[rtems commit] posix: Handle recursive attributes correctly.
Sebastian Huber
Wed Aug 14 05:59:20 UTC 2013
Does this mean that recursive mutexes didn't work up to now and we don't have a
test case for recursive mutexes?
On 2013-08-14 01:26, Chris Johns wrote:
> Module: rtems
> Branch: master
> Commit: 40398c45dcd9734b41f37ae4c5af124d58b59b32
> Changeset: http://git.rtems.org/rtems/commit/?id=40398c45dcd9734b41f37ae4c5af124d58b59b32
> Author: Chris Johns <chrisj at rtems.org>
> Date: Wed Aug 14 09:29:56 2013 +1000
> The recursive field in the pthread_mutexattr_t is now not used. The
> code in pthread_mutexattr_settype only sets the type field and not
> the recursive field.
> cpukit/posix/src/mutexinit.c | 2 +-
> 1 files changed, 1 insertions(+), 1 deletions(-)
> diff --git a/cpukit/posix/src/mutexinit.c b/cpukit/posix/src/mutexinit.c
> index e7663c9..592c77a 100644
> --- a/cpukit/posix/src/mutexinit.c
> +++ b/cpukit/posix/src/mutexinit.c
> @@ -165,7 +165,7 @@ int pthread_mutex_init(
> the_mutex_attr = &the_mutex->Mutex.Attributes;
> - if ( the_attr->recursive )
> + if ( the_attr->type == PTHREAD_MUTEX_RECURSIVE )
> the_mutex_attr->lock_nesting_behavior = CORE_MUTEX_NESTING_ACQUIRES;
> else
> the_mutex_attr->lock_nesting_behavior = CORE_MUTEX_NESTING_IS_ERROR;
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
