[rtems commit] posix: Change pthread_once to be SMP safe.
Wed Aug 14 06:21:41 UTC 2013
On 2013-08-14 02:21, Chris Johns wrote:
> Module:    rtems
> Branch:    master
> Commit:    03acc5915e002f0b03eee9e86212209705cca6d6
> Changeset: http://git.rtems.org/rtems/commit/?id=03acc5915e002f0b03eee9e86212209705cca6d6
> Author:    Chris Johns <chrisj at rtems.org>
> Date:      Wed Aug 14 10:21:41 2013 +1000
> Change pthread_once from using disabled pre-emption to using a
> pthread mutex making it SMP safe. GCC using a posix threading
> model uses pthread_once.
> The pthread mutex requires at least 1 mutex is configured so
> confdefs.h has been updated to account for the internal
> mutex.
>   cpukit/posix/Makefile.am                    |    6 ++-
>   cpukit/posix/include/rtems/posix/onceimpl.h |   57 +++++++++++++++++++++++++++
>   cpukit/posix/preinstall.am                  |    4 ++
>   cpukit/posix/src/once.c                     |   49 +++++++++++++++++++++++
>   cpukit/posix/src/pthreadonce.c              |   50 +++++++++++++++++++-----
>   cpukit/sapi/include/confdefs.h              |    7 +++
>   cpukit/sapi/src/posixapi.c                  |    2 +
>   7 files changed, 164 insertions(+), 11 deletions(-)
> diff --git a/cpukit/posix/include/rtems/posix/onceimpl.h b/cpukit/posix/include/rtems/posix/onceimpl.h
> new file mode 100644
> index 0000000..f023810
> --- /dev/null
> +++ b/cpukit/posix/include/rtems/posix/onceimpl.h
> @@ -0,0 +1,57 @@
> + * @file
> + * @brief Private Inlined Routines for POSIX Once
> + * This include file contains the static inline implementation of the private
> + * inlined routines for POSIX once.
> + *  COPYRIGHT (c) 1989-1999.
> + *  On-Line Applications Research Corporation (OAR).
> + *  COPYRIGHT (c) 2013.
> + *  Chris Johns <chrisj at rtems.org>
> + *  The license and distribution terms for this file may be
> + *  found in the file LICENSE in this distribution or at
> + *  http://www.rtems.com/license/LICENSE.
> +#include <rtems/score/objectimpl.h>
> +#include <rtems/score/percpu.h>
> +#ifndef _RTEMS_POSIX_ONCEIMPL_H
> +#define _RTEMS_POSIX_ONCEMPL_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup POSIX_ONCE
> + * @brief Lock to allow once mutex's to be initialized.
> +POSIX_EXTERN pthread_mutex_t _POSIX_Once_Lock;
The POSIX_EXTERN in combination with the definition in once.c is wrong.
> + * @brief POSIX once manager initialization.
> + * This routine performs the initialization necessary for this manager.
> +void _POSIX_Once_Manager_initialization(void);
> +#ifdef __cplusplus
> +#endif
> +#endif
> +/*  end of include file */
> diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
> index 093a9df..d0e238c 100644
> --- a/cpukit/posix/preinstall.am
> +++ b/cpukit/posix/preinstall.am
> @@ -84,6 +84,10 @@ $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h: include/rtems/posix/muteximpl.h $(PR
>   	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/muteximpl.h
> +$(PROJECT_INCLUDE)/rtems/posix/onceimpl.h: include/rtems/posix/onceimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
> +	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/onceimpl.h
>   $(PROJECT_INCLUDE)/rtems/posix/posixapi.h: include/rtems/posix/posixapi.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
>   	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/posixapi.h
> diff --git a/cpukit/posix/src/once.c b/cpukit/posix/src/once.c
> index 0000000..d77c3c1
> --- /dev/null
> +++ b/cpukit/posix/src/once.c
> @@ -0,0 +1,49 @@
> + * @file
> + * @brief POSIX Once Manager Initialization
> + * @ingroup POSIX_ONCE POSIX Once Support
> +#if HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <pthread.h>
> +#include <errno.h>
> +#include <rtems.h>
> +#include <rtems/posix/onceimpl.h>
> +pthread_mutex_t _POSIX_Once_Lock;
> +  pthread_mutexattr_t mattr;
> +  int r;
I would name this "eno" since the status is encoded as an errno number.
