[rtems commit] smptests/smp07: Use suspend instead of delete
Wed Aug 7 06:18:52 UTC 2013
Sebastian Huber wrote:
> On 2013-08-07 07:55, Sebastian Huber wrote:
>>>> - (void) rtems_task_delete( RTEMS_SELF );
>>>> + /* FIXME: Task deletion currently not supported */
>>>> + (void) rtems_task_suspend( RTEMS_SELF );
>>> In my view this is a blocker for 4.11. With such a bug we cannot say
>>> SMP is
>>> available and it was planned to be in 4.11.
>>> Is there a "hold giant lock" level solution ? That is something, even if
>>> performance is poor, that is stable.
>> I don't know an easy solution for the thread deletion problem, see also
>> http://www.rtems.org/pipermail/rtems-devel/2013-July/003509.html
> A list of other unsupported features can be found here:
> http://git.rtems.org/rtems/tree/testsuites/smptests/smpunsupported01/init.c
> The task variable API will never work on SMP
I consider this a feature. I never liked that API. This might break the
environment stuff related to the shell which I think uses it. I need to
check.
> (the Ada self rtems_ada_self has the same problem).
I will leave that for Joel.
> For Newlib a similar fixed with the usage of __getreent().
Do you mean newlib has this fixed with __getreent()
> As a result the C++ support is currently broken on SMP.
Which specific bits ?
> The non-preempt mode can work on SMP, but I think this would lead to a
> broken design.
On SMP the Classic API should return an error.
> The bdbuf and the once functions will not work due to that (mutual
> exclusion via non-preempt doesn't work on SMP).
Yes, we need condition variables in the Classic API.
