTWARE_FP == 1)
@@ -383,7 +401,7 @@ rtems_task Floating_point_task_1(
@@ -407,12 +425,6 @@ rtems_task Floating_point_task_1(
     (Thread_Control *) _Chain_First(&ready_queues[FP2_PRIORITY])
-  /* do not force context switch */
-  set_thread_dispatch_necessary( false );
     _Context_Save_fp( &executing->fp_context );
@@ -444,12 +456,6 @@ rtems_task Floating_point_task_2(
   FP_LOAD( 1.0 );
1.7.7
