[rtems commit] posix: Change pthread_once to be SMP safe.
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Aug 14 00:31:33 UTC 2013
You didn't remove both task mode calls as best I can tell on my phone.
Chris Johns <chrisj at rtems.org> wrote:
Module:    rtems
Branch:    master
Commit:    03acc5915e002f0b03eee9e86212209705cca6d6
Changeset: http://git.rtems.org/rtems/commit/?id=03acc5915e002f0b03eee9e86212209705cca6d6
Author:    Chris Johns <chrisj at rtems.org>
Date:      Wed Aug 14 10:21:41 2013 +1000
Change pthread_once from using disabled pre-emption to using a
pthread mutex making it SMP safe. GCC using a posix threading
model uses pthread_once.
The pthread mutex requires at least 1 mutex is configured so
confdefs.h has been updated to account for the internal
mutex.
 cpukit/posix/Makefile.am                    |    6 ++-
 cpukit/posix/include/rtems/posix/onceimpl.h |   57 +++++++++++++++++++++++++++
 cpukit/posix/preinstall.am                  |    4 ++
 cpukit/posix/src/once.c                     |   49 +++++++++++++++++++++++
 cpukit/posix/src/pthreadonce.c              |   50 +++++++++++++++++++-----
 cpukit/sapi/include/confdefs.h              |    7 +++
 cpukit/sapi/src/posixapi.c                  |    2 +
 7 files changed, 164 insertions(+), 11 deletions(-)
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 1b83eee..ea6d3d9 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -33,6 +33,7 @@ include_rtems_posix_HEADERS += include/rtems/posix/mqueue.h
 include_rtems_posix_HEADERS += include/rtems/posix/mqueueimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/mutex.h
 include_rtems_posix_HEADERS += include/rtems/posix/muteximpl.h
+include_rtems_posix_HEADERS += include/rtems/posix/onceimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
 include_rtems_posix_HEADERS += include/rtems/posix/priorityimpl.h
 include_rtems_posix_HEADERS += include/rtems/posix/psignal.h
@@ -115,6 +116,9 @@ libposix_a_SOURCES += src/mutexattrdestroy.c src/mutexattrgetprioceiling.c \
     src/mutexlocksupp.c src/mutexsetprioceiling.c src/mutextimedlock.c \
     src/mutextranslatereturncode.c src/mutextrylock.c src/mutexunlock.c
+## ONCE_C_FILES
+libposix_a_SOURCES += src/once.c src/pthreadonce.c
 ## PTHREAD_C_FILES
 libposix_a_SOURCES += src/pthreadatfork.c src/pthreadattrdestroy.c \
     src/pthreadattrgetdetachstate.c src/pthreadattrgetinheritsched.c \
@@ -131,7 +135,7 @@ libposix_a_SOURCES += src/pthreadatfork.c src/pthreadattrdestroy.c \
     src/pthreadexit.c src/pthreadgetcpuclockid.c \
     src/pthreadgetschedparam.c \
     src/pthreadinitthreads.c src/pthreadjoin.c src/pthreadkill.c \
-    src/pthreadonce.c src/pthreadself.c \
+    src/pthreadself.c \
     src/pthreadsetschedparam.c src/pthreadsigmask.c \
     src/psxpriorityisvalid.c src/psxtransschedparam.c
diff --git a/cpukit/posix/include/rtems/posix/onceimpl.h b/cpukit/posix/include/rtems/posix/onceimpl.h
new file mode 100644
index 0000000..f023810
--- /dev/null
+++ b/cpukit/posix/include/rtems/posix/onceimpl.h
@@ -0,0 +1,57 @@
+ * @file
+ * @brief Private Inlined Routines for POSIX Once
+ * This include file contains the static inline implementation of the private
+ * inlined routines for POSIX once.
+ *  COPYRIGHT (c) 1989-1999.
+ *  On-Line Applications Research Corporation (OAR).
+ *  COPYRIGHT (c) 2013.
+ *  Chris Johns <chrisj at rtems.org>
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#include <rtems/score/objectimpl.h>
+#include <rtems/score/percpu.h>
+#ifndef _RTEMS_POSIX_ONCEIMPL_H
+#define _RTEMS_POSIX_ONCEMPL_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup POSIX_ONCE
+ * @brief Lock to allow once mutex's to be initialized.
+POSIX_EXTERN pthread_mutex_t _POSIX_Once_Lock;
+ * @brief POSIX once manager initialization.
+ * This routine performs the initialization necessary for this manager.
