Change RTEMS GCC Thread model to POSIX, take 2
Wed Aug 14 06:28:08 UTC 2013
On 2013-08-14 03:39, Chris Johns wrote:
> Hi all,
> This is an updated patch I have tested with the the latest RTEMS kernel with
> the pthread_once patch.
> This change removes the weak support and RTEMS requires linking with POSIX
> enabled if C++ used.
> I am going to commit this to the rtems-tools and update the RSB to use it.
What is the error handling in case the C++ support cannot create a resource for
example?  Previously this was a fatal error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
