Updating legacy code in arm nds
Vipul Nayyar
nayyar_vipul at yahoo.com
Thu Aug 8 13:44:42 UTC 2013
Hello Sebastian,
I'll look into & study your commit.
I typically maintain two local repos, one forked from github rtems, in which I do most of my work. And the other pulled from git.rtems.org, that remains intact.
I'm getting this percpu.h error in the latest git master updated from rtems.org site. Please have a look.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: Joel Sherrill <joel.sherrill at oarcorp.com>; Cynthia Rempel <cynt6007 at vandals.uidaho.edu>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Thursday, 8 August 2013 11:44 AM
Subject: Re: Updating legacy code in arm nds
Hello Vipul,
for a conversion example please have a look at
http://git.rtems.org/rtems/commit/?id=f4dc319a8f92190c6efac916fb8b9b651d89df7c
read also the comments in "irq-generic.h".
On 2013-08-06 19:34, Vipul Nayyar wrote:
> Hello,
> As suggested, I studied the working of interrupt controller. So, I've made
> implementations of install & remove methods from libnds to change to Interrupt
> API. This is a small patch for arm nds. Just checking if going in the right
> direction.
> Fair warning: the compilation of arm nds gives an error, but not due to my
> changes. The error given is :
> ../../../../cpukit/../../../nds/lib/include/rtems/score/percpu.h:25:34: fatal
> error: rtems/score/assert.h: No such file or directory
> #include <rtems/score/assert.h>
> compilation terminated.
Do you get this error with the latest Git master?
> I'll be happy to fix this error, that's already present in the rtems tree. The
> path to assert.h seems to be fine. Need guidance.
> Regards
> Vipul Nayyar
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130808/17c3d375/attachment.html>