+void _POSIX_Once_Manager_initialization(void);
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 093a9df..d0e238c 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -84,6 +84,10 @@ $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h: include/rtems/posix/muteximpl.h $(PR
        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
+$(PROJECT_INCLUDE)/rtems/posix/onceimpl.h: include/rtems/posix/onceimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
 $(PROJECT_INCLUDE)/rtems/posix/posixapi.h: include/rtems/posix/posixapi.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
        $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
diff --git a/cpukit/posix/src/once.c b/cpukit/posix/src/once.c
index 0000000..d77c3c1
--- /dev/null
+++ b/cpukit/posix/src/once.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief POSIX Once Manager Initialization
+ * @ingroup POSIX_ONCE POSIX Once Support
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <pthread.h>
+#include <errno.h>
+#include <rtems.h>
+#include <rtems/posix/onceimpl.h>
+pthread_mutex_t _POSIX_Once_Lock;
+  pthread_mutexattr_t mattr;
+  int r;
+  _POSIX_Once_Lock = PTHREAD_MUTEX_INITIALIZER;
+  r = pthread_mutexattr_init( &mattr );
+  if ( r != 0 )
+    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa0000 | r );
+  r = pthread_mutexattr_settype( &mattr, PTHREAD_MUTEX_RECURSIVE );
+   if ( r != 0 )
+    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa1000 | r );
+  r = pthread_mutex_init( &_POSIX_Once_Lock, &mattr );
+  if ( r != 0 )
+    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa2000 | r );
+  pthread_mutexattr_destroy( &mattr );
diff --git a/cpukit/posix/src/pthreadonce.c b/cpukit/posix/src/pthreadonce.c
index 0700a22..2b02f1e 100644
--- a/cpukit/posix/src/pthreadonce.c
+++ b/cpukit/posix/src/pthreadonce.c
@@ -25,25 +25,55 @@
-#include <rtems/score/thread.h>
+#define PTHREAD_ONCE_INIT_NOT_RUN  0
+#define PTHREAD_ONCE_INIT_RUNNING  1
+#define PTHREAD_ONCE_INIT_RUN      2
 int pthread_once(
   pthread_once_t  *once_control,
   void           (*init_routine)(void)
+  int r = 0;
   if ( !once_control || !init_routine )
     return EINVAL;
-  if ( !once_control->init_executed ) {
-    rtems_mode saveMode;
-    rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &saveMode);
-      once_control->is_initialized = true;
-      once_control->init_executed = true;
-      (*init_routine)();
+  if ( once_control->is_initialized != 1 )
+    return EINVAL;
+  if ( once_control->init_executed != PTHREAD_ONCE_INIT_RUN ) {
+    r = pthread_mutex_lock( &_POSIX_Once_Lock );
+    if ( r == 0 ) {
+      int rr;
+       * Getting to here means the once_control is locked so we have:
+       *  1. The init has not run and the state is PTHREAD_ONCE_INIT_NOT_RUN.
+       *  2. The init has finished and the state is PTHREAD_ONCE_INIT_RUN.
+       *  3. The init is being run by this thread and the state
+       *     PTHREAD_ONCE_INIT_RUNNING so we are nesting. This is an error.
+      switch ( once_control->init_executed ) {
+        case PTHREAD_ONCE_INIT_NOT_RUN:
+          once_control->init_executed = PTHREAD_ONCE_INIT_RUNNING;
+          (*init_routine)();
+          once_control->init_executed = PTHREAD_ONCE_INIT_RUN;
+          break;
+        case PTHREAD_ONCE_INIT_RUNNING:
+          r = EINVAL;
+          break;
+        default:
+          break;
+      rr = pthread_mutex_unlock( &_POSIX_Once_Lock );
+      if ( r == 0 )
+        r = rr;
-    rtems_task_mode(saveMode, RTEMS_PREEMPT_MASK, &saveMode);
-  return 0;
+  return r;
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 50db877..2a3af15 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1695,6 +1695,11 @@ const rtems_libio_helper rtems_fs_init_helper =
   #include <rtems/posix/timer.h>
+   * POSIX Once support uses a single mutex.
+  #define CONFIGURE_MAXIMUM_POSIX_INTERNAL_MUTEXES 1
    * Account for the object control structures plus the name
    * of the object to be duplicated.
@@ -1856,6 +1861,7 @@ const rtems_libio_helper rtems_fs_init_helper =
   #define CONFIGURE_MEMORY_FOR_POSIX \
     ( CONFIGURE_MEMORY_FOR_POSIX_MUTEXES( CONFIGURE_MAXIMUM_POSIX_MUTEXES + \
+          CONFIGURE_MAXIMUM_POSIX_INTERNAL_MUTEXES + \
           CONFIGURE_MAXIMUM_GO_CHANNELS + CONFIGURE_GO_INIT_MUTEXES) + \
       CONFIGURE_MEMORY_FOR_POSIX_CONDITION_VARIABLES( \
           CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES + \
@@ -2304,6 +2310,7 @@ const rtems_libio_helper rtems_fs_init_helper =
       CONFIGURE_MAXIMUM_POSIX_THREADS + CONFIGURE_MAXIMUM_ADA_TASKS +
         CONFIGURE_MAXIMUM_GOROUTINES,
       CONFIGURE_MAXIMUM_POSIX_MUTEXES + CONFIGURE_GNAT_MUTEXES +
         CONFIGURE_MAXIMUM_ADA_TASKS + CONFIGURE_MAXIMUM_FAKE_ADA_TASKS +
         CONFIGURE_GO_INIT_MUTEXES + CONFIGURE_MAXIMUM_GO_CHANNELS,
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index af9ba2c..2d784a1 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -33,6 +33,7 @@
 #include <rtems/posix/keyimpl.h>
 #include <rtems/posix/mqueueimpl.h>
 #include <rtems/posix/posixapi.h>
 #include <rtems/posix/psignalimpl.h>
@@ -66,6 +67,7 @@ void _POSIX_API_Initialize(void)
   _POSIX_Key_Manager_initialization();
   _POSIX_Mutex_Manager_initialization();
   _POSIX_Message_queue_Manager_initialization();
+  _POSIX_Once_Manager_initialization();
   _POSIX_Semaphore_Manager_initialization();
   _POSIX_Timer_Manager_initialization();
   _POSIX_Barrier_Manager_initialization();
rtems-vc mailing list
rtems-vc at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-vc
