Change RTEMS GCC Thread model to POSIX.
Chris Johns
chrisj at rtems.org
Fri Aug 9 08:06:55 UTC 2013
Hi,
The patch attached changes the RTEMS thread model in GCC from 'rtems' to
'posix'. The patch also fixes the include paths for newlib so the
correct 'machine/_types.h' is picked up.
RTEMS using the POSIX thread model in gcc means C++ works with SMP. The
'rtems' thread model uses an RTEMS specific interface to code in RTEMS
that uses task variables. Task variables make no sense and will never
work in SMP systems [1].
This patch leaves the RTEMS thread model in the gcc sources. A patch for
gcc patches list would need to remove these sources.
[1] We should consider no building the task variable code when building
an SMP kernel.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130809/192471cd/attachment.ksh>
