[PATCH 08/12] smp: Rename _Scheduler_simple_smp_Start_idle()
Tue Aug 13 13:42:53 UTC 2013
Rename _Scheduler_simple_smp_Start_idle() to
_Scheduler_SMP_Start_idle().
 cpukit/score/Makefile.am                           |    1 +
 .../score/include/rtems/score/schedulersimplesmp.h |    7 +---
 cpukit/score/include/rtems/score/schedulersmp.h    |    7 +++
 .../score/include/rtems/score/schedulersmpimpl.h   |    2 -
 cpukit/score/src/schedulersimplesmp.c              |   12 ------
 cpukit/score/src/schedulersmpstartidle.c           |   40 ++++++++++++++++++++
 6 files changed, 49 insertions(+), 20 deletions(-)
 create mode 100644 cpukit/score/src/schedulersmpstartidle.c
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 5136d81..c5af9c7 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -120,6 +120,7 @@ endif
 if HAS_SMP
 libscore_a_SOURCES += src/schedulersimplesmp.c
+libscore_a_SOURCES += src/schedulersmpstartidle.c
 libscore_a_SOURCES += src/smp.c
 endif
diff --git a/cpukit/score/include/rtems/score/schedulersimplesmp.h b/cpukit/score/include/rtems/score/schedulersimplesmp.h
index 5329610..f62068a 100644
--- a/cpukit/score/include/rtems/score/schedulersimplesmp.h
+++ b/cpukit/score/include/rtems/score/schedulersimplesmp.h
@@ -68,7 +68,7 @@ extern "C" {
     _Scheduler_priority_Priority_compare, \
     _Scheduler_default_Release_job, \
     _Scheduler_default_Tick, \
-    _Scheduler_simple_smp_Start_idle \
+    _Scheduler_SMP_Start_idle \
 void _Scheduler_simple_smp_Initialize( void );
@@ -83,11 +83,6 @@ void _Scheduler_simple_smp_Yield( Thread_Control *thread );
 void _Scheduler_simple_smp_Schedule( Thread_Control *thread );
-void _Scheduler_simple_smp_Start_idle(
-  Thread_Control *thread,
-  Per_CPU_Control *cpu
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulersmp.h b/cpukit/score/include/rtems/score/schedulersmp.h
index 8b649b7..457af22 100644
--- a/cpukit/score/include/rtems/score/schedulersmp.h
+++ b/cpukit/score/include/rtems/score/schedulersmp.h
@@ -24,6 +24,8 @@
 #define _RTEMS_SCORE_SCHEDULERSMP_H
+#include <rtems/score/percpu.h>
+#include <rtems/score/thread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -42,6 +44,11 @@ typedef struct {
   Chain_Control ready[ 1 ];
 } Scheduler_SMP_Control;
+void _Scheduler_SMP_Start_idle(
+  Thread_Control *thread,
+  Per_CPU_Control *cpu
 #ifdef __cplusplus
diff --git a/cpukit/score/include/rtems/score/schedulersmpimpl.h b/cpukit/score/include/rtems/score/schedulersmpimpl.h
index 7736d2b..7e123e2 100644
--- a/cpukit/score/include/rtems/score/schedulersmpimpl.h
+++ b/cpukit/score/include/rtems/score/schedulersmpimpl.h
@@ -25,8 +25,6 @@
 #include <rtems/score/schedulersmp.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/percpu.h>
 #ifdef __cplusplus
 extern "C" {
diff --git a/cpukit/score/src/schedulersimplesmp.c b/cpukit/score/src/schedulersimplesmp.c
index 0905723..9e4c9d9 100644
--- a/cpukit/score/src/schedulersimplesmp.c
+++ b/cpukit/score/src/schedulersimplesmp.c
@@ -182,15 +182,3 @@ void _Scheduler_simple_smp_Schedule( Thread_Control *thread )
   ( void ) thread;
-  Scheduler_SMP_Control *self = _Scheduler_SMP_Instance();
-  thread->is_scheduled = true;
-  thread->cpu = cpu;
-  _Chain_Append_unprotected( &self->scheduled, &thread->Object.Node );
diff --git a/cpukit/score/src/schedulersmpstartidle.c b/cpukit/score/src/schedulersmpstartidle.c
new file mode 100644
index 0000000..4b6df5e
--- /dev/null
+++ b/cpukit/score/src/schedulersmpstartidle.c
@@ -0,0 +1,40 @@
+ * @file
+ * @brief SMP Scheduler Start Idle Operation
+ * @ingroup ScoreSchedulerSMP
+ * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/chainimpl.h>
+  Scheduler_SMP_Control *self = _Scheduler_SMP_Instance();
+  thread->is_scheduled = true;
+  thread->cpu = cpu;
+  _Chain_Append_unprotected( &self->scheduled, &thread->Object.Node );
1.7.7
