Current head compilation problem
Sree Harsha Konduri
sreehars at buffalo.edu
Fri Aug 16 01:45:45 UTC 2013
Hey Chris,
The configure i used is
$ ../rtems/configure --target=i386-rtems4.11 --enable-maintainer-mode
--enable-smp --enable-tests=yes --enable-rtemsbsp=pc386 --disable-posix
USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0 target_alias=i386-rtems4.11
This is the error.
Making all in hello
gmake[6]: Entering directory
`/home/harsha/rtems/4.11/pc386/i386-rtems4.11/c/pc386/testsuites/samples/hello'
i386-rtems4.11-gcc -B../../../../../pc386/lib/ -specs bsp_specs -qrtems
-mtune=i386 -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-Wl,-Ttext,0x00100000 -mtune=i386 -o hello.exe init.o
../../../../../pc386/lib/librtemsbsp.a(ckinit.o): In function
`bsp_clock_nanoseconds_since_last_tick_i8254':
/home/harsha/rtems/4.11/pc386/i386-rtems4.11/c/pc386/lib/libbsp/i386/pc386/../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/ckinit.c:153:
undefined reference to `Clock_driver_isrs'
`Clock_driver_support_at_tick_tsc':
/home/harsha/rtems/4.11/pc386/i386-rtems4.11/c/pc386/lib/libbsp/i386/pc386/../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/ckinit.c:90:
collect2: error: ld returned 1 exit status
gmake[6]: *** [hello.exe] Error 1
gmake[6]: Leaving directory
gmake[5]: *** [all-recursive] Error 1
Thanks,
Sree
On Thu, Aug 15, 2013 at 9:27 PM, Chris Johns <chrisj at rtems.org> wrote:
> Joel Sherrill wrote:
>> This could be a combination of changes. Vipul redid the
>> interrupt code and may have missed something. I think
>> he missed something.
>> Chris and Sebastian committed changes to clockdrv_shell.h
>> to change from "#ifdef " to "#if " and this is apparently
>> didn't propagate it to all impacted BSPs.
>> Adding people who need to check into this.
> A specific error with the configure line would be a big help. Sree ??
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130815/29c31e05/attachment.html>