> +  _POSIX_Once_Lock = PTHREAD_MUTEX_INITIALIZER;
> +  r = pthread_mutexattr_init( &mattr );
> +  if ( r != 0 )
> +    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa0000 | r );
Errors in the pthread_mutexattr_init(), pthread_mutexattr_settype(), and
pthread_mutexattr_destroy() are pure programming errors, so I should use
_Assert() here.
> +  r = pthread_mutexattr_settype( &mattr, PTHREAD_MUTEX_RECURSIVE );
> +   if ( r != 0 )
> +    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa1000 | r );
> +  r = pthread_mutex_init( &_POSIX_Once_Lock, &mattr );
> +  if ( r != 0 )
> +    rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, 0x80aa2000 | r );
This is a configuration error.  We need a proper error code for this with
source INTERNAL_ERROR_POSIX_API.  We need also a new test for this fatal error,
e.g. psxtests/psxfatal03.
> +  pthread_mutexattr_destroy( &mattr );
Check return value with _Assert()?
> diff --git a/cpukit/posix/src/pthreadonce.c b/cpukit/posix/src/pthreadonce.c
> index 0700a22..2b02f1e 100644
> --- a/cpukit/posix/src/pthreadonce.c
> +++ b/cpukit/posix/src/pthreadonce.c
> @@ -25,25 +25,55 @@
>   #include <rtems.h>
>   #include <rtems/system.h>
> -#include <rtems/score/thread.h>
> +#define PTHREAD_ONCE_INIT_NOT_RUN  0
> +#define PTHREAD_ONCE_INIT_RUNNING  1
> +#define PTHREAD_ONCE_INIT_RUN      2
I would rename PTHREAD_ONCE_INIT_RUN to PTHREAD_ONCE_INIT_COMPLETE to avoid too
many run combinations.
>   int pthread_once(
>     pthread_once_t  *once_control,
>     void           (*init_routine)(void)
> +  int r = 0;
>     if ( !once_control || !init_routine )
>       return EINVAL;
> -  if ( !once_control->init_executed ) {
> -    rtems_mode saveMode;
> -    rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &saveMode);
> -      once_control->is_initialized = true;
> -      once_control->init_executed = true;
> -      (*init_routine)();
> +  if ( once_control->is_initialized != 1 )
> +    return EINVAL;
> +  if ( once_control->init_executed != PTHREAD_ONCE_INIT_RUN ) {
> +    r = pthread_mutex_lock( &_POSIX_Once_Lock );
You get an error here,
1. a pure programming error, e.g. call of this function before
_POSIX_Once_Manager_initialization(), or
2. a corrupt system.
I would simply use _Assert() here.
> +    if ( r == 0 ) {
> +      int rr;
> +       * Getting to here means the once_control is locked so we have:
> +       *  1. The init has not run and the state is PTHREAD_ONCE_INIT_NOT_RUN.
> +       *  2. The init has finished and the state is PTHREAD_ONCE_INIT_RUN.
> +       *  3. The init is being run by this thread and the state
> +       *     PTHREAD_ONCE_INIT_RUNNING so we are nesting. This is an error.
> +      switch ( once_control->init_executed ) {
> +        case PTHREAD_ONCE_INIT_NOT_RUN:
> +          once_control->init_executed = PTHREAD_ONCE_INIT_RUNNING;
> +          (*init_routine)();
> +          once_control->init_executed = PTHREAD_ONCE_INIT_RUN;
> +          break;
> +        case PTHREAD_ONCE_INIT_RUNNING:
> +          r = EINVAL;
> +          break;
> +        default:
> +          break;
> +      rr = pthread_mutex_unlock( &_POSIX_Once_Lock );
> +      if ( r == 0 )
> +        r = rr;
> -    rtems_task_mode(saveMode, RTEMS_PREEMPT_MASK, &saveMode);
> -  return 0;
> +  return r;
I think the nesting case is not covered by a test.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
